On Mar 26, 6:18*pm, wrote:
The older 172's with manual flaps and simple basic electronics are pretty low maintenance. Nope. Unless someone has already replaced a lot of stuff like control cables, pulleys, control surface hinges and many other things, these will all be pretty old. Pulley bearings seize with age and corrosion. Cable corrode and the wires in them break, causing fraying where they run over pulleys, even if the angle change is very small. Any moisture that's gotten into the airframe, even condensation, causes corrosion and many good-looking airplanes have been junked because they were eaten out from the inside. Any animals that nested in it will have done terrible damage. 172 stabilizer spars crack, usually because people push the tail down to turn the airplane. A 1950s 172 has had 50 years to get to this state, and if it's been outside with the wind working the controls a bit, there'll be a lot of wear. The Continental engines need lots of care where the valves are concerned. The old wheels on '50s airplanes are almost impossible to find parts for, as is the rest of an airplane that old. Cessna doesn't stock or make parts fo.r their old models. Univair has a few of the more popular bits. If it was so cheap to run old airplanes, they'd be much in demand. But, like old cars, they often end up costing more than it would have cost to buy something much newer in the first place. Dan (aircraft maintenance engineer) |
On May 6, 8:09*pm, wrote:
On Mar 26, 6:18*pm, wrote: *The older 172's with manual flaps and simple basic electronics are pretty low maintenance. Nope. Unless someone has already replaced a lot of stuff like control cables, pulleys, control surface hinges and many other things, these will all be pretty old. Pulley bearings seize with age and corrosion. Cable corrode and the wires in them break, causing fraying where they run over pulleys, even if the angle change is very small. Any moisture that's gotten into the airframe, even condensation, causes corrosion and many good-looking airplanes have been junked because they were eaten out from the inside. Any animals that nested in it will have done terrible damage. 172 stabilizer spars crack, usually because people push the tail down to turn the airplane. A 1950s 172 has had 50 years to get to this state, and if it's been outside with the wind working the controls a bit, there'll be a lot of wear. The Continental engines need lots of care where the valves are concerned. * * * The old wheels on '50s airplanes are almost impossible to find parts for, as is the rest of an airplane that old. Cessna doesn't stock or make parts fo.r their old models. Univair has a few of the more popular bits. * * * If it was so cheap to run old airplanes, they'd be much in demand. But, like old cars, they often end up costing more than it would have cost to buy something much newer in the first place. Dan (aircraft maintenance engineer) I should add: Old electrical systems also cause considerable trouble. Age means corrosion, especially if there's moisture, and dust contributes further to problems. So we see failing switches and breakers and fuseholders and solenoids because their internal contacts develop oxides on them, causing resistance and heating and eventual burnout. Those old master switches on 172s are in a stupid spot, high in the panel and hard to get at, and they start to fail, too. Voltage regulators quit, and the generators have a rather short brush life and don't produce much juice. If the airplane has less-than-modern avionics, the tuning switches in them suffer the same oxidation and are forever costing money to get fixed. Battery cables and many other wires have crimped-on connectors that develop corrosion between the wire and terminal, and cause symptoms that can take a long time to diagnose. Old airframes develop corrosion-related resistance at riveted joints and we get ground-loop noise in radios and headsets. Lots of expensive fun, and many mechanics aren't really up to speed at finding the problems. Electrical stuff is a field all its own and a guy can spend a lot of time studying it. Most mechanics don't get nearly enough training in it. I restored a 1951 International Harvester half-ton pickup. Daily driver, not a show truck. As simple as a vehicle can get. No electronics, no complicated stuff. I drive it less than half the miles we put on our 2001 car, yet I spend much more time fixing stuff on the truck than I do on the car. We can gripe that "they don't build things like they used to," but it's a good thing they don't. Dan Dan |
| Thread Tools | |
| Display Modes | |
| CHEAP Los Angeles C-172 Flying Club CHEAP | [email protected] | Aviation Marketplace | 7 | May 7th 09 04:32 PM |
| CHEAP Los Angeles C-172 Flying Club CHEAP | Sunho | Owning | 2 | May 7th 09 01:13 AM |
| CHEAP Los Angeles C-172 Flying Club CHEAP | xyzzy | Owning | 0 | April 6th 09 04:31 PM |
| CHEAP L. A. Area Flying Club C-172 | [email protected] | Owning | 4 | April 5th 09 04:22 PM |
| Flying on the Cheap - Again | [email protected] | Home Built | 9 | January 23rd 05 05:25 PM |
