![]() I pulled the seat pan in my Ventus 2 for the first time to find the relief tube housing to be a 10 inch long sharp ended aluminum tube epoxied to the bottom of the fuselage. Needless to say if you have one of these in your glider I encourage you to get rid of it ASAP. I would hate to see what this would do in a hard landing. I cut mine off a few inches off the bottom and installed a flexible vinyl tube to replace the aluminum one. Not sure where this one was installed, but I believe when the glider was in the UK. http://picasaweb.google.com/TTaylor0...14503738989554 |
You are more likely to kill yourself by leaving tools in the bottom of your
glider. At 04:19 18 June 2009, Tim Taylor wrote: I pulled the seat pan in my Ventus 2 for the first time to find the relief tube housing to be a 10 inch long sharp ended aluminum tube epoxied to the bottom of the fuselage. Needless to say if you have one of these in your glider I encourage you to get rid of it ASAP. I would hate to see what this would do in a hard landing. I cut mine off a few inches off the bottom and installed a flexible vinyl tube to replace the aluminum one. Not sure where this one was installed, but I believe when the glider was in the UK. http://picasaweb.google.com/TTaylor0...14503738989554 |
On Jun 18, 2:45*am, Jim White wrote:
You are more likely to kill yourself by leaving tools in the bottom of your glider. We had a guy here in the states that was likewise unlikely to get killed (in part) by the aluminum instrument panel on his spiffy new German glider. Given the chance, it's smart to remove potentially lethal objects from the cockpit area. Good catch, Tim. -Evan Ludeman / T8 |
Look at the pipe cutter in the picture. No one in their right mind uses the
hull of their glider to place tools that they are using or have used. Sure way to have a 'loose article' accident. Judging by the picture the tube would appear to have been sensibly fitted forward of the stick, between the pilots knees. I don't know about you but I find it hard to fly my glider when sitting in front of the stick let alone land it. Jim At 12:16 18 June 2009, T8 wrote: On Jun 18, 2:45=A0am, Jim White wrote: You are more likely to kill yourself by leaving tools in the bottom of yo= ur glider. We had a guy here in the states that was likewise unlikely to get killed (in part) by the aluminum instrument panel on his spiffy new German glider. Given the chance, it's smart to remove potentially lethal objects from the cockpit area. Good catch, Tim. -Evan Ludeman / T8 |
On Jun 18, 5:45*am, Jim White wrote:
Look at the pipe cutter in the picture. No one in their right mind uses the hull of their glider to place tools that they are using or have used. Sure way to have a 'loose article' accident. I've been on on enough aircraft manufacturing lines to know it's quite normal to take tools into the hull and put them down when they are not being used. What makes a glider so special that the same practices cannot be followed. The important thing is to ensure that all tools are removed when the job is completed. That can be done by inventory and/or by careful inspection before closing. Andy |
At 14:16 18 June 2009, Andy wrote:
Remember Apollo 13? Or the AF Concorde that had tools left in the fuel tank? Better not to leave them there at all. Jim I've been on on enough aircraft manufacturing lines to know it's quite normal to take tools into the hull and put them down when they are not being used. What makes a glider so special that the same practices cannot be followed. The important thing is to ensure that all tools are removed when the job is completed. That can be done by inventory and/or by careful inspection before closing. Andy |
Look at the pipe cutter in the picture. No one in their right mind uses the hull of their glider to place tools that they are using or have used. Sure way to have a 'loose article' accident. Judging by the picture the tube would appear to have been sensibly fitted forward of the stick, between the pilots knees. I don't know about you but I find it hard to fly my glider when sitting in front of the stick let alone land it. Jim I'm not 100% familiar with the V2 innards, but it seems to me that the photo was taken looking forward and that the relief tube was fitted aft of the stick. I also can't tell whether it was an aftermarket job or done at the factory. It looks like one of those "pipe-within-a- pipe" deals that allows you to extend a rigid relief tube down into the airstream far enough that your pee doesn't get all over the tail boom, though the inner pipe wouldn't be depicted in this picture if that's the design. If that was the intent, making the outer tube flexible could make it hard to make the inner tube slide and peeing directly into the outer tube that ends flush with the outside fuselage shell might lead to having pee stream down the underside of the glider. It's hard to tell from the picture, but that's what it looked like. In any case installing a spear pointed up into the cockpit seems like a good way to put your eye out, though the geometry of that coming to pass would mean you'd have a whole lot of other things really badly mangled already. Maybe I'm not in my right mind, but the area under my seat pan is flat, smooth an concave, so I generally put most of my tools, screws, etc there then inspect that I take them all out before putting the pan back in. Putting parts and tools on the ground is begging to lose them or kick them around - but I don't generally have a nice shop to work in so dirt and wind and such are bigger concerns for me, On my glider you'd have to crack the seat pan to get it back in place on top of something as big as a pipe cutter. Tim, maybe you can explain the photo a tad more. And please confirm for everyone that you have located the pipe cutter so we can stop worrying. :-) 9B |
On Jun 18, 10:42*am, Andy wrote:
On Jun 18, 5:45*am, Jim White wrote: Look at the pipe cutter in the picture. No one in their right mind uses the hull of their glider to place tools that they are using or have used. Sure way to have a 'loose article' accident. Judging by the picture the tube would appear to have been sensibly fitted forward of the stick, between the pilots knees. I don't know about you but I find it hard to fly my glider when sitting in front of the stick let alone land it. Jim I'm not 100% familiar with the V2 innards, but it seems to me that the photo was taken looking forward and that the relief tube was fitted aft of the stick. I also can't tell whether it was an aftermarket job or done at the factory. *It looks like one of those "pipe-within-a- pipe" deals that allows you to extend a rigid relief tube down into the airstream far enough that your pee doesn't get all over the tail boom, though the inner pipe wouldn't be depicted in this picture if that's the design. *If that was the intent, making the outer tube flexible could make it hard to make the inner tube slide and peeing directly into the outer tube that ends flush with the outside fuselage shell might lead to having pee stream down the underside of the glider. *It's hard to tell from the picture, but that's what it looked like. *In any case installing a spear pointed up into the cockpit seems like a good way to put your eye out, though the geometry of that coming to pass would mean you'd have a whole lot of other things really badly mangled already. Maybe I'm not in my right mind, but the area under my seat pan is flat, smooth an concave, so I generally put most of my tools, screws, etc there then inspect that I take them all out before putting the pan back in. Putting parts and tools on the ground is begging to lose them or kick them around - but I don't generally have a nice shop to work in so dirt and wind and such are bigger concerns for me, On my glider you'd have to crack the seat pan to get it back in place on top of something as big as a pipe cutter. Tim, maybe you can explain the photo a tad more. *And please confirm for everyone that you have located the pipe cutter so we can stop worrying. *:-) 9B Thanks Andy, Yes the picture is taken from the back looking forward. I wasn't too worried about putting my eye out, but if the seat pan collapsed there would be major damage to many other body parts. I decided I would not want to compound the damage from an accident with a spear between my legs. All tools were accounted for and the entire fuselage was vacuumed out before reassembly. The vinyl tubing I added is rigid enough to act as a guide of the relief tube to run through without any issues. If it proved to be too flexible in the long run it will be easy to add some PVC tubing with a flexible vinyl or rubber junction so it will bend in the event of an accident. TT |
On 18 June, 13:45, Jim White wrote:
Look at the pipe cutter in the picture. No one in their right mind uses the hull of their glider to place tools that they are using or have used. Sure way to have a 'loose article' accident. The trick is to "take them out again". Ian |
On Jun 18, 11:01*am, Ian wrote:
The trick is to "take them out again". Yup, that's always worked for me as well. |
The Relief Band for Nausea Relief | jodom | Soaring | 28 | December 29th 07 09:50 PM |
Oshkosh Housing??? | RST Engineering | Piloting | 42 | May 8th 07 01:57 PM |
Oshkosh Housing??? | RST Engineering | Home Built | 41 | May 8th 07 01:57 PM |
Housing available for EAA 2005 | Jen | Instrument Flight Rules | 1 | July 11th 05 06:00 PM |
Oil screen housing for O-320 | mike regish | Piloting | 0 | June 22nd 04 10:52 PM |
