I'm having trouble finding someone simultaneously capable as well as
willing to make a cable for my brake assembly for my ship. Spruce doesn't have any barrel adjusters, a common motorcycle part.... I want the fancy swaged eyelet ends on a 3/32 cable (Spruce also only offers .078 cable or I would probably just send them my own barrel...), but need the barrel on it too. I've found people that *could* do it, but won't touch it cause it's an airplane (I may have them make a cable for my 'gold sluicing machine' or something though ![]() I'm looking for someone to just make it for me. Suggestions? TIA, -Paul |
On Jun 21, 11:51*am, sisu1a wrote:
I'm having trouble finding someone simultaneously capable as well as willing to make a cable for my brake assembly for my ship. Spruce doesn't have any barrel adjusters, a common motorcycle part.... *I want the fancy swaged eyelet ends on a 3/32 cable (Spruce also only offers .078 cable or I would probably just send them my own barrel...), but need the barrel on it too. I've found people that *could* do it, but won't touch it cause it's an airplane (I may have them make a cable for my 'gold sluicing machine' or something though ![]() I'm looking for someone to just make it for me. Suggestions? TIA, -Paul The rotary swage equipment is very expensive and wouldn't expect to find it outside of a large repair station. Unless it is a friend I would tell them its for an aircraft as that will scare just scare off just about everyone. Another suggestion is to silver solder the end on the cable. As long as there is no in use flex in the section near the fitting it works well. I have used that method for a long time with zero failures. |
On Jun 21, 12:43*pm, RAS wrote:
On Jun 21, 11:51*am, sisu1a wrote: I'm having trouble finding someone simultaneously capable as well as willing to make a cable for my brake assembly for my ship. Spruce doesn't have any barrel adjusters, a common motorcycle part.... *I want the fancy swaged eyelet ends on a 3/32 cable (Spruce also only offers .078 cable or I would probably just send them my own barrel...), but need the barrel on it too. I've found people that *could* do it, but won't touch it cause it's an airplane (I may have them make a cable for my 'gold sluicing machine' or something though ![]() I'm looking for someone to just make it for me. Suggestions? TIA, -Paul The rotary swage equipment is very expensive and wouldn't expect to find it outside of a large repair station. Unless it is a friend I would tell them its for an aircraft as that will scare just scare off just about everyone. Another suggestion is to silver solder the end on the cable. As long as there is no in use flex in the section near the fitting it works well. I have used that method for a long time with zero failures. Try a sailboat shop that does rigging. Also look in EAA mag. for someone that does fling wires and such for By-planes. |
On Jun 21, 11:51*am, sisu1a wrote: I'm having trouble finding someone simultaneously capable as well as willing to make a cable for my brake assembly for my ship. Spruce doesn't have any barrel adjusters, a common motorcycle part.... *I want the fancy swaged eyelet ends on a 3/32 cable (Spruce also only offers .078 cable or I would probably just send them my own barrel...), but need the barrel on it too. I've found people that *could* do it, but won't touch it cause it's an airplane (I may have them make a cable for my 'gold sluicing machine' or something though ![]() I'm looking for someone to just make it for me. Suggestions? TIA, -Paul The rotary swage equipment is very expensive and wouldn't expect to find it outside of a large repair station. Unless it is a friend I would tell them its for an aircraft as that will scare just scare off just about everyone. Another suggestion is to silver solder the end on the cable. As long as there is no in use flex in the section near the fitting it works well. I have used that method for a long time with zero failures. Paul, If there are any 'Old School' motorcycle repair businesses in your area, try them. For many years, I used to make all my own cables using parts from: http://www.flandersco.com/FlanCableSearch.html Sometime in the last couple decades, I loaned my solder pot to someone, and it never came back, and I subsequently got rid of most of my bits and pieces. |
Paul,
I've made several cables for my sailplanes. The "Bowden" cable is a bicycle or motorcycle cable. Invented by Mr Bowden of the Raleigh Bicycle Co. around 1900. You can get cable anchor bolts to fix the ends or silver braze the end on with hard silver solder with a propane torch. Go to a bicycle shop or motorcycle shop, get a brake cable and casing with one end that will work on your sailplane. Buy the best brake cable (do not use gear cable) housing with plastic lining and a die drawn wire (real smooth). It looks like flanders cable has all you need. if you cannot find it locally. Be sure to lube the cable with a cable lube found at bicycle shops when you install it I use a 50% silver brazing material with silflux for flux. found at welding shops. Make sure the fitting and wire is free of any oil or dirt before brazing. Also like was said, the silver will run up the cable and make it very stiff near the brazed fitting. The cable will come with 2 ends so, cut the end off you don't need and use the other end where you need the most flex. A new cable will improve the power of your brakes. Test your job by squeezing the lever real hard to see if the end will come off. After testing, you may need to turn the adjusting barrel to tighten the brakes. Watch out, on the first landing because the brakes may be more powerful than before. Ed Gaddy Cycle Logic |
When soldering a cable stop onto a wire, it is good practice to countersink
the end of the cable stop. That way you can flare the end of the cable wire (untwist and bend ends outward) before soldering. This soldered flare will add strength to the cable stop, preventing it from pulling through. After soldering, trim ends of wire with side cutters or Dremel tool. bumper MKIV yaw string and Quiet Vent zz Minden |
I have the small Screw Clamp for brake cable used by many gliders....
this is a small barrel threaded in one end with a small bolt that tightened onto the cable these come to me direct from TOST tim Please visit the Wings & Wheels website at www.wingsandwheels.com "sisu1a" wrote in message ... I'm having trouble finding someone simultaneously capable as well as willing to make a cable for my brake assembly for my ship. Spruce doesn't have any barrel adjusters, a common motorcycle part.... I want the fancy swaged eyelet ends on a 3/32 cable (Spruce also only offers .078 cable or I would probably just send them my own barrel...), but need the barrel on it too. I've found people that *could* do it, but won't touch it cause it's an airplane (I may have them make a cable for my 'gold sluicing machine' or something though ![]() I'm looking for someone to just make it for me. Suggestions? TIA, -Paul |
I'm having trouble finding someone simultaneously capable as well as willing to make a cable for my brake assembly for my ship. Spruce doesn't have any barrel adjusters, a common motorcycle part.... *I want the fancy swaged eyelet ends on a 3/32 cable (Spruce also only offers .078 cable or I would probably just send them my own barrel...), but need the barrel on it too. I've found people that *could* do it, but won't touch it cause it's an airplane (I may have them make a cable for my 'gold sluicing machine' or something though ![]() I'm looking for someone to just make it for me. Suggestions? TIA, -Paul Thanks All, for the suggestions and tips, it's all very useful and appreciated information. Despite all the good advice though, I'm having California Push-Pull make my cables (I'm getting 2 made, one for another owner doing the same conversion...), as it's hard to beat $30/cable with 3 days lead time for rotary swaged milspec plug-n-play action. http://www.push-pull.com/ (I ordered it as 'don't ask don't tell' this time... I'm not sure if they want to get into aircraft- but they did have the MS02668-3 eyelet ends my brake system needs as well as other high quality parts to make the entire cable to my specs... 7x7 wire, plastic lined conduit, the right size/type barrel adjuster etc...) A local wire rigging shop turned me on to them, but I thought others here may be able to benefit from this capable and friendly outlet. This is for a brake conversion BTW, not a repair or replacement, as my SZD-59's wheel/brake arrangement (and any other ship with the same wheel/brake system) is wholly inadequate. This is not due to the ship coming with a cheap/weak/stretchy under-engineered bicycle cable as some ships suffer from, but rather from a terribly designed mechanically actuated floating axle drum/disc/frankenstien proprietary brake design only found on many Polish ships, which is notorious for 1. not working 2. for self actuating under certain circumstances 3, for not being able to be adjusted right (two adjustments possible: 'annual mode' or flying mode...) 4. for getting stuck while engaged and scraping the nose/slamming the tail etc, all leading to a whole host of predictable problems It is hard to describe the anatomy of the brake due to it's unconventional nature, (I can email pics w/descriptions to anyone interested if you PM me...) but suffice to say it SUCKS. Any owner of such a ship (or anyone that has flown one...) will no doubt wholeheartedly agree. One such owner just described a laborious process he underwent involving rebuilding his stock system and using lapping compound to polish the threads that the very odd, 6 point actuating cam mechanism rides in (one of many major sources of avoidable friction in the circuit...) and some other tedious mods to 'bring it up to the level of horrible'. My solution is a complete conversion to a 5.00x5 Cleveland (I heart 5606!) disc and the installation of the related hydraulic parts. I decided to use my ship's stock brake lever (instead of using the trombone action of the airbrake travel or an aftermarket lever solution...), so one of the things I had to do was to design a bracket for the M aster C ylinder that turned my stock 1" of cable travel into 1.25" of piston travel, reducing the overall mechanical advantage of the system from 3:1 down to 2.4 to 1 in the process. This necessitated the actuation lever on the bracket to be longer than I wanted it in order to avoid mechanical interference while accommodating the cable pulling from slightly below the MC attach point on the lever, so I used the smallest eyelet available on the cable to minimize that length (I didn't want the pull be too far from centerline either... avoidable friction is the enemy!) . I went with the MS02668-3 eyelet as it's as small as I could find for a 3/32 cable (the minimum size cable I'm willing to use...) and hence minimized the extra length needed on that lever. MC pivot point is on a 1.6" radius on the lever and the cable pulls from a 1.28" radius measured from the same bottom pivot point to achieve the mechanical 'disadvantage' needed in minimal space. If this was able to be done using a ball or button stop this would have been relatively easy, as there are many options for those type of terminations (I live in Oakland with numerous shops nearby, and/or would be feasible to make myself.), but my conundrum came from needing motorcycle parts (M8-1.25 barrel adjuster w/2 nuts) on the same assembly as the milspec eyelets... all the sudden the list of capable shops got much smaller, and willing shops smaller yet. The overall conversion is almost done though, and I very much look forward to flying my ship again, especially with a brake that actually works! I still won't point at anything I don't want to buy- but still... Once completed I will set up a site documenting my process from beginning to end, with pictures and descriptions of the step-by- step for the conversion in addition to making the drawings/dimensions of the parts that need to be machined available in case anyone else is as fed up as I was with what is clearly the Achilles' heel of such a fine ship and they need some inspiration. -Paul PS. I absolutely love my Polish glider, I just hate it's wretched wheel/brake arrangement... (well, and the inadequate ventilation, but that problem is already solved ![]() |
MiG-29 cables | alcatraz | Military Aviation | 0 | March 1st 04 10:01 PM |
FS:Custom molded in ear monitors | Andre | Piloting | 4 | January 8th 04 01:37 PM |
FS: Custom molded in ear moniotrs | Andre | Rotorcraft | 0 | January 7th 04 01:39 AM |
FS: Custom molded in ear monitors | Andre | Products | 0 | January 7th 04 01:39 AM |
Custom Planes type? | Corrie | Home Built | 0 | October 19th 03 07:14 AM |
