iPAQ 310 serial
Old July 28th 09, 03:56 AM posted to rec.aviation.soaring
John Orton[_3_]
Default iPAQ 310 serial
Hi
Does anyone have any info on what serial port is connected to the USB on an
iPAQ 310/312.
I am trying to help setup one with XCsoar and feed in Flarm data as well. I
have the Flarm data at the correct voltage levels but I can't work out what
serial port the iPAQ thinks is there.
John
johnorto at gmail.com
Old July 28th 09, 07:47 AM posted to rec.aviation.soaring
Darryl Ramm
On Jul 27, 7:56*pm, "John Orton" wrote:
Hi
iPAQ 310/312.
John
Ah a trick question? The iPAQ 310 does not have a serial port. It is
USB only device.
You will likely want to use a serial over bluetooth connection to feed
it data. Many pilots are using the K6-Bt bluetooth adapter with the
310.
Darryl
Old July 28th 09, 09:15 AM posted to rec.aviation.soaring
Alastair Mutch
At 06:47 28 July 2009, Darryl Ramm wrote:
On Jul 27, 7:56=A0pm, "John Orton" wrote:
Hi
on
an iPAQ 310/312.
Ah a trick question? The iPAQ 310 does not have a serial port. It is USB
only device.
No it isn't. It has a serial port on the same connector as the USB port
although the voltage levels are lower than "normal" and need a level
convertor.
Paul Remde at Cumulus has cables for use with the serial port (rather than
using Bluetooth). These work fine for my installation.
Alastair
Old July 28th 09, 11:18 AM posted to rec.aviation.soaring
Andrej Kolar[_3_]
Com 3, but it doesn't work at 4800bps. Wiring is he
http://tr.im/unts
Old July 28th 09, 12:28 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Like everyone else, we were told that the iPAQ 310 did not have a serial
port. But then someone found a double-secret serial port on the USB
connector. The hardware is there. It took us a long time to get it to work
though because it has some idiosyncrasies. It requires an inline RS-232
voltage level converter and it works only at 9600 baud or higher. . That
is a bummer because it therefore doesn't work with a Cambridge 302 or LX
Colibri. But it does work with EW microRecorders and LX products that work
at 9600 or 19200 baud. Below are link to 2 new cables for use with the 310.
I have them in stock.
http://www.cumulus-soaring.com/goddard.htm#I310-PS5a-1
http://www.cumulus-soaring.com/godda...#I310-LX1600-1
I also have a new cable for use with the Bendix King AV8OR. I have tested
it with the standard (smaller) AV8OR, but not the new large AV8OR. The good
news is the AV8OR works at 4800 baud and has the brightest display I have
seen in a PDA/PNA.
http://www.cumulus-soaring.com/goddard.htm#AV8OR-PS5a-1
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Darryl Ramm" wrote in message
On Jul 27, 7:56 pm, "John Orton" wrote:
Hi
an
iPAQ 310/312.
I
what
John
USB only device.
310.
Darryl
Old July 28th 09, 01:57 PM posted to rec.aviation.soaring
John Orton[_4_]
On Jul 28, 7:28*pm, "Paul Remde" wrote:
Hi,
port. *But then someone found a double-secret serial port on the USB
connector. *The hardware is there. *It took us a long time to get it to work
though because it has some idiosyncrasies. *It requires an inline RS-232
voltage level converter and it works only at 9600 baud or higher. *. *That
Colibri. *But it does work with EW microRecorders and LX products that work
at 9600 or 19200 baud. *Below are link to 2 new cables for use with the 310.
I also have a new cable for use with the Bendix King AV8OR. *I have tested
it with the standard (smaller) AV8OR, but not the new large AV8OR. *The good
seen in a PDA/PNA.
Best Regards,
Paul Remde
Hi
an
iPAQ 310/312.
I
what
John
USB only device.
310.
Darryl
Thanks guys particularly Paul and Andrej.
Old August 3rd 09, 08:42 AM posted to rec.aviation.soaring
Al[_7_]
Hi,
http://www.cumulus-soaring.com/godda...ttp://www.cumu...
seen in a PDA/PNA.
Best Regards,
Paul Remde
Hi
an
iPAQ 310/312.
I
what
John
USB only device.
310.
Darryl
Anyone played with these?
http://www.aircable.net/support-serial3.html
Old August 3rd 09, 10:30 AM posted to rec.aviation.soaring
Jim White[_3_]
Yes. I have an Aircable Mini and was able to make it pair and talk
successfully to the HP310/314 from my PC GPS simulator.
Unfortunately when I hooked it up in the glider to my LX160 it would not
talk to that properly so the HP got gobbledegook.
Have put it on the back burner as a winter project.
BTW I am very interested in the serial port stuff as this would definately
be a better way to go for a permanent installation.
Can anyone point me at a document that describes the port, specifications,
and / or functionality?
tx
FlashFXP PRO 3.7 + serial - FlashFXPPRO3.7.rar [1/1] Peter Brady Aviation Photos 0 July 17th 09 06:16 PM
USB to Serial Converter RN Soaring 12 March 16th 08 12:21 AM
GTX 327 serial input? weebee Owning 1 December 19th 05 01:04 AM
How get get serial number of GNS-430? Andrew Gideon Owning 15 September 26th 05 11:49 PM
How get get serial number of GNS-430? Andrew Gideon Products 15 September 26th 05 11:49 PM
