Yet another PA-28 wingtip query...
Old August 3rd 09, 12:52 AM posted to rec.aviation.owning
Mike Spera
Default Yet another PA-28 wingtip query...
We've got some Madra droop-tips on our straight-wing -180. Although we've
enjoyed their
performance (good slow-flight characteristics, unchanged cruise/top
speed), my partner on the plane can't
stand the looks. So, we're looking to put Hoerner-style ones on. As far
as I can tell, there are at
least 6 different manufacturers/varieties:
..stuff snipped
I flew our 74 140 for a couple of years and a couple of hundred hours before
I put on the Met-co's. If there was a difference, I could not tell. My main
reason for the switch was cosmetic. The old stock tips were pretty crazed up
and flimsy.
I believe the weights sticking out or not is determined by what year your
plane is and not the tip design. Mine don't stick out but some of the 60's
Cherokees on the ramp do - stock tips or Hoerner style. I have also seen
several with the landing lights. Every one of the lenses is in some state of
cloudiness. How much do you REALLY fly at night? What can't you do with the
stock landing light? Maybe spot the deer you will hit anyway 3 seconds
earlier? Our instructor had us land quite a few times at night without the
light to show us there was nothing magical about the light (and stress that
they DO go out pretty often).
These things come without mounting holes so you have to make them. I used
the "masking tape trick" and it worked pretty well. Took about 2 hours once
the old ones were off and any bunged up speed nuts were replaced. Getting
the old tips off can be a real pain if lots of the hardware is rusted
together. Since you already have replacement tips you may not have such a
hard time getting them off IF the installer did not go gorilla on the
screws.
I paid about $500 for the set back in '97. I installed them and my wrench
signed them off. At today's price with mechanic you are probably looking at
$1000 or so. YIKES!
Good Luck,
Mike
Old August 3rd 09, 03:32 PM posted to rec.aviation.owning
Stealth Pilot[_2_]
On Sun, 2 Aug 2009 18:52:35 -0500, "Mike Spera"
enjoyed their
.stuff snipped
and flimsy.
mike
the old stock tips can be restored pretty easily.
the ones I restored are still pretty schmik some 9 years later.
you sand off all the outer paint and filler back to the glass base.
then you lay up two layers of lightweight glass cloth using epoxy.
do it neatly. allow to cure.
sand it off until any raised bits are removed, ie so that it is
smoothish but you can still see the weave.
leave the outside for the moment.
sand the inside back to the glass and lay up 1 or 2 layers of fine
glass cloth. allow to cure
back to the outside and you mix up a paste of epoxy and talcum powder
or other fine filler. screed this on with a spatula to fill the weave.
allow to cure then sand back until smooth.
prep and paint the tip.
there is no need to throw away old tips.
the technique also works on mushy crazed nosebowls. just degrease them
as the first step.
Stealth Pilot
Old August 4th 09, 03:07 AM posted to rec.aviation.owning
Mike Spera
No worries. Old tips were "recycled" to local FBO airplane. I know the
fiberglass drill. I repaired Corvettes in the 60s and 70s (Man, am I gettin'
old!). I just like the looks of the Hoerner style. The old rounded tips made
the plane look "old" to me.
Thanks for the procedure.
Mike
we've
enjoyed their
far
.stuff snipped
before
main
up
and flimsy.
mike
as the first step.
Stealth Pilot
Wingtip Camera NG[_2_] Soaring 14 April 9th 09 11:38 PM
Wingtip Camera kestrel19 Soaring 0 April 9th 09 04:02 PM
[10/13] - 11 Port Wingtip.JPG (1/1) Part 2 Waldo.Pepper[_2_] Aviation Photos 0 September 10th 08 11:23 PM
L-23 wingtip wheel modification 5Z Soaring 0 February 8th 06 05:50 PM
Visible wingtip vortex! Bill Piloting 23 October 25th 05 10:37 PM
