Glider Towplane Mid-air – TP PowerFLARM Inop
Old February 14th 20, 01:42 AM posted to rec.aviation.soaring
George Haeh
Default _Glider_Towplane_Mid-air_–_TP_PowerFLARM_Inop
I heard that the C-182 had cylinder problems; possibly delaying the descent after release was being done to avoid shock cooling.
  #42
Old February 14th 20, 01:43 AM posted to rec.aviation.soaring
Jonathan St. Cloud
On Thursday, February 13, 2020 at 8:15:06 AM UTC-8, jfitch wrote:
On Wednesday, February 12, 2020 at 8:41:55 AM UTC-8, Dan Marotta wrote:
Point taken, but a soft release is never a good thing from the tow
pilot's perspective.Â* When flying my glider I seldom released softly but
I always announced, "5J's off, thanks!"
On 2/11/2020 9:46 PM, 2G wrote:
On Tuesday, February 11, 2020 at 10:53:29 AM UTC-8, Dan Marotta wrote:
When I was towing, I would visually confirm that the glider was off and
then roll steeply and dive.Â* If I hadn't felt the glider get off, I
would fly straight and level for a bit to assure clearance before
beginning a more moderate descent.Â* I also maintained awareness of any
gliders that had not climbed away.
I would blame both of the pilots in this accident but would assign most
of the blame to the tow pilot.Â* Making what amounts to a level turn just
after release is asking for trouble.
On 2/11/2020 8:51 AM, Waveguru wrote:
This seems to happen every few years, where the tow plane makes a left turn and the glider make a right and they come around and collide. I changed the way we do it here so that the glider only makes a slight right turn, and then keeps his eye on the tow plane, so that at least one of the pair of planes can more easily maintain separation. When both planes make a 360° turn, neither of them can see the other. This kind of accident is the result.
Boggs
Dan, 5J
You can't hardly blame the glider pilot: they were flying straight ahead and were struck from behind. The tow pilot is clearly the one at fault.
Tom
Dan, 5J
There's been mention of people trained to announce the release on the radio. Should not this be in the SOPs of the operation? It is wherever I fly - glider is ALWAYS to announce release, tow plane acknowledges. If you aren't going to communicate with the aircraft 200 ft away, why have a radio at all?
Just to note, not all operations have radios in the tow planes.
  #43
Old February 14th 20, 02:00 AM posted to rec.aviation.soaring
jfitch
On Thursday, February 13, 2020 at 5:43:47 PM UTC-8, Jonathan St. Cloud wrote:
Boggs
Dan, 5J
  #44
Old February 14th 20, 05:17 PM posted to rec.aviation.soaring
Dan Marotta
Here we go again with "shock cooling" as an excuse.
Dan, 5J
PowerFLARM Core or LXNAV PowerMouse Installation in Towplane Paul Remde Soaring 1 October 2nd 19 04:58 PM
Powerflarm in towplane anecdotal experiences son_of_flubber Soaring 0 July 29th 19 04:30 PM
Cirrus collides with Glider/Towplane Jody Soaring 9 February 7th 10 03:14 AM
towplane collides with glider, prop hits wingtip [email protected] Soaring 21 September 1st 09 07:24 PM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
