To lift a title from The Bard and, since there's not much else going on
these days, and to give homage to Roseanne Roseannadana... What's all this nonsense I keep hearing about CG hooks? My first glider had a nose hook and it was easy to control on launch and tow.Â* All the rest had CG hooks (only) and I never noticed a difference either on take off or tow.Â* The only advantage I ever noticed about either was on ground launch where the nose hook was at a distinct disadvantage. So, for me at least, a CG hook would be a must for any non-self-launch glider.Â* I think that those who make a big bugaboo about CG hooks are doing a disservice to gliding. Let the games begin... -- Dan, 5J |
"I never noticed a difference either on take off or tow."
I don't agree, CG is more pleasing to fly on tow. Since there is little torque on the glider from the cable, a CG hook provides more options for holding position. The CG hook is also quite stable (as in stick won't help) in a nose high, cable low, elevator stalled configuration. Which is fine unless you happen to be tied a tow plane also with a stalled elevator at the time. This is extremely unlikely to happen if the glider pilot understands the possibility and proactively doesn't go there. Sadly, we sometimes don't include this possibility in training and so it does happen. Game on |
On Saturday, March 28, 2020 at 12:16:05 PM UTC-4, wrote:
"I never noticed a difference either on take off or tow." I don't agree, CG is more pleasing to fly on tow. Since there is little torque on the glider from the cable, a CG hook provides more options for holding position. The CG hook is also quite stable (as in stick won't help) in a nose high, cable low, elevator stalled configuration. Which is fine unless you happen to be tied a tow plane also with a stalled elevator at the time. This is extremely unlikely to happen if the glider pilot understands the possibility and proactively doesn't go there. Sadly, we sometimes don't include this possibility in training and so it does happen. Game on It's night time in Australia, guys :-). Nose hook for aero tow is a JAR thing now, and unlikely to change. It's my view that a (well designed and located) nose hook is safest for aero tow. Some CG only gliders are pussycats on tow, have perfect manners. Some nose hook equipped gliders have dangerous pitching tendencies. Inattentive glider pilots have killed tow pilots with both types. 200' tow rope (or longer) and Tost release on both ends is good. Switched on pilots with good training and procedures is best. T8 |
Hmmm.....many years, "a bit of sailplane hours"......a lot of "Mercian iron" (SGS) with nose hooks, about the same hours with CG hooks (mostly AS**** ships)..... all aero tow...frankly, in lots of conditions and suitable training, can't say I have an issue or preference.
Yes, low time training, nose hook can help since it tends to track to towplane tail a little easier. Yes, most of my aerotow hours are low tow (please don't start that argument yet again here....I fly and trained on both...). :-( I have NO winch experience (would LOVE to do Karl's course in PA....if nothing more than to fly with Karl...;-)). |
At 15:28 28 March 2020, Dan Marotta wrote:
To lift a title from The Bard and, since there's not much else going on these days, and to give homage to Roseanne Roseannadana... What's all this nonsense I keep hearing about CG hooks? My first glider had a nose hook and it was easy to control on launch and tow.Â* All the rest had CG hooks (only) and I never noticed a difference either on take off or tow.Â* The only advantage I ever noticed about either was on ground launch where the nose hook was at a distinct disadvantage. So, for me at least, a CG hook would be a must for any non-self- launch glider.Â* I think that those who make a big bugaboo about CG hooks are doing a disservice to gliding. Let the games begin... -- Dan, 5J The issue came up back in the early 1980's when most all high performance gliders only had C/G hooks for drag reduction purposes. A lot of those gliders still had tail skids as well. Stack a bunch of them on a paved runway for a competition and watch out! With any kind of crosswind at all, the gliders didn't have enough rudder authority at low speed to counter impending ground loops with any kind of weathervaning at all. Add a wing drop due to uneven tow plane prop vortices, and we had all sorts of ground loops into other gliders, cars and people on the sidelines. Using dive brakes to kill the lift on both wings on initial take-off roll helped with the wing drop issues, but until tail wheels became the norm, the tail skids would not track well on a hard surface. This lack of tail tracking ability coupled with a C/G release location meant that once a little weathervaning started, there was no way to stop it until you had rudder authority, and a lot of times, that was too late. The nose hook always pulls in front of the C/G to self damp or return the nose towards the centerline, which is extremely helpful until one gets rudder authority. There was way too much excitement on the contest take-off grid until tail wheels and nose hooks came to be the norm, and that's why there is the nose hook preference on newer gliders. RO |
I think Mike/RO has it right. The difference between CG and nose hooks is mostly felt on the ground at the beginning of the roll. If a wing goes down and the tail is not planted down hard, with a CG hook watch out. In the air there is not much difference. I've flown lots of gliders with both style hooks (and used both on aerotow), and never noticed much difference once I got in the air.
ROY |
At 00:11 29 March 2020, Roy B. wrote:
I think Mike/RO has it right. The difference between CG and nose hooks is m= ostly felt on the ground at the beginning of the roll. If a wing goes down = and the tail is not planted down hard, with a CG hook watch out. In the air= there is not much difference. I've flown lots of gliders with both style h= ooks (and used both on aerotow), and never noticed much difference once I g= ot in the air. ROY=20 And to the folks who say that they haven't noticed a difference, I will bet they haven't tried taking off with full water ballast and a 10- 15 Kt crosswind at a high density altitude SW USA desert location in a C/G hook / tail skid equipped glider... Been there, done that, got the T-shirt, and don't care to reinvent the wheel. I, for one have learned from history. Some of the younger folks haven't been around long enough to have seen it for themselves. RO |
RO
I think these days tailskids are as rare as hens teeth. The last one I saw was when the guy who bought my 1958 Ka6CR towed it home in 2000. |
