How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
Old June 9th 20, 07:07 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
On Tuesday, June 9, 2020 at 1:27:45 PM UTC-4, wrote:
A quick way is to only use a TOST ring set where you can still read (most) of the TOST part number stamped on the side of the small ring. With dimension change due to wear&tear, the part number will become unreadable.
This has the dual benefit of also ensuring you are being hooked up with a proper TOST ring set and not a home made or repaired set.
PS- Remind me to take a calipers out to the airfield next visit and validate a suspect worn ring’s dimensions. Thanks, whoever posted the spec dims.
It's on the oval ring on my ring pair... and TOST is stamped at the bottom of it.
Old June 9th 20, 11:09 PM posted to rec.aviation.soaring
While inspecting, look for small (maybe 1/32 inch?) cracks.
That seems to happen before noticeable wear changes.
Old June 9th 20, 11:45 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by Dan Marotta View Post
I was taught that, if unable to release, the glider should circle the
winch rather than slingshot towards the ground.Â* And why wouldn't the
driver cut the cable as soon as the glider overflew the winch and
started down?Â* Training...
On 6/8/2020 5:59 PM, Ventus_a wrote:
he winch driver didn't cut the cable and the winch was getting
destabilised as the glider went through about 45 degress down towards
the ground behind the winch. Going through about 400' with lots of
frantic pulling on the release and the stick the cable finally let go
and the day was saved.. Some badly shaken people and the hook
installation got a good working over to ensure that it couldn't happen
again
Colin
Dan, 5J
Hi Dan
The winch driver was an older gentleman and he bailed out of the winch. I suspect lack of familiarity with the cutting system and a sense of his own vulnerability prevailed. Since then a more robust training system is in place for winch drivers
  #24
Old June 10th 20, 12:53 AM posted to rec.aviation.soaring
AS
Welcome!
Uli
'AS'
  #25
Old June 10th 20, 06:40 PM posted to rec.aviation.soaring
Dan Marotta
Default How reliably do CG hooks disconnect when the angle of theropeexceeds the autorelease angle
Us older guys need to step up our game!
On 6/8/2020 5:59 PM, Ventus_a wrote:-
again
Colin-
Dan, 5J
Hi Dan
Dan, 5J
Aluminum angle Lou Home Built 11 June 25th 07 11:57 PM
Blue Angle #3 Elmshoot Naval Aviation 10 May 24th 04 10:35 PM
Another angle... tongaloa Home Built 0 February 27th 04 11:13 PM
The Dan Rather Angle Dude Owning 7 January 18th 04 09:10 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
