Hi Group,
	I've got a 303 and am interested in anyones' opinions about flying it, I've got 40 hrs in a SHK, 30 or so in a standard Cirrus, a few in a grob 103 Thanks, Scott  |
			 I have a few hundred hours in a Mosquito back in the 1980s. It is pretty conventional to fly apart from two unusual characteristics: First is the parallelogram stick action in pitch - not really an issue, you will quickly get used to it. The main issue is the unusual air brakes. The first bit of travel raises the upper trailing edge spoiler producing a little drag increase. The remainder of the travel produces a lot of extra lift and drag so the approach can be very steep, which actually very useful in short landing areas. The main consideration is that you should be very careful of using too much brake too early on the approach. If you are undershooting, reducing airbrake reduces drag but also drastically reduces lift too. If you dump brakes very low on the approach, the first effect is to reduce lift and dump yourself in a worse undershoot position. However rounding out with minimal brake gives a very long float.You should always aim to approach with steadily increasing airbrake, rounding out with maximum brake. If you start to undershoot, reduce airbrake ASAP until you look a bit too high, then steadily increase brake towards max. If you know anyone with a Mini-Nimbus or a Ventus B, the brake system will be similar and they could give you more advice. Good luck with the new ship! Regards Roy Pentecost At 20:09 18 June 2020, Scott Williams wrote: Hi Group, I've got a 303 and am interested in anyones' opinions about flying it, I've got 40 hrs in a SHK, 30 or so in a standard Cirrus, a few in a grob 103 Thanks, Scott  |
You're never too high in a Mosquito - a salute to the terminal velocity
	limiting air brakes.Â* To test the brakes, I once started at a couple thousand feet AGL, opened full brakes and pointed the nose straight down.Â* It did not reach red line.Â* Everything said below is true, too. Enjoy! On 6/18/2020 2:37 PM, Roy Pentecost wrote: I have a few hundred hours in a Mosquito back in the 1980s. It is pretty conventional to fly apart from two unusual characteristics: First is the parallelogram stick action in pitch - not really an issue, you will quickly get used to it. The main issue is the unusual air brakes. The first bit of travel raises the upper trailing edge spoiler producing a little drag increase. The remainder of the travel produces a lot of extra lift and drag so the approach can be very steep, which actually very useful in short landing areas. The main consideration is that you should be very careful of using too much brake too early on the approach. If you are undershooting, reducing airbrake reduces drag but also drastically reduces lift too. If you dump brakes very low on the approach, the first effect is to reduce lift and dump yourself in a worse undershoot position. However rounding out with minimal brake gives a very long float.You should always aim to approach with steadily increasing airbrake, rounding out with maximum brake. If you start to undershoot, reduce airbrake ASAP until you look a bit too high, then steadily increase brake towards max. If you know anyone with a Mini-Nimbus or a Ventus B, the brake system will be similar and they could give you more advice. Good luck with the new ship! Regards Roy Pentecost At 20:09 18 June 2020, Scott Williams wrote: Hi Group, I've got a 303 and am interested in anyones' opinions about flying it, I've got 40 hrs in a SHK, 30 or so in a standard Cirrus, a few in a grob 103 Thanks, Scott -- Dan, 5J  |
On Thursday, June 18, 2020 at 4:09:45 PM UTC-4, Scott Williams wrote:
	Hi Group, I've got a 303 and am interested in anyones' opinions about flying it, I've got 40 hrs in a SHK, 30 or so in a standard Cirrus, a few in a grob 103 Thanks, Scott You should have no problem with the Mosquito, I flew one back in the 80's for quiet a bit. It was a very comfortable ship to fly and the flap configuration is very nice. Enjoy the landings, you will learn to like the ship.  |
On Thursday, June 18, 2020 at 5:47:34 PM UTC-4, Dan Marotta wrote:
	You're never too high in a Mosquito - a salute to the terminal velocity limiting air brakes.Â* To test the brakes, I once started at a couple thousand feet AGL, opened full brakes and pointed the nose straight down.Â* It did not reach red line.Â* Everything said below is true, too. Enjoy! -- Dan, 5J I can only second that! Using the trailing edge dive brakes on my Calif in the 'Oh Jesus!' setting, I can get sink rates of close to 100 ft/sec w/o building speed much over 80mph while standing on the rudder pedals and looking at the houses becoming larger! Great design - I don't miss the SH dive brakes. Uli 'AS'  |
Hi, I have about 200hrs in my Mosquito.
	Sweet handling, powerful brakes, decent performance. Easy to rig, automatic connections, but wing panels are heavy. The best thermalling flap setting is midway between +1 and +2, cut the appropriate slot with a Dremel-type tool. Recommend installing heel brakes rather than the lever brake by control stick. Be aware the canopy latch above pilots head can wear out and effect canopy latching. Any other queries please feel free  |
500 hours   Great ship , modified wheel brake to a grip on the control stick . Great landing capabilities and a tough airframe.
| Thread Tools | |
| Display Modes | |
| de Havilland Mosquito pics 3 [7/9] - Mosquito F Mk II in India circa 1943.jpg (1/1) | Miloch | Aviation Photos | 0 | May 1st 19 05:23 PM |
| de Havilland Mosquito pics 3 [6/9] - Mosquito B Mk IV Series 2, DK338, built in September 1942 and delivered to 105 Squadron.jpg (1/1) | Miloch | Aviation Photos | 0 | May 1st 19 05:22 PM |
| de Havilland Mosquito pics 2 [3/8] - Construction concepts pioneered in the DH.88 Comet were later used in the Mosquito.jpg (1/1) | Miloch | Aviation Photos | 0 | May 1st 19 05:20 PM |
| Metalworking Question for Bruce Frank or anyone else with expertise | David H. Uhrbrock | Home Built | 3 | September 16th 04 04:07 PM |
| Expertise Needed: TU-154 Panel Question | GlaringTruth | Simulators | 1 | October 5th 03 06:54 AM |
