Hi all - does anyone have any experience with cleaning seat belt webbing? I can remove the buckles from the webbing and was wondering if this material can be washed using a mild detergent like Woollite or similar.
Uli 'AS' |
I have washed many skydiving rigs. I use a tub of lukewarm (not hot) water and a little bit of Woolite to wash a harness/container system. Use a soft bristle brush, rinse very well and hang dry in a place where it will dry quickly. Woolite is the standard for jobs like this. This is how every rigger I have known does it.
FWIW, Kyle |
On Thursday, July 9, 2020 at 6:08:57 PM UTC-4, KyleCharles wrote:
I have washed many skydiving rigs. I use a tub of lukewarm (not hot) water and a little bit of Woolite to wash a harness/container system. Use a soft bristle brush, rinse very well and hang dry in a place where it will dry quickly. Woolite is the standard for jobs like this. This is how every rigger I have known does it. FWIW, Kyle Thanks, Kyle! I will try that. Uli 'AS' |
You probably already know this, but just to be on the safe side: Avoid acidic cleaning agents like bleach.
Also be careful to avoid situations that might expose the webbing to battery acid. It's very bad for nylon. As others suggested, I wash my climbing ropes and other nylon soft gear with woolite. Were I to need to wash my seat belt webbing, that's how I'd do it. https://www.cmcpro.com/what-happens-...ts-on-my-rope/ --Bob K. |
https://www.cmcpro.com/what-happens-...ts-on-my-rope/ Interesting web page. They said they ran strength tests after exposure to a nice assortment of stuff. But I don't see the test results? (I do like the design of the rope pull tester though ;-) |
| Seat Belt Re-Webbing | vontresc | Soaring | 4 | March 25th 14 08:16 AM |
| Seat belt clip | Fred[_4_] | Soaring | 2 | June 23rd 08 06:10 PM |
| Seat belt tags | Stephen Stilkey | Owning | 28 | March 15th 04 05:29 PM |
| Seat Belt Extenders | M.E. Borner | Owning | 4 | October 3rd 03 02:55 PM |
| Seat Belt Age? | BD5ER | Home Built | 2 | July 7th 03 01:10 AM |
