On Saturday, July 11, 2020 at 12:02:01 AM UTC+12, wrote:
Is anyone still making eccentric wing pin tools, I have a Nimbus 2 that is a bitch to get the wings in the last 15ml/ half inch even with everything aligned correctly on the marks. With my self built electric wing rigger I can do everything but that last bit. I am making her complete one man system Gary I thank everybody for the suggestions which I will work through as soon as the rain stops and the ground firms up again. My engineer says that my ship has very tight tolerances on all metal components (no wear) which pleases him! She has relatively low hours for her years thus little wear. There are a couple of small areas the flap teflon seal tapes are starting to lift slightly,any suggestions (glues) to extend their life? Gary |
There are a couple of small areas the flap teflon seal tapes are starting to lift slightly,any suggestions (glues) to extend their life? For mylar seals, new transfer and safety tape after cleaning out the old with acetone. Will be interested to see what answer shows up for teflon tapes. |
On Saturday, July 11, 2020 at 8:20:27 PM UTC-7, Tim Taylor wrote:
As always Tom, we are glad you know more than the rest of us. I am sorry I only have 30 years of rigging 4 different SH gliders, including a Nimbus 2, and have found that often lack of cleaning has made a major difference in the ability to get rig them. Alignment is critical, but it it is not going the last few mm it is often cleaning. But again you know everything and we mere beginners must know very little compared to your vast knowledge. Your sarcasm is noted. Well, I have FORTY YEARS rigging a variety of gliders. Note that I said "lubing is not a bad thing" - what part of that did you miss? Go back and reread it. And when the lubing doesn't do the trick, follow the tips I gave (that is meant for the rest of you, Tim is obviously to thick headed to learn). Tom |
There can be other causes for rigging difficulties, e.g., the first time
I helped Tom Bjork rig his ASH-30 mi, we were absolutely unable to get the second main pin inserted.Â* After a long struggle, we removed the second wing inboard panel and found one of those tiny R-clips which are used to secure l'Hotelier fittings on the shelf. That tiny thickness was enough to prevent alignment of the pin bushings. On 7/13/2020 10:16 PM, 2G wrote: On Saturday, July 11, 2020 at 8:20:27 PM UTC-7, Tim Taylor wrote: As always Tom, we are glad you know more than the rest of us. I am sorry I only have 30 years of rigging 4 different SH gliders, including a Nimbus 2, and have found that often lack of cleaning has made a major difference in the ability to get rig them. Alignment is critical, but it it is not going the last few mm it is often cleaning. But again you know everything and we mere beginners must know very little compared to your vast knowledge. Your sarcasm is noted. Well, I have FORTY YEARS rigging a variety of gliders. Note that I said "lubing is not a bad thing" - what part of that did you miss? Go back and reread it. And when the lubing doesn't do the trick, follow the tips I gave (that is meant for the rest of you, Tim is obviously to thick headed to learn). Tom -- Dan, 5J |
A few of us were helping a fellow pilot assemble his brand-new HpH 304 several years ago, and clearances were so tight that it was a real struggle. One British observer said, "Oh just take it out and ground-loop it a few times. It will loosen right up!"
the "bedding in" process recommended by
(some? many? all?) manufacturers of semi-automatic shotguns, who suggest the first 20 rounds or so should be magnum loads...by way of exercising the precision sliding bits under maximum-routine, high-stress, conditions in expectation of achieving the longest/smoothest operating lifetime. Using that theory, a new automobile should be "broken in properly" by winding it up to max RPM and driven as fast as possible directly off the showroom floor until it loosens up. Or breaks. However, I regularly test electronic components this way. If they are going to fail, they are likeliest to do so early in their life. If they succeed in passing a large number of cycles, they will probably last quite a while. We had a batch of relays that failed after a short stress test, but the next batch (probably from another production run) is still going strong a year later. |
On Tuesday, July 14, 2020 at 7:52:02 AM UTC-7, wrote:
the "bedding in" process recommended by (some? many? all?) manufacturers of semi-automatic shotguns, who suggest the first 20 rounds or so should be magnum loads...by way of exercising the precision sliding bits under maximum-routine, high-stress, conditions in expectation of achieving the longest/smoothest operating lifetime. Using that theory, a new automobile should be "broken in properly" by winding it up to max RPM and driven as fast as possible directly off the showroom floor until it loosens up. Or breaks. However, I regularly test electronic components this way. If they are going to fail, they are likeliest to do so early in their life. If they succeed in passing a large number of cycles, they will probably last quite a while. We had a batch of relays that failed after a short stress test, but the next batch (probably from another production run) is still going strong a year later. I take the "Captain Ron" approach. "If it going to break, it is going to break out there." ![]() |
The boat i run usually never breaks at the dock, it breaks at the beginning of a longer trip usually. Murphy was a seaman.
My quote to the crew, "Only new parts and old parts are suspect. The ones in the middle of their service life are fine." |
| Eccentric cam wing assembly tools | [email protected] | Soaring | 20 | November 7th 16 08:15 PM |
| f/s One man wing assembly tool | JJ Sinclair[_2_] | Soaring | 2 | July 31st 15 12:48 AM |
| Tool Tech Wing Wheel - FS - Bringing to Moriarty if interested | WaltWX[_2_] | Soaring | 0 | May 29th 13 10:43 PM |
| FS: Eccentric Assembly Tools | SteveB_Z5 | Soaring | 0 | July 28th 12 12:52 AM |
| FS: Eccentric Assembly Tools | SteveB_Z5 | Soaring | 0 | January 21st 12 06:37 PM |
