Is there a way - an easy way hopefully - to have TFRs display on Google Earth?
On Saturday, September 12, 2020 at 9:13:49 AM UTC-7, jp wrote:
Is there a way - an easy way hopefully - to have TFRs display on Google Earth? Answering my own question: I plotted the corners of the Bobcat TFR on Google Earth and then connected the corners with a red line. Not quick but did the job. |
On Saturday, 12 September 2020 10:36:32 UTC-6, jp wrote:
On Saturday, September 12, 2020 at 9:13:49 AM UTC-7, jp wrote: Is there a way - an easy way hopefully - to have TFRs display on Google Earth? Answering my own question: I plotted the corners of the Bobcat TFR on Google Earth and then connected the corners with a red line. Not quick but did the job. I have used this GE plugin for a number of years with good results http://www.2ld.de/tfr2kml/ |
Is there a way - an easy way hopefully - to have TFRs display on Google Earth? SkyVector (online charts and flight planning website) has TFRs plotted in a timely manner. No user action required. skyvector.com Other formats found he http://soaringdata.info/tfrs/tfrs.php, including .kml for Google Earth. |
On Saturday, September 12, 2020 at 10:28:17 AM UTC-7, GliderCZ wrote:
On Saturday, September 12, 2020 at 9:13:49 AM UTC-7, jp wrote: Is there a way - an easy way hopefully - to have TFRs display on Google Earth? SkyVector (online charts and flight planning website) has TFRs plotted in a timely manner. No user action required. skyvector.com Other formats found he http://soaringdata.info/tfrs/tfrs.php, including .kml for Google Earth. Yes, I use skyvector and like it a lot. For this particular case I was looking for more ground detail that the sectional chart in skyvector provides. |
As GliderCZ pointed out, my website at http://www.soaringdata.info does this.
- Select the TFRs tab - Follow the link to the query form - Enter a center airport and a radius to define the area of interest - select Google Earth KML format for the output .... and download a KML file containing all the TFRs in the area that can be opened in Google Earth. It is all free and freely redistributable. Lynn Alley "2KA" |
On Saturday, September 12, 2020 at 11:13:49 AM UTC-5, jp wrote:
Is there a way - an easy way hopefully - to have TFRs display on Google Earth? The Google Earth app I have installed on my iMac has a ool that enables drawing circles of known radius. I used the drawing tool to put concentric glider rings around my home airport and designate Class C & D airspace nearby.. Send a message to smanley at wisc dot edu and I'll reply with an image attachment. |
Is there a way - an easy way hopefully - to have TFRs display on Google Earth? Another option would be to use an image capture function to take a picture of the Google Earth screen, then import the image into a Microsoft Office app (Excel or Word) and use the MS drawing tools to add in the TFR. Then capture that image. |
Scott :
The airspace depiction is another thing that SoaringData.Info will do for you. Just download allusa.kml on the airspace tab at http://soaringdata.info. Or you can just check the "Add ATC-controlled airpspace" box when you do the TFR query I described above. Lynn |
Google Earth Pro changes | [email protected] | Soaring | 4 | May 8th 20 12:17 AM |
V2 Google Earth Pro changes | [email protected] | Soaring | 0 | May 7th 20 08:33 PM |
Saw This On Google Earth | John[_1_] | Naval Aviation | 3 | January 27th 08 12:25 AM |
Google Earth | Frank Whiteley | Soaring | 3 | November 16th 07 12:36 AM |
Google Earth fun | Al Denelsbeck | Aviation Photos | 4 | January 11th 07 04:31 PM |
