Why did Britain win the BoB?
Let us imagine that we are going to be playing a complex wargame assigned to us some 3rd or 4th year military science course. There are 20 classmates. Each will have to write a report from either GErmany's or Britain's perspective, and the grade will determine your standing on your team when the game is played. The Battle of the Atlantic is open to play too. In addition, any commentary on any matter could boost your grade. Such as commenting on mass communications then and now, or anything that seems intersting and anytime relevant to military studies. The setting is July 1st, 1940. What must the Axis do better? And what must the Allies do better? To me it looks like Germany can improve a lot, and Britain only a little bit. It is easy for the Axis team to create a shopping list of things to do better, or more, or less, but what can be put on the Allies list? John Freck |
"John Freck" wrote in message om... Why did Britain win the BoB? Let us imagine that we are going to be playing a complex wargame assigned to us some 3rd or 4th year military science course. There are 20 classmates. Each will have to write a report from either GErmany's or Britain's perspective, and the grade will determine your standing on your team when the game is played. The Battle of the Atlantic is open to play too. In addition, any commentary on any matter could boost your grade. Such as commenting on mass communications then and now, or anything that seems intersting and anytime relevant to military studies. The setting is July 1st, 1940. What must the Axis do better? And what must the Allies do better? The Germans need to 1) Develop drop tanks for the Bf-109 2) Go after the RAF sector control rooms, they were largely above ground and vulnerable 3) Use the Me-110 as fighter bombers on low level strike missions not as heavy fighters 4) Get their intel sorted out, attacking coastal command airbases was a massive waste of resources 5) Target the Supermarine works at Southhampton and keep hitting it To me it looks like Germany can improve a lot, and Britain only a little bit. It is easy for the Axis team to create a shopping list of things to do better, or more, or less, but what can be put on the Allies list? 1) Ground the Defiants and requip the squadrons with Hurricanes 2) Ditch the outdated RAF tactics and adopt the German method 3) Disperse and reinforce those sector control rooms 4) Increase efforts to disperse aircraft production 5) Kick Leigh-Mallory and Dowding's ass and make them work as a team, if necessary fire one or other of them. 6) Get the carburettor mods to stop the engine cutting out under +ve G done as a matter of priority 7) Get the bomber force after the German airfields every night deprive the buggers of sleep if nothing else. Keith |
Keith Willshaw wrote:
"John Freck" wrote in message om... Why did Britain win the BoB? Let us imagine that we are going to be playing a complex wargame assigned to us some 3rd or 4th year military science course. There are 20 classmates. Each will have to write a report from either GErmany's or Britain's perspective, and the grade will determine your standing on your team when the game is played. The Battle of the Atlantic is open to play too. In addition, any commentary on any matter could boost your grade. Such as commenting on mass communications then and now, or anything that seems intersting and anytime relevant to military studies. The setting is July 1st, 1940. What must the Axis do better? And what must the Allies do better? The Germans need to 1) Develop drop tanks for the Bf-109 2) Go after the RAF sector control rooms, they were largely above ground and vulnerable 3) Use the Me-110 as fighter bombers on low level strike missions not as heavy fighters 4) Get their intel sorted out, attacking coastal command airbases was a massive waste of resources 5) Target the Supermarine works at Southhampton and keep hitting it To me it looks like Germany can improve a lot, and Britain only a little bit. It is easy for the Axis team to create a shopping list of things to do better, or more, or less, but what can be put on the Allies list? 1) Ground the Defiants and requip the squadrons with Hurricanes They did - Defiants got one or two daylight outings during the BoB. After that their main roles were Night Fighting (more Effective than Hurricanes), SAR (safer than a Lysander!) and Convoy cover (Better than an Anson if range permitted). Better Defiants than Battles - Bomber command were actually rebuilding Battle squadrons at this time. 2) Ditch the outdated RAF tactics and adopt the German method Getting rid of the outdated Vics and formations and going to Finger Four or Loose Duce tactics yes. RAF tactical control of Fighter formations was way ahead of the Luftwaffe's. 3) Disperse and reinforce those sector control rooms 4) Increase efforts to disperse aircraft production 5) Kick Leigh-Mallory and Dowding's ass and make them work as a team, if necessary fire one or other of them. 6) Get the carburettor mods to stop the engine cutting out under +ve G done as a matter of priority I think you mean -ve G. Indeed this is the major shortfall that the RAF should have anticipated 7) Get the bomber force after the German airfields every night deprive the buggers of sleep if nothing else. Night intruders would be a good improvement on things but we need to keep in mind that 2 Group actually did a god job of bombing the invasion ports and impacting the German build up of barges etc. Less important than the aircraft production is to get more Pilots into Fighter command earlier. Dowding - Leigh-mallory is not a real time issue. Parks vs Leigh-Mallory was an issue but Dowding was on top of it. Most of the differences there were down to the nature of the problem in Kent VS north of the Thames. Parks could not use a big wing because his warning periods were to short to assemble it. Leigh Mallory had a relatively long period between alert and engagement which could usefully be used to assemble the big wings. Park's problem was that LM's reinforcements were taking to long to arrive with the result that the Germans were being hammered AFTER Park's airfields had been trashed rather than before. That said the RAF could have withdrawn from Kent and still punished the LW enough to prevent Germany being able to secure the beaches. LM's big wings performing a fighter sweep timed with a mass 2 group attack would sure mess up Germanys ad hoc landing forces. One thing the post war aggrandizement and publicity does not make clear is that the RAF was in no way out of options during the BoB - they continually had the choice of when and where to engage and were able to conserve and rotate forces through the whole Battle. The Luftwaffe on the other hand was making a much more committed effort and with much less flexibility about what they hit and where. One of the things I find most odd about Histories of the Battle of Britain is how one sided the stories are on the British side. Very few give Bomber or Coastal command a mention yet these were the forces that would have been committed to hitting them "on the beaches". The presence of Fleet Air Arm Fighter Squadrons in the UK are also unmentiond but their locations would have been such as to "free up" RAF squadrons. The big thing that the LW should have done is take out the Radar stations and the Sector stations. The LW only made one serious attempt to take out the Radar chain and the RAF managed to cover the resulting hole with the one replacement radar set they had and a couple of bluffs that fooled the LW signals into thinking that at least 2 other stations were still functioning (They were transmitting but the receiver complex was u/s for a couple of days). The RAF needed to get CH Low going earlier that was not something that could have been sorted out between Jan and July '40. Given the timeframe the RAF should have been taking over the Skua and Roc's of the Fleet Air Arm and forming Dive bomber squadrons with them in place of Battle Squadrons. Capacity was there to do this - BP produced both Roc and Defiant and it would not have been a major loss to turn the Roc production over to a Dedicated Skua/Roc Dive Bomber. (2 gun turret instead of 4, No Wing folding kit etc. - larger bomb load). Note that these aircraft used Bristol engines so freeing the Merlins for H & S that would have been used in Battles and Defiants. I am not saying that the Roc dive bomber would have been able to operate in the face of Bf109's but it would have been an improvement over the Battle since as a dive bomber it would have had better accuracy at hitting ships and front line targets than the Battle. Also 2~4 turret mg's has got to be better than 1 hand trained mg! Keith |
"Steven Vincent" wrote in message ... Keith Willshaw wrote: "John Freck" wrote in message om... Why did Britain win the BoB? Let us imagine that we are going to be playing a complex wargame assigned to us some 3rd or 4th year military science course. There are 20 classmates. Each will have to write a report from either GErmany's or Britain's perspective, and the grade will determine your standing on your team when the game is played. The Battle of the Atlantic is open to play too. In addition, any commentary on any matter could boost your grade. Such as commenting on mass communications then and now, or anything that seems intersting and anytime relevant to military studies. The setting is July 1st, 1940. What must the Axis do better? And what must the Allies do better? The Germans need to 1) Develop drop tanks for the Bf-109 2) Go after the RAF sector control rooms, they were largely above ground and vulnerable 3) Use the Me-110 as fighter bombers on low level strike missions not as heavy fighters 4) Get their intel sorted out, attacking coastal command airbases was a massive waste of resources 5) Target the Supermarine works at Southhampton and keep hitting it To me it looks like Germany can improve a lot, and Britain only a little bit. It is easy for the Axis team to create a shopping list of things to do better, or more, or less, but what can be put on the Allies list? 1) Ground the Defiants and requip the squadrons with Hurricanes They did - Defiants got one or two daylight outings during the BoB. After that their main roles were Night Fighting (more Effective than Hurricanes), SAR (safer than a Lysander!) and Convoy cover (Better than an Anson if range permitted). Better Defiants than Battles - Bomber command were actually rebuilding Battle squadrons at this time. They withdrew the squadrons but didnt immediately re-equip them at a time when pilots were in much shorter supply than aircraft. 2) Ditch the outdated RAF tactics and adopt the German method Getting rid of the outdated Vics and formations and going to Finger Four or Loose Duce tactics yes. RAF tactical control of Fighter formations was way ahead of the Luftwaffe's. 3) Disperse and reinforce those sector control rooms 4) Increase efforts to disperse aircraft production 5) Kick Leigh-Mallory and Dowding's ass and make them work as a team, if necessary fire one or other of them. 6) Get the carburettor mods to stop the engine cutting out under +ve G done as a matter of priority I think you mean -ve G. Indeed this is the major shortfall that the RAF should have anticipated 7) Get the bomber force after the German airfields every night deprive the buggers of sleep if nothing else. Night intruders would be a good improvement on things but we need to keep in mind that 2 Group actually did a god job of bombing the invasion ports and impacting the German build up of barges etc. Less important than the aircraft production is to get more Pilots into Fighter command earlier. Dowding - Leigh-mallory is not a real time issue. Parks vs Leigh-Mallory was an issue but Dowding was on top of it. Most of the differences there were down to the nature of the problem in Kent VS north of the Thames. Parks could not use a big wing because his warning periods were to short to assemble it. Leigh Mallory had a relatively long period between alert and engagement which could usefully be used to assemble the big wings. Park's problem was that LM's reinforcements were taking to long to arrive with the result that the Germans were being hammered AFTER Park's airfields had been trashed rather than before. That said the RAF could have withdrawn from Kent and still punished the LW enough to prevent Germany being able to secure the beaches. LM's big wings performing a fighter sweep timed with a mass 2 group attack would sure mess up Germanys ad hoc landing forces. One thing the post war aggrandizement and publicity does not make clear is that the RAF was in no way out of options during the BoB - they continually had the choice of when and where to engage and were able to conserve and rotate forces through the whole Battle. The Luftwaffe on the other hand was making a much more committed effort and with much less flexibility about what they hit and where. True enough One of the things I find most odd about Histories of the Battle of Britain is how one sided the stories are on the British side. Very few give Bomber or Coastal command a mention yet these were the forces that would have been committed to hitting them "on the beaches". The presence of Fleet Air Arm Fighter Squadrons in the UK are also unmentiond but their locations would have been such as to "free up" RAF squadrons. Yes at the time a every bomber squadron had to keep an anti-invasion flight on readines 24/7 The big thing that the LW should have done is take out the Radar stations and the Sector stations. The LW only made one serious attempt to take out the Radar chain and the RAF managed to cover the resulting hole with the one replacement radar set they had and a couple of bluffs that fooled the LW signals into thinking that at least 2 other stations were still functioning (They were transmitting but the receiver complex was u/s for a couple of days). The RAF needed to get CH Low going earlier that was not something that could have been sorted out between Jan and July '40. The radar stations were quite hard targets to hit and even if they were knocked out some warning was available from the observer corps. The sector stations were the point where everything converged and in many cases were little more than an Nissen hut Given the timeframe the RAF should have been taking over the Skua and Roc's of the Fleet Air Arm and forming Dive bomber squadrons with them in place of Battle Squadrons. Capacity was there to do this - BP produced both Roc and Defiant and it would not have been a major loss to turn the Roc production over to a Dedicated Skua/Roc Dive Bomber. (2 gun turret instead of 4, No Wing folding kit etc. - larger bomb load). Note that these aircraft used Bristol engines so freeing the Merlins for H & S that would have been used in Battles and Defiants. The Skua/Roc werent very survivable though and production was in such small numbers that I doubt ramping up was very practical. A better option may have been to fit bomb racks to the P-40's (Tomahawk I and Tomahawk IIA) the RAF got in June 1940 I am not saying that the Roc dive bomber would have been able to operate in the face of Bf109's but it would have been an improvement over the Battle since as a dive bomber it would have had better accuracy at hitting ships and front line targets than the Battle. Also 2~4 turret mg's has got to be better than 1 hand trained mg! Trouble is with the power turret fitted the Roc couldnt carry the bombload the Skua did, arguably the cleaner, fatster and more manoeuverable Skua was more survivable. Keith |
Here's some programs:
1) Have the Governor-General of Canada light a fire under Mackenzie King and get the Canada portion of the Empire Aircrew Training Program rolling full speed ASAP. No 'nice guy' treatment. 2) get the Polish fighter pilots cracking ASAP. They were held back too long. 3) get the cannon Hurricane program cracking ASAP^2 for anti-bomber work. 4) send Leigh-Mallory off to New Zealand. 5) move Bader to Kenley or Manston. 6) get a meaningful night intruder program working every night all night. 7) External tank on Spitfires to bounce 109s sucking fumes on the way home. See if they can swim the rest of the way. (Route Spits around the battle scene to arrive at intercept points with height advantage and lots of internal fuel. Bounce and go home.) Walt BJ |
"Herbert Pocket" wrote in message ...
Agreed, it is hard to pick out any outstanding Allied failures at the macroscopic level, though this is probably a consequence of knowing (with 20:20 hindsight) that the Allies were ultimately victorious. Snip In no particular order: A) Earlier recognition of aerial bombing inaccuracies, and development of improved assessment, equipment & training (with reference to the RAF's poor performance in early bombing missions and the general misbelief that the job was being well done). Herbert Pocket, Your point A) isn't any scraping the barrel by any means. The Allies wasted immense resources on bombers and strategic bombing. If Britain, and the Allies, had cut out four engined bombers in order to have a large increase in top fighters and a boost to strong, fast,and long-ranged 2 engined bombers: Then Germany would have had a harder time much sooner. Hopefully, I'm not reading to much into your sugggestion, I have long put forward similar notion that most of the strategic bombing was a waste, or it could have been done with much less and even better. During the Summer of 1940 the Allies could have had more fighters and more fuel, and have had the bombers on lower level missions cutting up Germans energy and transport. All strategic bombing could have, and should have, been done by long ranged fighter-bombers, and fast 2-engined bombers, and 100% of the effort shoud have been against German military targets, energy, and transport. IN 1947 the USAAF stated that 95% of startegic bombing reasouces were wasted, only 5% of the strategic bombing effort was worthwhile. But Christ, that 5% was a knock-out! Viturally, all the crippling damage done by strategic air attack was done by long-ranged fighter bombers and 2-engined bombers attacking at low altitude, and almost no serious damage was done by the wasteful other line. One hundred Mustangs each with a single 1,000lbs bomb, flying in low in order to lay down 50+ direct hits on railline is very troublesome to the GErmans, and did I mention the destoyed and badly damaged locomotives, loads, and other equipment, and the need for Germany then to disperse AAA? The Allies can put down 500 fighter-bomb sorties like that a day in the Rhur by 1943 and sleep in to boot. John Freck |
"John Freck" wrote in message om... "Herbert Pocket" wrote in message ... Agreed, it is hard to pick out any outstanding Allied failures at the macroscopic level, though this is probably a consequence of knowing (with 20:20 hindsight) that the Allies were ultimately victorious. Snip In no particular order: A) Earlier recognition of aerial bombing inaccuracies, and development of improved assessment, equipment & training (with reference to the RAF's poor performance in early bombing missions and the general misbelief that the job was being well done). Herbert Pocket, Your point A) isn't any scraping the barrel by any means. The Allies wasted immense resources on bombers and strategic bombing. There were no strategic bombers in 1940 RAF bomber command was almost exlusively equipped with light day bombers such as the Blenheim and Battle. The handful of 'heavies' available were twin engine types such as the Wellington, Whitley and Hampden. Keith Keith |
WaltBJ wrote:
Here's some programs: snip 7) External tank on Spitfires to bounce 109s sucking fumes on the way home. See if they can swim the rest of the way. (Route Spits around the battle scene to arrive at intercept points with height advantage and lots of internal fuel. Bounce and go home.) No, this one's not going to fly, if you'll excuse the expression. Already by August 18th, Park had ordered his controllers not to puruse reconnaissance a/c out to sea, and to engage major formations 'over land or within gliding distance of the coast', to cut down on pilots being lost over the channel. Pilot losses were starting to hurt, and they couldn't afford to lose pilots shot down over the North Sea and Channel, but otherwise okay at the time of bailout. Guy |
"Keith Willshaw" wrote in message
Your point A) isn't any scraping the barrel by any means. The Allies wasted immense resources on bombers and strategic bombing. Snip There were no strategic bombers in 1940 I was getting beyond the time frame I began with, July 1st 1940. My commentary gets more and more relevant from July 1st, 1940, however. IMO, the RAF had strategic bombers if the strategically bombed. To me then, 'strategic bomber' is any plane dropping bombs on a strategic mission bombing run. This then begs the question what is 'strategic bombing'. If on July 1st, 1940 a single Hurricane Super Marine Spitfire drops a single 1,000lbs bomb on a railroad line near Arnhiem, then a strategic bombing mission occured. I find it important to note: 'tactical' and 'strategic' are not opposite. The sentence 'There are tactical variations of strategic bombing that include type of aircraft used, altitude and speed at moment of bomb release, maginitude, and target.' makes sense, and the inverse is true. There are strategeis behind tactical choises. In any case, the RAF can from July 1st, 1940 favor fighters even more than they did, and use fighter bombers more over bombers and use bombing better. RAF bomber command was almost exlusively equipped with light day bombers such as the Blenheim and Battle. The handful of 'heavies' available were twin engine types such as the Wellington, Whitley and Hampden. You are telling me that the RAF had no heavy bomb load capacity 4-engined bombers yet by July 1st, 1940, or not many. Furthermore, you indicate strategic bombing must be "heavy" bombing as opposed to "light" bombing. I think you use you vocabulary differently than me, and that we need to understand our idiomatical difference and develop from there carefully. John Freck |
"John Freck" wrote in message om... "Keith Willshaw" wrote in message Your point A) isn't any scraping the barrel by any means. The Allies wasted immense resources on bombers and strategic bombing. Snip There were no strategic bombers in 1940 I was getting beyond the time frame I began with, July 1st 1940. My commentary gets more and more relevant from July 1st, 1940, however. IMO, the RAF had strategic bombers if the strategically bombed. To me then, 'strategic bomber' is any plane dropping bombs on a strategic mission bombing run. This then begs the question what is 'strategic bombing'. If on July 1st, 1940 a single Hurricane Super Marine Spitfire drops a single 1,000lbs bomb on a railroad line near Arnhiem, then a strategic bombing mission occured. No that would have been a bloody miracle since there never was such a thing as a Hurricane Super Marine Fighter I find it important to note: 'tactical' and 'strategic' are not opposite. The sentence 'There are tactical variations of strategic bombing that include type of aircraft used, altitude and speed at moment of bomb release, maginitude, and target.' makes sense, and the inverse is true. There are strategeis behind tactical choises. In any case, the RAF can from July 1st, 1940 favor fighters even more than they did, and use fighter bombers more over bombers and use bombing better. They DID favor fighters, there was no such thing as the fighter bomber at the time and the bomber force was being used in the tactical role to attack the invasion barges. The strategic attack on German industry didnt begin in earnest until 1942. RAF bomber command was almost exlusively equipped with light day bombers such as the Blenheim and Battle. The handful of 'heavies' available were twin engine types such as the Wellington, Whitley and Hampden. You are telling me that the RAF had no heavy bomb load capacity 4-engined bombers yet by July 1st, 1940, or not many. Exactly that, not one 4 engined bomber was in service. Furthermore, you indicate strategic bombing must be "heavy" bombing as opposed to "light" bombing. I think you use you vocabulary differently than me, Thats for sure, I also know what missions RAF bomber command flew in 1940 do you ? and that we need to understand our idiomatical difference and develop from there carefully. I think you need to read up a little on the subject , here's a free clue. Of the 13,000 tons of bombs the RAF dropped in 1940 only 137 tons fell on Industrial towns, the majority were on airfields, naval targets and troop concentrations. These usually count as tactical missions. In fact raids on tactical targets exceeded those on strategic ones until 1942. Of the 13,000 bombs dropped in 1940 5,000 were delivered by Wellingtons (twin engined) , 3000 by Whitleys (twin engined), 2700 by Hampdens (twin engined), 2000 by Blenheims (twin engined) and the remainder by the single engined Fairey battle. Keith |
| George III of Britain vs. George II of America | WalterM140 | Military Aviation | 5 | July 5th 04 09:36 AM |
| U.S. airmen playing hardball as American game grows in Britain, By Ron Jensen, Stars and Stripes | Otis Willie | Military Aviation | 0 | May 24th 04 04:30 AM |
| Britain Reveals Secret Weapon - Chicken Powered Nuclear Bomb ! | Ian | Military Aviation | 0 | April 2nd 04 04:18 PM |
| Battle of Britain fighters | Tony Williams | Military Aviation | 1 | February 14th 04 08:46 AM |
| Why did Britain win the BoB? | Grantland | Military Aviation | 79 | October 15th 03 04:34 PM |
