Newby questions about the GLASFLUGEL H 201 STANDARD LIBELLE
Old May 28th 21, 10:45 AM posted to rec.aviation.soaring
LoftusRoadLad
Default Newby questions about the GLASFLUGEL H 201 STANDARD LIBELLE
New to gliding (won't say "soaring" since I haven't been accused of doing much of that) and was interested in buying a forgiving starter glider. I've flown the 1-26 extensively but would like a bit more performance--feel like I'm stuck at the field.
I've seen the 201 on Wings and Wheels. I've read a couple of online items on the Libelle and they seem to be fairly glowing--not bad anyway. However, they are all, naturally, pretty old and with them being early glass birds I was wondering if I should be concerned about that--maintaining condition, repairs, upkeep etc. Also, the airbrakes from what I can tell aren't great at spoiling lift--I'd like some views on that. I looked on the NTSB database for Libelle accidents and quite a few of the accidents were regarding landing out and not being able to lose altitude quickly enough--though I understand it slips well, or not having much braking once on the deck.
I also read that although it is supposed to be easy (a gem) to assemble/disassemble, there might be an historical issue with a pin that could have dire consequences.
Finally, although just about every thing I've read is encouraging, there are quite a few for sale on W&W. I was wondering about that too--but there's a few 1-26s as well, so...
RS JD
Old May 28th 21, 11:27 AM posted to rec.aviation.soaring
Ronald de Vries
RS JD
Great ship and flies really nice. Airbrakes are ok if you watch your speed and don't extend the fully. No reason not to buy. Rigging is a simple job and can be done alone with a one man rig assist if you like.
Just buy a Libelle and try it.
Ronald
Old May 28th 21, 12:58 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Bear in mind when reading what follows that I had just under 270 hours
when I first flew a Libelle 201 from an aero tow - and had a nice 24
minute flight in fairly liftless conditions and no issues with flying it.
I was looking for a glider after flying club single seaters from 17 hours
(when I converted from ASK-21 to SZD Junior) and then to a Pegase 90 at
82 hours: so I'd been flying club single seaters (Pegase and Discus)
cross country for around 180 hours before first climbing into a Libelle.
That's true - nobody runs away if you ask for help rigging or de-rigging
a Libelle. It helps a lot that the spar stubs are fully visible during
this process. Elevator is self-connecting and stab is locked in place
with a single screw. There's a single, central pin that holds the wings
together and airgrakes are self-connection. The only real gotcha is that
the aileron connectors are just inside the fuselage and you *MUST* feel
under them as you drop the spring-loaded center pin through the ball
bearing on the end of the aileron push-rod. If you can't feel the end of
the pin projecting 1/4" or so through the underside of the bearing you've
done it wrong, so pull the pin up against the spring and do it again.
Repeat as needed until the pin is correctly fitted and sticking out of
the underside of the bearing.
I've had mine for 15 years, it had passed its 3000 hour inspection before
I bought it. The only major issues have been that:
- I damaged one of the aileron drives. They're fragile - NEVER, EVER
apply any force at all to the stick if you've got aileron locks or the
wing dolly fitted. For this reason its also better to have the wings off
or the ailerons disconnected before taking the panel out or putting it
back - this need the stick to be hard over on one side or the other to
slide the panel past it.
- I'm currently having one of the airbrakes bearings replaced because of
corrosion due to water leaks through an old (now replaced) set of covers.
The type certificate holder is Glasfaser in Germany - they're a pleasure
to deal with and very helpful if you need spares and/or drawings.
I think everything else I can tell you is he
https://www.gregorie.org/gliding/lib...201_notes.html
Martin | martin at
Gregorie | gregorie dot org
Old May 28th 21, 02:28 PM posted to rec.aviation.soaring
Hank Nixon
RS JD
These are a nice older glider to own. The finish holds up remarkably well for their age.
Light and easy to rig.
Not as rugged as more modern gliders.
Well supported by Streifeneder.
Forgiving and fairly easy to fly once you learn how to use the rudder.
Learn good energy management and pick big fields.
Good luck
UH
Old May 28th 21, 03:21 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Coming from a 1-26, it will be easy to build up speed in a Libelle. In your current flying, concentrate on exact airspeed control in circuit flying until you get the Libelle. The dive brakes aren't powerful enough to get rid of any excess energy, but are adequate for a well-flown circuit. If you can get dual in a high performance two-seat glass glider, it would be time well spent - it amazing how quickly the knots build up. The Libelle is the prettiest glider I've seen, and it is a regret that I have never had the chance to fly one.
Old May 28th 21, 06:05 PM posted to rec.aviation.soaring
Tony[_7_]
There is a TN to increase the spoiler travel that I am sniffing at - but really, they're fine. It will seem like a big change from a 1-26 with a skid because it is a big change!
Old May 28th 21, 06:30 PM posted to rec.aviation.soaring
Robert S
RS JD
I've heard lots of folks talk about the Libelle's weak spoilers. But, my experience was transitioning form a 1-26 to my Libelle and I would say the Libelle spoilers are more effective than the 1-26. YMMV or course. I'm sure other glass ships have more effective spoilers but if you're used to the 1-26 you'll be pleasantly surprised. I found the Libelle to be quite a bit more sensitive to correct rudder inputs so your ability to fly clean and straight will improve with time in the Libelle. I've found no vices at all with mine and I highly recommend it as a first glass ship.
I would say the biggest thing for you to determine is, can you physically fit in one? The cockpit is SNUG with zero extra room - particularly across the shoulders. I would strongly recommend finding one to actually sit in before making a purchase.
I've gotten superb support from Streifeneder when I need to ask a question or purchase a part - great folks to deal with. The bang for the buck with a Libelle is really quite good. Get one and fly the heck out of it!
Robert
Old May 28th 21, 08:02 PM posted to rec.aviation.soaring
Stéphane Vander Veken
I think the story about the Libelle airbrakes is partly because the "open class" Libelle H-301 (an older model than the standard Libelle H-201, the higher number notwithstanding) had the airbrakes very far backwards on the wing to keep the laminarity of the airflow undisturbed. They were indeed rather ineffective. Those on the Standard Libelle are quite decent, if not overly powerful.
When Hänle was developing the Standard Libelle, the IGC rules for the standard class still specified terminal velocity airbrakes (speed lower than Vne in a vertical dive), and even if the Libelle airbrakes were not really that good, they still limited the velocity below Vne at a 45° dive. That was a point of contention, because the IGC accepted this without formally changing the rules. American manufacturers like the Schweizer brothers felt cheated because they had indeed developed - at great cost - terminal velocity airbrakes conforming to the rules for their standard gliders.
Old May 29th 21, 12:03 AM posted to rec.aviation.soaring
Frank Whiteley
RS JD
Others have made most of the salient comments. Several of the early generation glass ships were 'over built' and the structure will endure for many years. The metal bits may need replacement and some of the Libelles have needed joystick replacements due to cracking near the base. Spigot pins might also need attention. But good support remains, so not a huge issue. Tight at the shoulders, so try on with a jacket if you will fly in a cooler climate and winter. Beautiful glider.
Frank
Old May 29th 21, 02:18 AM posted to rec.aviation.soaring
Wallace Berry[_2_]
Some will tell you that the yawstring on a Libelle is like a windshield wiper and that you will be forever dancing on the rudders to try to keep that string straight. Here's the real dope: Pull that yawstring off the front of the canopy where everyone sticks it. That's right down in the turbulent air produced by the angle of the canopy where it meets the cockpit perimeter. Put that yawstring up high on the canopy, just in your peripheral vision. You will be amazed at how much less rudder action you will need. I know this because I have been flying a 301 Libelle for 30 years. And, yes, I have flown 201's. I prefer the better performance of the flapped 301. In reality, the 201's handle better and are usually in better shape, being newer. However, nothing looks as good as a nice 301 with the low profile "racing" canopy.
Attention Glasflugel Libelle Pilots Nathan Lemmon Soaring 14 November 11th 20 09:44 PM
Glasflugel Libelle H-301/-301B POH thermalrider[_2_] Soaring 0 December 6th 12 01:23 AM
Interesting Standard Libelle Steve Leonard Soaring 1 April 22nd 06 11:17 PM
Interesting Standard Libelle Peter Thomas Soaring 0 April 22nd 06 12:00 AM
Standard Libelle Pam Kurstjens Soaring 4 May 22nd 05 06:40 PM
