#31
With this thread still active, I thought I'd take another crack at expousing
Jose's original query to those in the know about the accuracy of Tom's books on the performance of the F-4 and -14 in Iranian air combat. The stuff on the Tomcat could surely have a lot to say about the current picture of a-a combat. Some of you guys must have an inkling about whether or not there really was a lot of a-a combat as Tom suggests, or whether the "popular" account of there being very little a-a action (and airworthy 'Cats!) is more likely to be true. Thanks, Tony |
#32
Pechs1 wrote:
Thomas- Which does raise the question ogf what might have happened to Tomcat availability, etc, if it had been redeisgned from the ground up in the early 1990s like the Super Hornet. BRBR To late. If it was going to become the 'Super Tomcat or Tomcat 21, it needed to happen in the 80s, when $ was everywhere. I would say that the detailed Super Tomcat work would have been done in about the same period as the F/A-18E/F, but you're quite right to point out that the groundwork needed to be laid earlier. If in the early 1980s, they had comitted to making the whole force into F-14Ds or equivalent, there would have been a lot more reason to push a next generation version in place of the Super Bug. -- Tom Schoene Replace "invalid" with "net" to e-mail "Our country, right or wrong. When right, to be kept right, when wrong to be put right." - Senator Carl Schurz, 1872 |
#33
Tom-I would say that the detailed Super Tomcat work would have been done in
about the same period as the F/A-18E/F, It was, I saw briefs on the Tomcat 21 when I was in VX-4...late 80s but the USN didn't buy it. P. C. Chisholm CDR, USN(ret.) Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer |
#35
Tamas- Otherwise all variable wing planes suck a great deal: heavy,
trouble-prone, cost a lot to maintain, wings mecha takes up precious place in the fuselage, won't survive battle damage. No wonder the USN is retiring all Tomcats. BRBR It wasn't the swept wing that doomed the F-14. In my experience in 2 F-14 squadrons, the wing sweep mechanism was never a maintenance issue. It's pretty much bulletproof, too, being overbuilt and armored. Wing sweep problems are really rare. The folks at Pax tested the one wing stuck aft flyability and landability (I don't remember whether they tested trappability, though), I think as the result of that actually happening once. That was fairly recently, like in the last decade, so it's probably related to system wear. The wing sweep actuators ran on separate hyd systems but were interconnected via a torque tube so that loss of one PC would not inhibit wing operation. Problem was the torque tube was designed for emergency use, not every day. Standard maint procedures would use only one hyd to power the system and sweep the wings with the tube. Eventually one failed in flight and the aircraft trapped aboard America in the IO with one at 20 degrees one at 35 (mid 80's, the cruise after I left VF-102). It was relatively easy to control and except for higher approach speed (maneuvering flaps/slats only) not that big a deal. R / John |
#36
Delighted to hear your experience again, Mary! You really have a unique
point of view. (although I still smart a little when my first post attempt on this group was rejected years ago, when you said it was "almost good enough") Were you the last moderator on this group? Old Chief Lynn |
#37
Harry Andreas wrote:
This 3 level maintenance was the same for both USAF and USN. Lately, since the mid-90's, contracts have gone to 2 level maintenance. Getting rid of the intermediate shop has eased a lot of problems; Harry, there is still 3 level maintenance. In the USN, what you refer to as flightline is usually called "O level" as in organization (squadron). "I level" for intermediate, may be as close as across the street on base, but it is a separate entity from the squadron. (It is also usually a "good deal" for the maintenance folks for a shore tour after their time in the squadron, especially if the guys with families, because they don't have to move.) Depot level is usually not on the same base, as one depot serves a geographical reqion of several hundred miles radius or more. From what I've seen so far, I agree with how you describe the direction of the work on the flightline. Fault codes, troubleshooting flowcharts, and replacing black boxes. The avionics guys still know how to detail work like repair individual pins in connectors, check for continuity, but I've seen major components like an entire FLIR turret get shipped to swap out with a bad one on a deployed aircraft. By the way I'm a helicopter guy, not fast mover, but maintenance is a pretty similar business through all of naval aviation. |
#38
Jim Carriere wrote in message ...
Harry Andreas wrote: This 3 level maintenance was the same for both USAF and USN. Lately, since the mid-90's, contracts have gone to 2 level maintenance. Getting rid of the intermediate shop has eased a lot of problems; Harry, there is still 3 level maintenance. In the USN, what you refer to as flightline is usually called "O level" as in organization (squadron). "I level" for intermediate, may be as close as across the street on base, but it is a separate entity from the squadron. (It is also usually a "good deal" for the maintenance folks for a shore tour after their time in the squadron, especially if the guys with families, because they don't have to move.) Depot level is usually not on the same base, as one depot serves a geographical reqion of several hundred miles radius or more. From what I've seen so far, I agree with how you describe the direction of the work on the flightline. Fault codes, troubleshooting flowcharts, and replacing black boxes. The avionics guys still know how to detail work like repair individual pins in connectors, check for continuity, but I've seen major components like an entire FLIR turret get shipped to swap out with a bad one on a deployed aircraft. By the way I'm a helicopter guy, not fast mover, but maintenance is a pretty similar business through all of naval aviation. I worked intermediate maintenance (Marine Phantoms, S models) in the late 80s; we deployed *alot*. In a three-year tour, each squadron had two WestPacs and two WTIs to Yuma. However, it was always shore-based deployment (from Kaneohe Bay to Iwakuni, then to Subic or Kadena). I, being young and newly married, was always sent somewhere every few months. When we reported aboard Kaneohe, most of us were assigned to one of the rotary wing or Phantom squadrons, which meant we deployed; some were attached to the H&MS 24 squadron, which meant they didn't deploy. Everyone in IMA worked in the same shop and on whatever gear from whatever squadron needed work; the only difference was whenever VMFA-212 was heading out, those Marines attached to 212 left too and worked out of the local H&MS shop wherever they were deployed to. At least once, at Subic, the APA test bench for the Phantoms broke, which IIRC was a downing gripe for Phantoms since a myriad of flight attitude information was routed through it. A carrier (the Ranger?) had S-model Phantoms onboard and pulled into Subic for shore leave. We got permission from the ship to come aboard -- called for a base taxi, loaded the trunk with broken APA modules, and hauled them to the ship. We went aboard, promptly broke the Navy's test bench too, and were politely asked to leave and not come back anymore... Thanks for the trip down memory lane, Matt |
#39
Some complicating factors that came with the F-14:
1. Congress dictated, and the Navy agreed, that 70% of aircraft failures would be repairable at the organizational or intermediate level. 2. Congress dictated that Grumman use many small-business minority-setaside subcontractors. Many of these were frauds from the start; the president of the company was last seen headed for Brazil with his secretary under one arm and the entire assets of the company under the other. Once the company was gone, where do we get the parts? Just get the drawings and find another bidder, right? Wrong! The drawings were assets in bankruptcy, and bankruptcy courts do not work for DOD. 3. From day one, the RAG's, fleet squadrons, the production line and the Iranian buy were in competition for parts. It had been agreed that Iran would receive a one-year AVCAL (spare parts allowance based on aircraft quantity and projected flight hours) at the time of delivery of the first aircraft. Shortly into production, it was decided we could get more oil money back by providing Iran a two-year AVCAL with the first aircraft. 4. Every Congresscritter had to have an ankle to bite where the F-14 was concerned. Practically all F-14 communications from the fleet to Washington were by phone; any telegraphic message mentioning a fault or shortage would be highlighted in Jack Anderson's newspaper column within hours. 5. Fleet introduction was the classic Chinese fire drill. The first fleet F-14's that landed on Enterprise couldn't be launched; the nose launch bars would not fit the ship's fittings. George Skurla, President of Grumman Aerospace, was personally assigned a helicopter with crew and a machinist mate with a set of micrometers and flew the parts ashore to a machine shop in San Diego so they could be machined to fit. 6. By the time VF-124, -1, -2, -14 and -32 were outfitted, there had been so many configuration changes that the maintainers had to carry a matrix chart listing Bureau Numbers versus LRU dash numbers. Each LRU version had a code for each BUNO: 1) Works OK; 2) Works - Degraded Capability, or; 3) Don't Plug It In - Makes Smoke. Truly, a flying miracle! Rick P.S.: Would one of you REAL old-timers give me the real scoop on the Wing Flap Glove Vane System? "Jim Carriere" wrote in message ... Harry Andreas wrote: This 3 level maintenance was the same for both USAF and USN. Lately, since the mid-90's, contracts have gone to 2 level maintenance. Getting rid of the intermediate shop has eased a lot of problems; Harry, there is still 3 level maintenance. In the USN, what you refer to as flightline is usually called "O level" as in organization (squadron). "I level" for intermediate, may be as close as across the street on base, but it is a separate entity from the squadron. (It is also usually a "good deal" for the maintenance folks for a shore tour after their time in the squadron, especially if the guys with families, because they don't have to move.) Depot level is usually not on the same base, as one depot serves a geographical reqion of several hundred miles radius or more. From what I've seen so far, I agree with how you describe the direction of the work on the flightline. Fault codes, troubleshooting flowcharts, and replacing black boxes. The avionics guys still know how to detail work like repair individual pins in connectors, check for continuity, but I've seen major components like an entire FLIR turret get shipped to swap out with a bad one on a deployed aircraft. By the way I'm a helicopter guy, not fast mover, but maintenance is a pretty similar business through all of naval aviation. |
#40
In article , Jim Carriere
wrote: Harry Andreas wrote: This 3 level maintenance was the same for both USAF and USN. Lately, since the mid-90's, contracts have gone to 2 level maintenance. Getting rid of the intermediate shop has eased a lot of problems; Harry, there is still 3 level maintenance. In the USN, what you refer to as flightline is usually called "O level" as in organization (squadron). "I level" for intermediate, may be as close as across the street on base, but it is a separate entity from the squadron. (It is also usually a "good deal" for the maintenance folks for a shore tour after their time in the squadron, especially if the guys with families, because they don't have to move.) Depot level is usually not on the same base, as one depot serves a geographical reqion of several hundred miles radius or more. Yes, I know about O and I level. I try to KISS these subjects because this newsgroup is read by a lot of people who who don't know. I should have mentioned that many, many programs/platforms still use 3 level maintenance; that what I described as 2 level maintenance is really just now starting to hit the fleet with the newer systems like the new APG-79 radar in the F/A-18E/F. I recently worked the GPS receiver for the JSF. F-35 is using 2 level maintenance also. From what I've seen so far, I agree with how you describe the direction of the work on the flightline. Fault codes, troubleshooting flowcharts, and replacing black boxes. The avionics guys still know how to detail work like repair individual pins in connectors, check for continuity, but I've seen major components like an entire FLIR turret get shipped to swap out with a bad one on a deployed aircraft. By the way I'm a helicopter guy, not fast mover, but maintenance is a pretty similar business through all of naval aviation. Agreed. The philosophy of maintenance and testability is the same regardless of platform. As the older systems are replaced, 2LM will be increasingly common and the costs should drop, as long as the PMA funds enough spare LRUs for the pipeline. r/ -- Harry Andreas Engineering raconteur |
