F-14 Tomcat story.
Old November 16th 04, 12:53 PM
JDupre5762
Default F-14 Tomcat story.
I was told a story once by someone who worked at Grumman concerning the F-14.
It seems that one day a crew took up an F-14 and shortly after take off found
that the pitch controls (elevons?) were stuck causing the aircraft to pitch up
uncontrollably. By increasing power the crew was able to keep the aircraft in
a series of loops. After several loops they used rudder to bring the aircraft
horizontal changing the loops into a series of tight turns. In the meantime
they were radioing Grumman for advice and were told to eject. Instead the
pilot determined that by ruddering back into a loop and using throttle he could
land at the bottom of the loop. This was successful and later manufacturing
tools were found jamming the affected control.
Is this true?
John Dupre'
Old November 16th 04, 05:58 PM
JD
Something like that happened to Yeager (I think) flying the F-86 (I think)
out of Downy Field (I think) enroute to Edwards AFB (I think) in the early
'50s. Someone here will know the story... I think. I don't think you
could do that in an F-14 though.
JD
Old November 16th 04, 09:22 PM
John Carrier
Sounds a bit far-fetched. While it's theoretically possible, getting the
aircraft to the precise position (altitude, alignment, airspeed) to allow
the second half of the loop to work to allow (what would have to be) a
perfect touchdown is beyond belief.
R / John
"JDupre5762" wrote in message
F-14.
found
pitch up
aircraft in
aircraft
meantime
could
manufacturing
Is this true?
John Dupre'
Old November 16th 04, 10:31 PM
W. D. Allen Sr.
Ever hear the naval term, "sea story"?
WDA
end
F-14.
found
pitch up
aircraft in
aircraft
meantime
could
manufacturing
Is this true?
John Dupre'
Old November 16th 04, 11:10 PM
Is this true?
John Dupre'
Responding as a controller and not a pilot it MAY have happened. But my
guess he might have been merely trying to get back to the field where
crash equipment was standing by. Actually landing would only have been
shear luck.
Old November 16th 04, 11:52 PM
Greasy Rider
On Tue, 16 Nov 2004 13:31:14 -0800, "W. D. Allen Sr."
proclaimed:
Do you know the difference between a fairy tale and a sea story?
A fairy tale begins with "Once upon a time...."
A sea story begins with "This is no **** .......".
Old November 17th 04, 02:56 AM
rottenberg
"JD" wrote in message news:8lqmd.104450$R05.74500@attbi_s53...
JD
An incident is described in Yeager's book in which I think his
ailerons were locked, and it happened while he was inverted on a
low-level pass of a friend's cabin. Being Yeager, he used quick
thinking to deduce and correct the problem, unlocking the controls.
After a safe landing, the plane was taken apart and both it and other
planes that had been lost without explanation were tracked to the same
factory. There was some critical part - a linkage or something of
that sort - that had been intalled the wrong way by a single factory
worker who had been working so long that when he saw something in the
plans that didn't gibe with his experience, he ignored. Nobody was
telling him how to put planes together. Yeager notes that nobody told
him how many men he killed.
Old November 17th 04, 11:40 PM
John Carrier
"Greasy Rider" wrote in message
proclaimed:
Or, "There I was ..."
R / john
Old November 18th 04, 12:25 AM
Leanne
" Or, "There I was ..."
R / john, was that with or without a parachute?
Leanne
Old November 18th 04, 01:47 AM
John Carrier
Aileron loss is not as challenging as pitch control loss. You can roll most
airplanes with rudder to some degree, and with swept wing jets at high alpha
that is the only way it should be done.
The F-4 stabs would go full leading edge down with a dual PC failure,
causing an uncontrollable pitch up. BUT, with judicious use of rudder, you
could barrel roll the aircraft. Duke Cunningham did several such rolls to
get his damaged aircraft feet wet on 10 May, 1972. Full stab deflection in
most
I experienced a limited control jam in the F-14 in which I had insufficient
pitch authority to hold the nose up for level flight. We started a gradual
descent back to the beach (approx 100 miles) and the brief was we would roll
inverted to push the nose into a climb, get a little altitude, roll upright
to continue the descent, and so-on until we reached a reasonable ejection
point. Luck being a better asset than skill, the controls freed up after
about 50 miles and we very cautiously brought the jet back for a straight in
approach and landing.
R / John
"rottenberg" wrote in message
om...
think)
early
you
JD
FS: 1990 "Hornet: The Inside Story of the F/A-18" Fighter Jet Book Jim Sinclair Aviation Marketplace 1 November 8th 05 10:06 AM
FS: Revell Monogram "F-14A Tomcat" Plastic Model Kit (1:48 Scale) J.R. Sinclair Aviation Marketplace 0 August 16th 04 06:59 AM
George W. Bush Abortion Scandal that should have been Psalm 110 Military Aviation 0 August 12th 04 10:40 AM
FS: 1990 "Hornet: The Inside Story of the F/A-18" Fighter Jet Book J.R. Sinclair Aviation Marketplace 0 June 2nd 04 08:59 AM
PFC Lynch gets a Bronze Star? Brian Military Aviation 77 August 2nd 03 12:15 PM
