Tach 100rpm low
Old July 7th 03, 01:50 AM
Ben Smith
Default Tach 100rpm low
Hello -
Our mechanic verified my hunch that our tachometer is reading 100rpm low.
(At all ranges). Should the tach be repaired, or replaced? (Or left
alone?) Also, if I get a new one, is there a way to have the indicated
hours made the same as the existing one?
TIA
Ben
C-172 - N13258 @ 87Y
Old July 7th 03, 03:44 AM
BTIZ
is 100 RPM low... critical? might depend on the airplane, if you are the
only one that flies it, and knows it.. or post a placard..
does reading 100RPM low at all ranges, effect the total time accrued? most
likely.. by miniscule amounts..
make the new tac read the same total hours as the old?? why..
just make a log book entry of total time when old tac was removed, and tac
reading on new tac when installed, each maint log after that will carry the
correct total time forward.
What does your mechanic say?
BT
"Ben Smith" wrote in message
Hello -
TIA
Ben
Old July 7th 03, 06:11 AM
Patric Barry
You don't need a new tach - the setting requires an adjustment. And to
answer your question about whether it should be repaired - absolutely yes!
Hello -
TIA
Ben
Old July 7th 03, 03:41 PM
Ron Natalie
"Ben Smith" wrote in message ...
Hello -
I had my tach overhauled. Not only did it fix the accuracy issues, but they
also cleaned up (repainted) the dial. Wasn't very expensive as I can recall.
Unfortunately, the shop got bought out by scoundrels so I can't give a
recommendation.
Mechanical tach failure? Rich S. Home Built 25 November 6th 04 03:30 PM
