#21
Yep, another friend did that in his Cub after taxiing into a taxiway
light. Just goosed it and flew 10 miles home. Said it ran a little rough. Dylan Smith wrote: On Mon, 21 Jul 2003 10:33:04 -0700, Jeff wrote: ...your serious..a guy sawed off the tips of his prop and then flew the plane again? Don't worry, we had this happen with a club Beech Sierra. The guy didn't even bother doing that - he just flew home with curled prop tips! |
Yeah, it may be a western thing, but I doubt it. These people are
everwywhere. When I went to Johnson Creek a couple years ago there was a 182 that was parked waiting for a new engine. After startup something broke. All the oil leaked out on the ground where he was parked, he saw this later. He took off with no oil. After getting about 200 feet in the air he notices no oil pressure so returns and lands. After landing and parking the prop spins down like a turbo prop. Takes forever to stop. Finds out the crankshaft had snapped in two. If you've ever been to Johnson Creek you know what a bad deal this could have been. John Galban wrote: Newps wrote in message news:vaWSa.115114$H17.35404@sccrnsc02... Last month a buddy taxiied his J-5 into a hole, a seriously big hole. One prop tip was bent about 30 degrees back from straight, the other just had the paint scraped. So we found a wheel chock and a mallet. With a couple guys holding onto the prop, another holding the chock against the back of the prop the other guy whacked on the prop until it was more or less straight. Then he flew home. I wouldn't call this uncommon. That must be a Montana thing. I met a guy at the Spotted Bear backcountry strip who was lucky enough to have had just enough altitude to glide there. His crank had snapped over the adjacent Wilderness Area. Turns out he'd taxied into a snowbank a few months prior. When I talked to him, he still hadn't made the connection between his prop strike and the broken crank on his Champ. John Galban=====N4BQ (PA28-180) |
from what I understand about propellers, they are what makes the plane go,
they turn at a very high RPM and are suppose to be balanced. during preflight you check for cracks, dings and any other problems that may cause a problem. I would consider a bent (more or less) prop a problem. The thing with aviation is we are suppose to be responsible people, we learn what to do and not to do, we are suppose to check ourselves. you can get away with alot if thats what your wanting to do. But where it catches up with you is when you least expect it. Thomas Borchert wrote: Newps, So we found a wheel chock and a mallet. Well, I would walk away rather than being part in something like that. I sure think aviation is over-regulated, but that'S a major Forrest Gump moment: Stupid is as stupid does. -- Thomas Borchert (EDDH) |
#24
Yes I know they are everywhere, I read the NTSB reports alot. I like the one recently where
the guy had an engine failure, he landed just fine in a farmers field, after landing, he restarted the plane, took off, at around 200 ft, plane lost power, rolled, crashed, he died Newps wrote: Yeah, it may be a western thing, but I doubt it. These people are everwywhere. When I went to Johnson Creek a couple years ago there was a 182 that was parked waiting for a new engine. After startup something broke. All the oil leaked out on the ground where he was parked, he saw this later. He took off with no oil. After getting about 200 feet in the air he notices no oil pressure so returns and lands. After landing and parking the prop spins down like a turbo prop. Takes forever to stop. Finds out the crankshaft had snapped in two. If you've ever been to Johnson Creek you know what a bad deal this could have been. John Galban wrote: Newps wrote in message news:vaWSa.115114$H17.35404@sccrnsc02... Last month a buddy taxiied his J-5 into a hole, a seriously big hole. One prop tip was bent about 30 degrees back from straight, the other just had the paint scraped. So we found a wheel chock and a mallet. With a couple guys holding onto the prop, another holding the chock against the back of the prop the other guy whacked on the prop until it was more or less straight. Then he flew home. I wouldn't call this uncommon. That must be a Montana thing. I met a guy at the Spotted Bear backcountry strip who was lucky enough to have had just enough altitude to glide there. His crank had snapped over the adjacent Wilderness Area. Turns out he'd taxied into a snowbank a few months prior. When I talked to him, he still hadn't made the connection between his prop strike and the broken crank on his Champ. John Galban=====N4BQ (PA28-180) |
#25
It's not just the bent prop I would be worried about. It takes a serious
jolt to bend a big piece of aluminum like that, and engines don't like that kind of (mis)treatment. Is anyone aware of ANY aircraft engines that don't require a serious inspection after a prop strike? "Jeff" wrote in message ... from what I understand about propellers, they are what makes the plane go, they turn at a very high RPM and are suppose to be balanced. during preflight you check for cracks, dings and any other problems that may cause a problem. I would consider a bent (more or less) prop a problem. The thing with aviation is we are suppose to be responsible people, we learn what to do and not to do, we are suppose to check ourselves. you can get away with alot if thats what your wanting to do. But where it catches up with you is when you least expect it. Thomas Borchert wrote: Newps, So we found a wheel chock and a mallet. Well, I would walk away rather than being part in something like that. I sure think aviation is over-regulated, but that'S a major Forrest Gump moment: Stupid is as stupid does. -- Thomas Borchert (EDDH) |
#26
Newps,
Yep, another friend You gotta get thinking about what kind of friends you have... ;-) -- Thomas Borchert (EDDH) |
#27
![]() "Ron Garrison" wrote in message news ![]() It's not just the bent prop I would be worried about. It takes a serious jolt to bend a big piece of aluminum like that, and engines don't like that kind of (mis)treatment. Is anyone aware of ANY aircraft engines that don't require a serious inspection after a prop strike? Both Continental and Lycoming require an engine teardown for any propstrike no matter how minor. My insurance company didn't even bat an eye when I told them I wanted one. |
#28
Newps wrote in message .net...
After getting about 200 feet in the air he notices no oil pressure so returns and lands. After landing and parking the prop spins down like a turbo prop. Takes forever to stop. Finds out the crankshaft had snapped in two. If you've ever been to Johnson Creek you know what a bad deal this could have been. I spend a lot of time at Johnson Creek (as a matter of fact I'll be there in about a week), and I'd have to say I'm very impressed. Getting a 182 back onto the runway from 200 ft. is something I'd expect from Bob Hoover. The trees at the end of the runway are damn near 100 ft. tall. John Galban=====N4BQ (PA28-180) |
#29
Several times for me.
Brian Sponcil wrote: I suppose that in some strange way it should fill us with confidence to know that an airplane, even one so badly corroded it has holes, won't likely break up in flight. Out of curiosity, I wonder how many people have aborted due to the preflight inspection (not including run-up)? For myself, I can think of at least two times that I cancelled because of what I found under the cowl. -Brian Warrior 33431 Iowa City, IA Dan Luke wrote: "Dylan Smith" wrote: There was a Beech Duke at Houston Gulf. I swear that the guy who flew it (about once every four months) wouldn't have noticed if the right wing was missing beyond the engine nascelle (until he tried to rotate of course). The plane had a LOT of defects which were readily apparent to the most cursory inspection, including some very bad corrosion on the vertical stab. There's a Cardinal at one of our local fields with corrosion so bad there are actually holes in it. I hear its tail number on CTAF once in a while. This kind of thing is not too uncommon, apparently. It's a wonder these aircraft don't show up in the accident reports more often. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
#30
Lessee, I have pulled a 10 inch crescent wrench out from on top of a
cylinder on one plane.... Found the rudder linkage completely disconnected at the tail of another (that one aborted the flight!)... Found the fuel tanks essentially dry on one when the gauges showed half full (had a little heart to heart with the fbo on that one)... Had a couple of instances of fouled plugs on the runup that caused me to change planes rather than wait on the mechanic... Ya gotta be alert because they ARE trying to get you... Denny "Brian Sponcil" wrote in message ... Out of curiosity, I wonder how many people have aborted due to the preflight inspection (not including run-up)? |
Flying Magazine Subscriptions Trial Offer | Keith | Aviation Marketplace | 0 | July 1st 04 05:24 PM |
Northern NJ Flying Club Accepting New Members | Andrew Gideon | Aviation Marketplace | 1 | June 12th 04 03:03 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
3 Misawa pilots get Distinguished Flying Cross | Otis Willie | Military Aviation | 9 | December 8th 03 02:47 AM |
Flying Fortress Movie | L'acrobat | Military Aviation | 0 | July 1st 03 12:42 AM |
