#21
"Maule Driver" wrote: "CriticalMass" Those GPS receivers won't count for much in your IFR training, but, for the ADF, I'd dump it. ADF approaches and transmitters are being decommissioned around the country wholesale, and replaced by GPS approaches which are more accurate than ADF anyway. That's a little contradictory isn't it? If you are going to fly GPS approaches at small airports why wouldn't it count for much in your IFR training? I believe the GPS units in question were VFR units. |
CriticalMass wrote:
: Those GPS receivers won't count for much in your IFR training, but, for the : ADF, I'd dump it. : ADF approaches and transmitters are being decommissioned around the country : wholesale, and replaced by GPS approaches which are more accurate than ADF : anyway. True enough, although getting IFR GPS's installed can be a somewhat pricey endeavor. I went over this idea when I was putting together the panel in my Cherokee for my IFR training. With WAAS GPS's about the depreciate all non-precision GPS's, it seemed silly to pay big bucks to get one installed. I did my training with VOR's, a DME (thanks to the wonderful KNS-80 bought and installed for a song), and ILS components. A VFR GPS can be used for situational awareness, and could be used in a pinch (read: emergency) as an ADF/DME/VOR if really necessary. I wouldn't pay to have the ADF redone. The usual sentiment is if it's installed, works, and you don't need more panel space, leave it in. Anything missing from that equation and it makes more sense to ditch it. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Ron Rosenfeld wrote:
But I've not seen a garden-variety AM receiver that would tune to 260. If you know of one, please let me know. The one's I've seen don't go much below the AM broadcast band. Good point; I forgot about that. If you are seriously interested in going this route you might check out the various shortwave receivers that are available. Radio Scrap used to have a fairly decent one that didn't cost too much, but that might be too geekish a product for anyone to carry any more. Tim |
#24
![]() On 24-Oct-2003, "Dan Luke" c172rgATbellsouthDOTnet wrote: The ADF still may be necessary in some instances, but they are dwindling. I have an ADF in my airplane that I will keep using as long as it still works, but I when it breaks, it's gone. OK, here's a question for those familiar with use of an IFR certified GPS in non-GPS approaches. The approach plate for the ILS at my home airport (PAE) plainly states "ADF REQUIRED". The reason is that the missed approach procedure calls for intercepting and tracking inbound on a specific heading to the LOM. In looking over a bunch of approaches it is clear to me that there are a number of ILSs that carry the ADF REQUIRED indication. My question is, can an approach certified GPS (legally) be used in lieu of an ADF for navigational guidance in a segment of an ILS procedure that nominally requires an ADF? If so, how? If not, it seems to me that ditching the ADF will close off use of many ILS procedures. -- -Elliott Drucker |
#25
![]() wrote in message ... On 24-Oct-2003, "Dan Luke" c172rgATbellsouthDOTnet wrote: The ADF still may be necessary in some instances, but they are dwindling. I have an ADF in my airplane that I will keep using as long as it still works, but I when it breaks, it's gone. OK, here's a question for those familiar with use of an IFR certified GPS in non-GPS approaches. The approach plate for the ILS at my home airport (PAE) plainly states "ADF REQUIRED". The reason is that the missed approach procedure calls for intercepting and tracking inbound on a specific heading to the LOM. In looking over a bunch of approaches it is clear to me that there are a number of ILSs that carry the ADF REQUIRED indication. My question is, can an approach certified GPS (legally) be used in lieu of an ADF for navigational guidance in a segment of an ILS procedure that nominally requires an ADF? If so, how? If not, it seems to me that ditching the ADF will close off use of many ILS procedures. -- -Elliott Drucker Yes. Punch 'direct-to' and put in the NDB id. Hit 'Obs' if you want to intercept a different radial/bearing than the one that your already on. Piece of cake! Cheers, John Clonts Temple, Texas N7NZ |
#26
OK, here's a question for those familiar with use of an IFR certified GPS in non-GPS approaches. The approach plate for the ILS at my home airport (PAE) plainly states "ADF REQUIRED". The reason is that the missed approach procedure calls for intercepting and tracking inbound on a specific heading to the LOM. In looking over a bunch of approaches it is clear to me that there are a number of ILSs that carry the ADF REQUIRED indication. My question is, can an approach certified GPS (legally) be used in lieu of an ADF for navigational guidance in a segment of an ILS procedure that nominally requires an ADF? If so, how? From the AIM 1-1-20 f.: 6. Restrictions (a) GPS avionics approved for terminal IFR operations may be used in lieu of ADF and/or DME.... [snip] (f) Charted requirements for ADF and/or DME can be met using the GPS system, except for use as the principal instrument approach navigation source. [unless, of course, the approach is charted as an "overlay" approach]. To do this in the case you describe, I would press the the "direct" button on the KLN-90B and enter the identifier for the LOM as the waypoint. I would then have to press "enter" twice, set the GPS to OBS mode, set the CDI scale to one mile and turn the OBS to the missed approach course setting on the approach plate. If I were really flying this approach, I would have already done this stuff before I ever commenced the approach. It's really the same thing as tuning in a VOR and setting the OBS on a conventional NAV radio. More accurate than using the ADF and easier to fly. Oh yeah, and I would *still* have my ADF tuned to the LOM and be watching it, too. -- Dan C172RG at BFM |
#27
![]() "Maule Driver" wrote in message m... "CriticalMass" Those GPS receivers won't count for much in your IFR training, but, for the ADF, I'd dump it. ADF approaches and transmitters are being decommissioned around the country wholesale, and replaced by GPS approaches which are more accurate than ADF anyway. That's a little contradictory isn't it? If you are going to fly GPS approaches at small airports why wouldn't it count for much in your IFR training? Because they're not IFR-certified. Not much more needs to be said, assuming the proper attitude toward flying IFR in accordance with the rules has any bearing on the matter. |
#28
![]() wrote in message ... CriticalMass wrote: : Those GPS receivers won't count for much in your IFR training, but, for the : ADF, I'd dump it. : ADF approaches and transmitters are being decommissioned around the country : wholesale, and replaced by GPS approaches which are more accurate than ADF : anyway. The usual sentiment is if it's installed, works, and you don't need more panel space, leave it in. Anything missing from that equation and it makes more sense to ditch it. I think that's what I said, isn't it? |
#29
On Fri, 24 Oct 2003 08:23:50 -0500, "CriticalMass"
wrote: I noticed the price of a new Garmin 155XL IFR-certified GPS is now down to just over $2,000. not even close...... http://www.pacific-coast-avionics.co...il.asp?id=4456 |
#30
![]() Bob wrote: On Fri, 24 Oct 2003 08:23:50 -0500, "CriticalMass" wrote: I noticed the price of a new Garmin 155XL IFR-certified GPS is now down to just over $2,000. not even close...... http://www.pacific-coast-avionics.co...il.asp?id=4456 That's the installed price of a new unit and is typical. A search in Yahoo turns up prices of about $3,000 for a new unit uninstalled (yes, Garmin's policy is to only sell installed units). Several outfits are also selling reconditioned units for $2,000 to $2,300. Perhaps CriticalMass saw one of those ads. George Patterson You can dress a hog in a tuxedo, but he still wants to roll in the mud. |
We should replace planes with tie-fighters !!! | Dan Simper | Naval Aviation | 5 | February 6th 05 06:20 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
best source to replace missing cowl fastener | Craig | Owning | 5 | August 25th 03 08:07 PM |
