Hello community,
imagine you have a plane (rented) with a build in 2-place intercom (sigtronics in this case) and want to give your passengers their own headsets, so you can communicate with them. It is not necessary for them to hear the radio transmissions you make, although, it would be nice (if legal ;-). What do you need? An additional portable 2-place intercom? A Y-cable extension? Thanks in advance for your answers. Regards Kai Glaesner |
"Kai Glaesner" wrote in message
What do you need? An additional portable 2-place intercom? A Y-cable extension? I purchased a 4-place portable intercom for this type of scenario. -- John T http://tknowlogy.com/tknoFlyer __________ |
![]() "Kai Glaesner" wrote in message ... What do you need? An additional portable 2-place intercom? A Y-cable extension? I have a 4-place sigtroncs portable that I used a lot. It seemed to work fine cascaded into the copilots mic/phone jack. |
Hello community,
imagine you have a plane (rented) with a build in 2-place intercom (sigtronics in this case) and want to give your passengers their own headsets, so you can communicate with them. It is not necessary for them to hear the radio transmissions you make, although, it would be nice (if legal ;-). What do you need? An additional portable 2-place intercom? A Y-cable extension? Thanks in advance for your answers. Regards Kai Glaesner I've tried to daisy chain two portable intercoms together when I had this same situation. It resulted in nobody being able to hear or speak. I don't know why this happened. Also had bad results combining a portable intercom with a panel mount intercom in a 4 seat airplane only equipped with headset jacks for the front seats. |
Ron,
I have a 4-place sigtroncs portable that I used a lot. It seemed to work fine cascaded into the copilots mic/phone jack. So I guess you connected your headset to the pilots jack, and copilots and passengers to the portable? |
In article , Kai Glaesner
wrote: What do you need? An additional portable 2-place intercom? A Y-cable extension? Plugging a second intercom into an existing intercom will result in feedback if the mic plugs are plugged in. This is especially true if you have the second intercom plugged into the pilots side mic jack. You may not hear it within the airplane, but if you transmit, all anyone will hear is a squeal. Two Y-cords may work, or not , depending on the impedances of the headsets. |
![]() "Kai Glaesner" wrote in message ... So I guess you connected your headset to the pilots jack, and copilots and passengers to the portable? Nope, I plugged all the headsets into the intercom. The only reason I used the copilots side is to keep the mess of cords out of my way. I used a portable PTT connected to PTT in on the intercom.... you may have to investigate whether this will work on your plane. On some planes I did this with I used the hand mike in. |
![]() "EDR" wrote in message ... In article , Kai Glaesner wrote: What do you need? An additional portable 2-place intercom? A Y-cable extension? Plugging a second intercom into an existing intercom will result in feedback if the mic plugs are plugged in. Funny, it works just fine for me. Why would their be feedback. The intercom looks like a headset to the the thing it's plugged into. The only real fun and games is getting the PTT's and the squelches right if you intend to actually use both intercoms. In my case I just plug everybody into the four place and plug the portable into a single mic/headphone jack (just as if there was not an intercom installed in the first place). |
So I guess you connected your headset to the pilots jack, and copilots and passengers to the portable? I've found that it's much better to have all headsets plugged into the same intercom system. Otherwise you may find that your passengers can hear you, but you might not hear them. -- John T http://tknowlogy.com/tknoFlyer __________ |
John,
I've found that it's much better to have all headsets plugged into the same intercom system. Otherwise you may find that your passengers can hear you, but you might not hear them. I guess if I connect the portable to the pilot's jack and press the planes's build in PTT you can hear the whole group chatting while transmitting? |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | General Aviation | 0 | December 11th 03 09:42 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Aviation Marketplace | 0 | December 11th 03 09:41 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Instrument Flight Rules | 0 | December 11th 03 09:41 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Aviation Marketplace | 1 | October 17th 03 02:04 AM |
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | General Aviation | 0 | September 4th 03 04:41 AM |
