Saftey of exposed wheel at 41,000 feet
Old December 6th 03, 04:14 AM
Steven P. McNicoll
"Don Tuite" wrote in message
I think he's asking about either excess tire pressure bursting the
tire or the tire expanding and getting stuck in the wheel well.
If that's his concern leaving the wheel exposed would make no difference as
wheel wells are not pressurized anyway.
Old December 6th 03, 04:22 AM
Steven P. McNicoll
"Tom" wrote in message
Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose
wheel and 98 PSI on the mains. They are filled with dry nitrogen.
Not maximum pressure, maximum pressure differential. Normal sea level
pressure is about 14.7 psi.
Old December 6th 03, 04:23 AM
Steven P. McNicoll
Your math doesn't add up (how cliche' )
How so?
Old December 6th 03, 05:23 AM
aptim
B-737 don't have main gear doors either. But I don't know if a 737 can
cruise at FL410.
aptim A&P
"stephen" wrote in message
m...
Hello,
How safe is Eclipse Aviaion's decision to expose the wheel on jet that
cruises at 41,000 feet?
Has this been done before? On what airplane?
Cessna Citation's have half open wheel bays. They cruise FL410 and up.
Old December 6th 03, 06:04 AM
Tom
"DaveSproul" wrote in message
differential is about 15 psi, which is trivial for a tire.
nose
Apparently, another "sorry" would be in order. What he's saying is that
difference between sea level and outer space is only around 15psi, which
is
PROBABLY an almost insignificant fraction of the pressure usually existing
inside a properly inflated tire.
I suppose that he could be saying THAT! I figured he was addressing the
outside/inside air pressure.
This group is not known for high literacy content :~)
Old December 6th 03, 06:21 AM
stephen wrote:
Hello,
Safe from what?
If the aircraft isn't supersonic and the wheel wells aren't
heated and pressurized, they are going to see the same environment
whether they are hanging in the breeze or totally enclosed.
Jim Pennino
Remove -spam-sux to reply.
Old December 6th 03, 03:53 PM
EDR
In article , Tom
Nowhere does the original poster make any inferences to anything. It is
a straight question.
"How safe is Eclipse Aviaion's decision to expose the wheel on jet that
cruises at 41,000 feet? Has this been done before? On what airplane?"
Old December 6th 03, 04:30 PM
G.R. Patterson III
Which means that, if you took one into outer space, the nose tire would be
essentially at 135 PSI and the mains at 113.
George Patterson
Some people think they hear a call to the priesthood when what they really
hear is a tiny voice whispering "It's indoor work with no heavy lifting".
Old December 6th 03, 11:48 PM
Tom
"G.R. Patterson III" wrote in message
nose
Still the 'ol PITA, eh George?
Old December 6th 03, 11:52 PM
unrepentent
nose
is
Nor are its readers. :-))
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
Ta-152H at low altitudes N-6 Military Aviation 16 October 13th 03 03:52 AM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
