Update: Our mechanic found a bad spark plug lead wire. Thanks for all of
the replys. "David R." wrote in message ... We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago, we began to notice the engine to be rough on the right magneto during run-up. Over two weeks, it became increasingly difficult to burn it off by leaning during the run-up, until one day when it became impossible. We noticed on the engine monitor that the #5 cylinder head temp was cold during the run-up. Our mechanic looked at it, and yep, it was a fouled spark plug which was replaced. Now, about 15 hours later (and an annual), we have the same problem with the #5 cylinder. It's going back to the shop today. Any ideas? Why the same cylinder? What should we be looking for? |
I have no idea. I did not do it. The A&P made the call and got it right.
A new/used jug fixed it all. "David R." wrote in message ... How do you diagnose a cracked piston ring? Scope? Compressions? "Kevin Chandler" wrote in message ... We had a similar problem except the plug was getting fouled with oil. We had a crack piston ring. |
![]() "David R." wrote: How do you diagnose a cracked piston ring? A cracked compression ring will show up as low compression. A cracked oil wiper ring will show up in fouled plugs, oily deposits on the inside of the exhaust pipes, and smoky exhaust. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
And a cracked wallet will show up soon after..
denny "G.R. Patterson III" wrote in message ... "David R." wrote: How do you diagnose a cracked piston ring? A cracked compression ring will show up as low compression. A cracked oil wiper ring will show up in fouled plugs, oily deposits on the inside of the exhaust pipes, and smoky exhaust. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
Compression loss on cylinder when rings line up Truth of fiction? | test it | Home Built | 10 | May 11th 04 08:11 PM |
O-200 Cylinder Repair | jls | Home Built | 3 | February 29th 04 02:45 AM |
Cylinder Wrenches for 0-320A Narrow Deck | DAVE | Home Built | 1 | December 31st 03 01:45 PM |
Stick Shake When Firing Guns | John Kunkel | Military Aviation | 17 | October 2nd 03 12:39 AM |
'Hot' cylinder after overhaul? | Tony Cox | Owning | 8 | August 10th 03 07:25 PM |
