Tailplane question
Old January 19th 04, 03:43 PM
Lou Parker
Default Tailplane question
I'm building the tail-plane of my wooden aircraft and the plans have
specific measurements of the ribs every couple of inches to get the
shape from leading edge back. Unfortunately when I built the ribs it
came out looking as if it would create a whole lot of drag. In fact
when I follow the measurements, the first 3 inches go from 1/2" to 3"
in thickness immediately, and then smooth out. Not only does this just
look wrong, but not even close to the drawing supplied. I've checked
my numbers 3 times now, and keep getting the same results. Can anyone
tell me where to find information on the design and construction of
tail-planes? I may have to redesign this part.
Lou
Old January 19th 04, 04:04 PM
Ed Wischmeyer
Tailplane drag is not likely to be all that significant in the grander
scheme of things. A thicker tailplane can give you more authority. The
TurbineLegend and its descendants had tailplane thickness of either 13
or 16% (forget which), and I believe the RV series is at 9%. This isn't
an engineering answer, of course, but it doesn't sound to me like you've
necessarily got a problem.
What kind of plane is it, and what speed range? What are the chord,
thickness, and span of the tailplane?
Ed Wischmeyer
Old January 19th 04, 04:26 PM
Jan Carlsson
check the coordinats one more time, so you don't have a comma in the wrong
place!?
Jan Carlsson
"Lou Parker" skrev i meddelandet
om...
Lou
Old January 19th 04, 11:46 PM
Ed Sullivan
"Jan Carlsson" wrote in message ...
place!?
Jan Carlsson
om...
Lou
You didn't mention the name of the aircraft you are building, and have
you checked with the designer?
Ed Sullivan
Old January 24th 04, 03:32 PM
Badwater Bill
Ed Sullivan
Ed:
I thought you were dead.
BWB
Zenith Zodiac XL question Mick Home Built 4 January 14th 04 05:47 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Here's a silly question regarding plans David Hill Home Built 21 October 8th 03 04:17 AM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 03:20 AM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 09:47 PM
