I have trouble steering my homebuilt, which is simular of PA-20 and
suspect the steering springs are weak. Of coarse excessive tension would be too much stress on the rudder steering yoke. Does anyone know the correct spring rate for the steering springs on a PA-20? |
suspect the steering springs are weak. Of coarse excessive tension would be too much stress on the rudder steering yoke. Does anyone know the correct spring rate for the steering springs on a PA-20? Don't forget to check your landing gear alignment. It should be toed *out* very slightly. See deja for past discussions on this topic. You could also check the caster angle on the tailwheel, in addition to the steering springs. Ed Wischmeyer |
"Ed Wischmeyer" wrote in message
... I have trouble steering my homebuilt, which is simular of PA-20 and suspect the steering springs are weak. Of coarse excessive tension would be too much stress on the rudder steering yoke. Does anyone know the correct spring rate for the steering springs on a PA-20? Don't forget to check your landing gear alignment. It should be toed *out* very slightly. See deja for past discussions on this topic. You could also check the caster angle on the tailwheel, in addition to the steering springs. Ed Wischmeyer Also, don't forget to check for tailwheel alignment. Sometimes, corrosion in the rear fuselage can cause a bend that is reflected in a mis-aligned tailwheel and will reflect itself in hard steering (pre-flighted a Champ once where moving the rear of the fuse side-to-side to check tailwheel breakout tension showed more fuse movement than tailwheel movement). I don't know if the PA-20 is subject to such a problem, but if the other excellent suggestions don't pan out, check this. Heck, for safety's sake, check it anyhow. I saw a FlyBaby with a similar problem - water had been trapped in the rear and the wood had rotted - same symptom, very im-precise steering, lots of give in the fuse. Michael Pilla |
Marvin
My PA-20 has springs of different sizes on each side. A big stout one on one side and a lighter one on the other. I'm told that it is to eliminate the resonance associated with shimmy. "Marvin Barnard" wrote in message ... I have trouble steering my homebuilt, which is simular of PA-20 and suspect the steering springs are weak. Of coarse excessive tension would be too much stress on the rudder steering yoke. Does anyone know the correct spring rate for the steering springs on a PA-20? |
I believe the different sized (rate) steering springs was an attempt by
Maule to stop shimmy. If the pivot is properly lubricated, then the pivot angle is the problem. It must be at right angles to the ground under load. The force necessary to make the tailwheel turn is much larger if the top of the pivot points toward the front. For planes that started out o.k., the spring to the fuselage is probably bent and needs replacement or re-arching. Springs sag with old age. If it looks good without a load, then the tailwheel attachment spring is too soft and deflects to much when you climb aboard. This happens many times when a leaf from the spring is removed in a well intentioned attempt to make the plane ride better. So check the angle with a normal passenger and fuel load. Then if the top of the pivot points forward, you have two options. New complete spring set or re-arch the old. -- Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs or Always looking for articles for the Experimenter soon to be Sport Pilot "Ron Webb" wrote in message ... Marvin My PA-20 has springs of different sizes on each side. A big stout one on one side and a lighter one on the other. I'm told that it is to eliminate the resonance associated with shimmy. "Marvin Barnard" wrote in message ... I have trouble steering my homebuilt, which is simular of PA-20 and suspect the steering springs are weak. Of coarse excessive tension would be too much stress on the rudder steering yoke. Does anyone know the correct spring rate for the steering springs on a PA-20? |
I'm using a 6" Maule which I wonder if it may be too small? Tail
weight is 115 Lbs. The wheel kingpost angle is vertical. The steering springs are about 30 Lbs. tension. ( It's the Aircraft in Dec. "Experimenter" ) ....Staggerwing version of PA-20, I noticed most PA-20's use an 8" Scott...... are there any other folks using Maule successfully on PA-20? |
Ron Webb wrote:
Marvin My PA-20 has springs of different sizes on each side. A big stout one on one side and a lighter one on the other. I'm told that it is to eliminate the resonance associated with shimmy. "Marvin Barnard" wrote in message ... I have trouble steering my homebuilt, which is simular of PA-20 and suspect the steering springs are weak. Of coarse excessive tension would be too much stress on the rudder steering yoke. Does anyone know the correct spring rate for the steering springs on a PA-20? Springs of difference size make no since. the different tension is gona have that tailwheel not be lined up with the direction of the travel of the airplane, causing stress on it when it touches down. If it is a break over tailwheel, make sure the brake over is working right. If you have a tailwheel lock, make sure that is working right. If you have neither, well------good luck |
Tailwheel question | Steve B | Aerobatics | 4 | January 30th 04 03:35 AM |
Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 10:18 PM |
homebuilt tailwheel | Del Rawlins | Home Built | 7 | November 9th 03 02:34 AM |
