Thanks for all the replies! I think I'll start with some mineral
spirits (although the gojo sounds intriguing) and if any exhaust stains remain I'll invest in the Aero-Glaze. Appreciate the help. z |
If you do ever get around to using the solvent go to NAPA or equivalent and
get the attachment for your compressors airhose. It is a spray gun that has a hose coming off of it that you stick into the can of solvent. Press the trigger and the air sucks the solvent up thru the nozzle and blasts all that crud right off the bottom of the plane. |
On Wed, 16 Jun 2004 17:32:47 -0600, "Newps"
wrote: If you do ever get around to using the solvent go to NAPA or equivalent and get the attachment for your compressors airhose. It is a spray gun that has a hose coming off of it that you stick into the can of solvent. Press the trigger and the air sucks the solvent up thru the nozzle and blasts all that crud right off the bottom of the plane. I've got one of those and love it. Thanks for the tip. z |
![]() "zatatime" wrote in message ... On Wed, 16 Jun 2004 17:32:47 -0600, "Newps" wrote: If you do ever get around to using the solvent go to NAPA or equivalent and get the attachment for your compressors airhose. It is a spray gun that has a hose coming off of it that you stick into the can of solvent. Press the trigger and the air sucks the solvent up thru the nozzle and blasts all that crud right off the bottom of the plane. I've got one of those and love it. Thanks for the tip. Remember to run a sheet metal screw up into the bottom of the hose that goes into the solvent can. You want a really small opening, otherwise you'll suck that gallon can dry in no time flat and have a hell of a mess. A little goes a long way. |
On Wed, 16 Jun 2004 19:38:52 -0600, "Newps"
wrote: "zatatime" wrote in message .. . On Wed, 16 Jun 2004 17:32:47 -0600, "Newps" wrote: If you do ever get around to using the solvent go to NAPA or equivalent and get the attachment for your compressors airhose. It is a spray gun that has a hose coming off of it that you stick into the can of solvent. Press the trigger and the air sucks the solvent up thru the nozzle and blasts all that crud right off the bottom of the plane. I've got one of those and love it. Thanks for the tip. Remember to run a sheet metal screw up into the bottom of the hose that goes into the solvent can. You want a really small opening, otherwise you'll suck that gallon can dry in no time flat and have a hell of a mess. A little goes a long way. LOL - ok. Didn't think about that. z |
Belly Cleaning...? | zatatime | Owning | 48 | July 6th 04 04:33 AM |
World War II-era B-17 makes belly landing THE ASSOCIATED PRESS | Otis Willie | Military Aviation | 0 | May 7th 04 03:02 AM |
