#11
Hmmm, do you have a carb with a 1-piece venturi? On some applications these
made the engines run so poorly that the 2-pc was allowed to be reinstalled. Does leaning, even leaning to the point of the engine dying, change the roughness? Perhaps the carburettor is incorrectly jetted. Did you look at the distributor blocks in the mags? Or the coils? Perhaps the increased temperature of running at 1000-1700 with less cooling airflow is making something conduct that shouldn't? -- Aaron Coolidge There in lies the mystery. It ran fine before the timing was set correctly. Leaning has no effect. It is also only this RPM range. Outside of it, the engine runs like a champ. The side effect of fixing the timing is that the engine consistently runs 100 deg cooler on the head temp. I am wondering if the plugs are reacting funny. If I somehow "partially" contaminated them when I had them out for the cylinder repair. It doesn't, however, feel like they are fouling since leaving the effected RPM range requires no "clearing". Jim |
BTW -
Check that your cylinder baffling system is complete, tight to the cylinders and properly secured to the engine, and that air loads don't cause it to deflect away from the fins. You seem to have had a lot of cylinder agony. Do you have a balance problem? Above 1700 RPM the engine mounts may be able to isolate a still-running-rough engine from the cockpit. Be sure the plug gaps are small enough that you don't cause a marginal ignition harness to flashover at higher power. Does carb heat smooth things out? If so the engine is running lean. It could also be an intake manifold gasket that has sucked in, except that I wouldn't expect the idle to be smooth. NRPetersen |
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE | Karsten | Home Built | 0 | September 3rd 04 07:34 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) | Kyler Laird | General Aviation | 0 | March 1st 04 12:11 AM |
Rough Engine, please help | John Clonts | Owning | 14 | February 26th 04 12:09 AM |
rough engine just after power reduction | Sydney Hoeltzli | Owning | 11 | July 30th 03 03:37 PM |
