Hi,
I'm interested to buy a Mooney M20K. But the airfield I use is grass airfield. Do you think that Grass is ok with a M20K or it's dangerous ? Thanks a lot. (I must take a decision in few days ... ) Mike. |
A friend has an "E" and he doesn't want it on grass. Last year at OSH
we walked through the Mooney camp and he pointed out how low the gear doors were to the ground. Any little hole hit would obviously cause damage. From what I've read on a recent thread, Mooney did raise it, but you'll need to find out which model. On 13 Aug 2004 02:02:19 -0700, (vfr2003) wrote: Hi, I'm interested to buy a Mooney M20K. But the airfield I use is grass airfield. Do you think that Grass is ok with a M20K or it's dangerous ? Thanks a lot. (I must take a decision in few days ... ) Mike. |
Ron Rosenfeld wrote in message . ..
On 13 Aug 2004 02:02:19 -0700, (vfr2003) wrote: Hi, I'm interested to buy a Mooney M20K. But the airfield I use is grass airfield. Do you think that Grass is ok with a M20K or it's dangerous ? Thanks a lot. (I must take a decision in few days ... ) Mike. A well maintained grass strip should not be a problem. I have flown my M20E (less clearance than an M20K) into a variety of grass strips in the NE. I don't think that is true. On the M20E you simply have the single plate gear door attached to the gear itself. On the J-K's you have another gear door extension that further reduces the distance from bottom of tire to gear door. I would say any grass longer than 1" would tear up the gear door. I have seen J model owners remove that extra door and achieve the clearance of an E model Mooney. I've landed my Moony on the beach in Mexico and gravel in Canada but would never consider landing it on grass. I have hundreds of grass landings in other planes, but wouldn't consider doing it in my Mooney. -Robert |
Just to add another thought.... (I have limited Mooney experience/knowledge)
operating occasionally on grass may be different than basing on grass. You will always have 'bad' grass days on occassion if you base on it. Given the need to go or get home, you will be sorely tempted to operate on such days (i.e. mud, soft, or uncut). Another issue may be insurance if you are basing on grass. I live on 3400' of grass with trees on both ends and would never consider owning a Mooney for that reason, even though that would otherwise be my first choice for a retractable. |
Maule Driver wrote:
Just to add another thought.... (I have limited Mooney experience/knowledge) operating occasionally on grass may be different than basing on grass. You will always have 'bad' grass days on occassion if you base on it. Given the need to go or get home, you will be sorely tempted to operate on such days (i.e. mud, soft, or uncut). Another issue may be insurance if you are basing on grass. I live on 3400' of grass with trees on both ends and would never consider owning a Mooney for that reason, even though that would otherwise be my first choice for a retractable. Another data point, FWIW. I've never landed my J model on grass, but have taxied on some pretty rough grass on a couple of occasions, like getting from the runway to my camp site at OSH. I'm always nervous about it, but have yet to see any damage. Limited data, 'cause it's not something I do very often. I may just have been lucky. I'm still going to be nervous when I do that. Dave |
On 15 Aug 2004 11:08:58 -0700, (Robert M. Gary) wrote: I'm interested in your landing on gravel and beach experiences. We've got a temporary gravel taxiway in place here in EPM (while the main taxiway is being reconstructed), and I've been unwilling to even taxi on it for fear of picking up the stones with the prop. Could you tell me more about those surfaces you've been on? The beach was Alphonsinas in Baja. The beach is actually quite hard and as long as you avoid the pot holes left by the trucks driving on it, its almost like landing on a hard surface. I use a technique for softfield in the case of the beach or gravel. I choose the best spot for the mains when I do my low pass. On short final I trim the trim all the way back and push forward on the yoke to hold attitude (the Mooney is unusual in that back trim actually increases the available back elevator authority). Once the mains hit (with the nose very high) I add in some power and can hold the plane on the mains with the nose very high. Once I find where I want the nose to be, I chop the power. For takeoff, I do similar. I run the trim all the way back (or 3/4 if back pax). Hold full back elevator. The nose will pop up pretty quick on the take off roll (most people have never seen a Mooney's nose pop up before ). You must be comfortable driving around on only themains because the plane isn't anywhere near flying speed. The goal is to keep the prop as high as possible. I always practice soft field techniques before going down to Mexico. Most Mooney pilots just land normal so I'm not sure the condition of their props and gear in Mexico. -Robert |
| Thread Tools | |
| Display Modes | |
| Mooney drops into my backyard | Dave Butler | Owning | 41 | May 11th 04 11:19 PM |
| 10 1/2 Acres Hill Top, 8 miles from Mooney - airport, Kerrville, Texas | David | Aviation Marketplace | 0 | March 17th 04 01:44 AM |
| Mooney info | eddie | Owning | 13 | March 12th 04 07:42 PM |
| Mooney to Offer Light Sport Airplane | Rick Pellicciotti | Home Built | 4 | September 24th 03 02:08 PM |
| Cirrus vs Mooney | Charles Talleyrand | Owning | 6 | July 9th 03 12:35 AM |
