"dual magneto"
Old November 2nd 04, 07:30 AM
Kai Glaesner
Default "dual magneto"
Hello,
reading the "no RPM drop..." thread gave rise to a question: what is the
benefit (if there is any) of the "dual magneto" (two magnetos in a single
housing) installation? Should these kind of installation be preferred, or
avoided (if there is a choice ;-)?
Thanks in advance for the answer..
Regards
Kai
Return address is invalid to help stop junk mail.
Old November 2nd 04, 04:07 PM
Ron Natalie
While the mechanical drive to a magento can fail, it's not a likely failure.
The main reason there are two magenetos is not so much that the magnetos
themselves fail often, but something in the entire ignition system connected
to that magneto fails. Since magneto's are pretty weak sparks, the usual
culprit is some fouling of the spark plug.
Old November 2nd 04, 05:10 PM
Dan Thomas
"Kai Glaesner" wrote in message . com...
Hello,
Regards
Kai
The dual mag leaves more room on the accessory case for other
stuff like vacuum and fuel pumps and so on. The drawbacks include more
difficult maintenance, as the two mags must be timed in accordance
with each other, and if the timing's off the mag has to come off and
be opened up to reset it. With two separate mags it's a matter of
loosening whichever mag is off and rotating it a bit to get it into
agreement with the other and with the engine. Further, these mags are
often on engines in tight compartments, surrounded by hoses and cables
and wires and sharp pointy things (like safety wire) and engine mount
tubes and other accessories and shoved up against the firewall, making
life unpleasant for the mechanic. We have one on a 182RG and I dislike
it intensely.
The other drawback is the single drive. There was an AD years
ago against the impulse drive springs in these things; they'd corrode
and fail, retarding the timing on both mags to TDC or worse, and the
power would drop to some useless value. Occasionally we hear of
another one quitting and remember that lots of owners are ignoring ADs
at their peril.
Dan
Robert M. Gary
Hello,
They should be avoided. They have a nasty problem of falling off.
Mooneys and Arrows have had this problem. Most have since been change
over to two different mags. I think the benefits were easier
installation and less area to pressurize (for those mags that are
pressurized).
-Robert
Old November 2nd 04, 08:56 PM
Ray Andraka
another consideration is that the LASAR electronic ignition cannot be fitted to
engines with the two-in-one dual mag. It is only available for separate mags.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Impulse Coupling on Magneto Kai Glaesner Owning 5 October 3rd 04 05:10 AM
definition of "dual controls" Lee Elson Instrument Flight Rules 4 April 24th 04 02:58 PM
Beech dual yoke w/rams horns/color preference Dan Karshin Aviation Marketplace 1 March 28th 04 05:04 PM
First couple hours of real CFII dual given.... Blaine Instrument Flight Rules 17 January 15th 04 05:48 PM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 03:01 AM
