Well had my 1st oil change today. Have owned the 1964 172E for just 25
	hours. When the filter was cut open we found a few small slivers of Aluminum. When I bought the plane the pre-buy inspection was a complete annual and the mechanic didn't mention any "aluminum in the oil" so apparrantly this just started. What is the likely source of this aluminum? The mechanic suggested that I fly for 10 hours and change the oil again to see if the problem goes away. Anyone seen a situation where aluminum in the oil was a one time thing? signed "Not having a good day"  |
			 Gary Wilcox wrote: When I bought the plane the pre-buy inspection was a complete annual and the mechanic didn't mention any "aluminum in the oil" so apparrantly this just started. If the previous owner changed the oil and filter just before your pre-purchase, there wouldn't be any particles in the filter for your A&P to find. Check the engine log book. Assuming that an oil change was made and that the change was properly logged, you'll know whether it just started or not. What is the likely source of this aluminum? Don't know that one. Most of the critical components such as bearings, cylinder sleeves, wrist pins, etc. are not aluminum. I'd say that's encouraging. If I had to guess, I'd say that a bearing is loose and eating away at it's housing, but that usually makes a good deal of noise. The mechanic suggested that I fly for 10 hours and change the oil again to see if the problem goes away. Stay close to home. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it.  |
	The O-540 in our Pathfinder was making metal at the pre-buy inspection. It turned out to be aluminum from the piston pin plugs, and the amounts we found convinced us to slash our purchase offer, and put in a new engine when it was accepted. (BTW: The new piston plugs are made of a harder alloy that won't spall, supposedly.) If you found a "few slivers" that's not abnormal. If there are a lot of slivers, and you're flying a C-172 with the H2AD engine, you may have some serious trouble brewing. (That engine was known for making metal, although the latest oil additives supposedly have alleviated this problem.) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination"  |
How many years has it been since the engine was overhauled?
	They hate sitting around. Karl  |
"Gary Wilcox"  wrote in message ..  .
	What is the likely source of this aluminum? The mechanic suggested that I fly for 10 hours and change the oil again to see if the problem goes away. Though I've never personally had that problem, I know a few that have. In every case, the source of aluminum was the piston pin plugs. John Galban=====N4BQ (PA28-180)  |
A possible guess based on experience from a C-150 which has the same
	cylinders - It could be a wrist pin end plug scrubbing the cylinder wall. This was caused by a loose (i. e. floating) wrist pin rod bushing. A C-150 of ours always had produced a very small amount of aluminum which our mechanic condemmed as having a lemon engine. On teardown we found one wrist pin bushing loose in the rod end, & that mechanical rectification was causing the wrist pin end to scrubb slightly on the cylinder wall. I suspect the bushing had been cracked loose during a previous disassembly. We redid it with Millenium cylinders & a new rod of course. It has been good ever since. It now is again at or beyond TBO.  |
On Tue, 2 Nov 2004 16:36:16 -0600, "Gary Wilcox"
	wrote: What is the likely source of this aluminum? The mechanic suggested that I fly for 10 hours and change the oil again to see if the problem goes away. Be careful about flying with visible metal in the filter. I had a similar problem with my O360. Metal in the filter and I grounded the airplane. My AP said nearly the same thing as yours, but suggested that we look in the finger screen that is right before the oil pump first. Pulled that and there were thumbnail sized pieces of Al in it. So many large chunks that it was nearly plugged its whole length (~4"). We started pulling jugs and found that the back bosses of one piston (that provide support for the wrist pin) were nearly all broken out! I hate to think what might have happened if I did fly a few more hours.... My suggestion is to check the screen (not very hard to do) before you fly. Anyone seen a situation where aluminum in the oil was a one time thing? Not very likely. The piston/wrist pin plugs are about all there is to make Al. Good Luck, Jerry  |
			 Jerry Jesion wrote: Be careful about flying with visible metal in the filter. I had a similar problem with my O360. Metal in the filter and I grounded the airplane. I don't have a filter on my 470 just a screen. I only look at the screen once a year, at the annual. A couple years ago I started to lose the starter adapter. The shaft of the adapter shed some metal. We found that in the screen at the next annual. No way I automatically ground the plane because of a little metal. You have to find out what it is and then figure out why it's there. Some metal it doesn't matter.  |
			 I don't have a filter on my 470 just a screen. I only look at the screen once a year, at the annual. A couple years ago I started to lose the starter adapter. The shaft of the adapter shed some metal. We found that in the screen at the next annual. No way I automatically ground the plane because of a little metal. You have to find out what it is and then figure out why it's there. Some metal it doesn't matter. I disagree. AFAIK particles of metal large enough to see with the naked eye in the oil is not normal for any engine (with the possible exception of just after a major overhaul). IMHO to fly with an engine making metal is not a good idea. Especially if there is a constant speed prop. First find out what is going on before making any decision in this regard. j  |
I have the same engine and had the same symptom.  My mechanic changed oil and
	said fly it 10 more hours and we will re-check. When we re-checked, it was worse and it cost me $13,000 to get airworthy again. This was my second year of ownership. :-( www.Rosspilot.com  |
| Epoxy Bonding to Aluminum and Magnesium | Ryan Young | Home Built | 25 | September 16th 04 03:45 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
