			#11
Bruce Cunningham wrote:
	the cure is sometimes that in the rear inspection covers on the sides of the tail in front of the stabilator, they have a edge bent outward to scoop air into the tail and keep exhaust out. These scoops or inspection plates have to be mounted with the scoop facing forward so that they face the airstream. People have installed the covers with the scoop facing down or backwards, usually after an annual etc., and then they start getting CO in the cabin. Are these the round inspection plates like those one finds all over the airplane, or something different? Is the "scoop" really noticable, or a slight bending? - Andrew  |
Andrew Gideon  wrote in message   gonline.com...
	Bruce Cunningham wrote: the cure is sometimes that in the rear inspection covers on the sides of the tail in front of the stabilator, they have a edge bent outward to scoop air into the tail and keep exhaust out. These scoops or inspection plates have to be mounted with the scoop facing forward so that they face the airstream. People have installed the covers with the scoop facing down or backwards, usually after an annual etc., and then they start getting CO in the cabin. Are these the round inspection plates like those one finds all over the airplane, or something different? Is the "scoop" really noticable, or a slight bending? - Andrew Yes they are. They are a combination scoop/inspection cover. The scoop is about a 1/4 inch high outward joggle of the inspection plate just in front of the stabilator. The open part must face the airstream, that is, forward. There is one on each side. I don't know if 182s have this. I think maybe some 210s do. If your plane is supposed to have them and doesn't, in all likelyhood that is the problem. The scoop is a Cessna part and can be ordered. It was the fix Cessna found when CO was an issue on the Cardinal RG, maybe other models. My fixed gear Cardinal does not have them. The exhaust, flow around the fuselage, and openings are different so it doesn't need them. I sent you an email with photos of a plane both with and without the scoops. Hope that's you're problem. It will be easy to fix if it is. Guys have spent months and thousands of dollars to find a leak when this was the problem. In some instances, all it took was 5 minutes to turn the scoops in the right direction, as they don't work if they're not, in fact they sometimes make it worse. Regards, Bruce Cunningham N30464  |
	Our Cessna R182 is getting CO in the cockpit. We've now had three different shops look at it multiple times, all to no (complete) effect. They've done things like resealing the firewall, the gear-wells, the exhaust, and the like. But still we get CO. We've swapped CO detectors around between planes, so the detectors' results are trusted. One interesting oddity: turning cabin heat on does seem to get rid of the CO. We've noticed no difference made between type of flight. I personally have had readings both while XC and while maneuvering (practicing commercial maneuvers), and at various altitudes. Others have reported the same. At this point, we're at something of a loss. The next thing we're trying is to extend the exhaust pipe. The presumption is that this would get the CO into the slipstream and away. Extending the exhaust pipe is asking for trouble. There have been a few exhaust systems failures, and at least one fatal crash, that have been caused by extending the pipe. The added mass changes the vibration characteristics of the system, with the extra weight causing more flex in the pipes near the cylinders as the engine rocks, and breakage can occur. A busted system inside the cowl is really bad. Find the entry point. You might note lead stains around the inside of the entry inside the fuselage. 100LL has lots of lead and we've found entry points that way. Dan  |
That's raises an interesting point.  With 100 LL having so much lead, is
	there also a problem of chronic lead poisoning over a long time from a small amount of exhaust getting into the cabin? Obviously it's not an acute problem, but what about over time? -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney to love America "Dan Thomas" wrote in message om... Find the entry point. You might note lead stains around the inside of the entry inside the fuselage. 100LL has lots of lead and we've found entry points that way. Dan  |
Check for any cracks at the joint of the pipe and the flange that bolts
	to the head. Also at the joint between the muffler and the riser if you have one. "Andrew Gideon" wrote in message online.com... Our Cessna R182 is getting CO in the cockpit. We've now had three different shops look at it multiple times, all to no (complete) effect. They've done things like resealing the firewall, the gear-wells, the exhaust, and the like. But still we get CO. We've swapped CO detectors around between planes, so the detectors' results are trusted. One interesting oddity: turning cabin heat on does seem to get rid of the CO. We've noticed no difference made between type of flight. I personally have had readings both while XC and while maneuvering (practicing commercial maneuvers), and at various altitudes. Others have reported the same. At this point, we're at something of a loss. The next thing we're trying is to extend the exhaust pipe. The presumption is that this would get the CO into the slipstream and away. But that "presumption" is really more of a "guess" or even a "hope". Anyone have any suggestions or ideas or experiences that might help us? Thanks... Andrew  |
OtisWinslow wrote:
	Check for any cracks at the joint of the pipe and the flange that bolts to the head. Also at the joint between the muffler and the riser if you have one. *Everything* forward of the firewall has been checked, and much of it resealed, a couple of times. That's why I'm looking for something "else". But thanks... Andrew P.S. Since we're on the subject, though: "the head" of what?  |
			 "Andrew Gideon" wrote in message online.com... OtisWinslow wrote: Check for any cracks at the joint of the pipe and the flange that bolts to the head. Also at the joint between the muffler and the riser if you have one. *Everything* forward of the firewall has been checked, and much of it resealed, a couple of times. That's why I'm looking for something "else". But thanks... Andrew P.S. Since we're on the subject, though: "the head" of what? Cylinder head? doh! allen  |
"Bob Chilcoat"  wrote in message ...
	That's raises an interesting point. With 100 LL having so much lead, is there also a problem of chronic lead poisoning over a long time from a small amount of exhaust getting into the cabin? Obviously it's not an acute problem, but what about over time? Probably some risk involved, but the monoxide is a much more immediate risk so that long-term exposure to lead isn't an issue: you'll die in a crash before the lead gets you. I suppose we'll see leaded fuel disappear from aviation sooner or later anyway. Dan "Dan Thomas" wrote in message om... Find the entry point. You might note lead stains around the inside of the entry inside the fuselage. 100LL has lots of lead and we've found entry points that way. Dan  |
Andrew Gideon wrote:
	OtisWinslow wrote: Check for any cracks at the joint of the pipe and the flange that bolts to the head. Also at the joint between the muffler and the riser if you have one. *Everything* forward of the firewall has been checked, and much of it resealed, a couple of times. That's why I'm looking for something "else". The only time I get CO in the Navion cockpit is when sitting on the ground with the canopy open pointed into the wind.  |
			 I thought I'd let you all know what's going on. First, a mechanic with whom we checked claimed to be familiar with the Cardinal's scoops, and said that the R182 had no such thing. Given that the tail structure of the Cardinal is so different from other Cessnas, apparently, this isn't too surprising. But I have to admin: I'm still not completely certain. However, we've had the extensions installed (although I've yet to see them; the airplane pulled out as I arrived at the airport yesterday). The airplane has flown 6.9 tachometer hours since then, and has been showing a steady zero reading on the CO detector. So...it looks good at the moment. - Andrew  |
| Thread Tools | |
| Display Modes | |
| Thanks for ideas on drilling a centered hole! | Scott | Home Built | 12 | October 25th 04 03:52 AM |
| Speech: Air Power: The Men, Machines and Ideas | Otis Willie | Military Aviation | 0 | May 8th 04 12:25 AM |
| Mystery avionics identification??? | Steve | Owning | 3 | March 15th 04 07:41 PM |
| About German Mystery Objects | Erich Adler | Military Aviation | 85 | February 22nd 04 03:10 AM |
| Eurofighter weapon load mystery | John Cook | Military Aviation | 2 | January 27th 04 11:01 PM |
