Compression readings
Old December 9th 04, 12:37 AM
Default Compression readings
On a Lycoming O-550, at what compression reading would you start to consider
doing a top or complete overhaul?
Old December 9th 04, 01:28 AM
Orval Fairbairn
In article . net,
What is a "Lycoming "IO-550"? I know what a lycoming IO-540 is and what
a Continental IO-550 is, but -- a "Lycoming IO-550"??
Old December 9th 04, 02:10 AM
Newps
Anybody who decides to do a complete overhaul because of low compresion
reading/s is a moron. Why is the compression low? How many hours on
the engine, etc? I bought my 182 6.5 years and 900 hours ago with 500
SMOH. My mechanic and I have since learned that the overhaul by Mid
States in Tulsa wasn't a very good one. I have had 5 of my 6 cylinders
off over the years, but just once each. It's always the valves. You
fix them and move on. Perhaps this is why Mid States is no longer in
business. No way I do a complete top much less a complete overhaul just
for bad valves. The occasional oil analysis always comes back normal.
Old December 9th 04, 03:55 AM
kage
" wrote in message
ink.net...
consider
There is no such engine.
KG
Old December 9th 04, 10:02 AM
markjen
I agree. Compression readings are just one indicator of engine health,
along with history, oil analysis, long-term trends, etc. And some engines
are notorious for low compressions now and then - if you did a top overhaul
every time a cylinder dipped below 60, you'd never get a year without
pulling a cylinder. There is no such thing as a magic number that it a
go/no-go for doing a top.
- Mark
Old December 11th 04, 01:57 AM
Fly
Dear Mr. ygaabofm
Sorry we couldn't help you. Have you tried asking NASA?
" wrote in message
nk.net...
All these replies and not one serious answer.
Let me rephrase the question.
On the Big Lycoming engines, at what compression reading would indicate a
need for an investigation. In other words, what compression reading is
considered a warning sign?
ygaabofm
"kage" wrote in message
" wrote in message
ink.net...
consider
KG
Old December 13th 04, 12:33 AM
First of all, thank you for answering the question.
Secondly, the first answers were not serious because it was obvious from the
answers that they did understand the question, and chose not to answer it.
There were some pretty detailed answers but none gave at what reading would
one start considering the cylinder a problem.
"Newps" wrote in message
They were serious, now you ask the proper question.
a
It depends. If the reading isn't in the mid 70's or above on a
particular cylinder then find out where the air is escaping and fix
accordingly. If the reading was zero you still wouldn't necessarily
overhaul the engine.
Old December 13th 04, 12:34 AM
No. Have you tried posting something useful?
"Fly" wrote in message
Dear Mr. ygaabofm
" wrote in message
nk.net...
a
ygaabofm
" wrote in message
ink.net...
consider
KG
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 09:11 PM
Compression Tests Doug Owning 10 March 27th 04 07:17 PM
Compression Tests Doug Aerobatics 4 March 27th 04 06:29 AM
Compression Tests Doug General Aviation 5 March 27th 04 06:29 AM
0200A Higher Compression Cylinders? Boelkowj Home Built 3 December 16th 03 03:25 PM
