Fat Albert the Apache needed his annual exam... When I bought him the
	annual was in the summer and I have been gaining a month a year on that... This year we moved it into December 1st... The annual usually takes 3-5 days, but this morning he still sits in the shop with the starboard engine uncowled after 3 weeks... I have been proactive in doing preventive maintenance between annuals and normally we breeze through the annual... This year there were two AD's that needed to be satisfied... One was the flap torque arm and torque tube... This is pretty straight foward... We pulled them out (labor hours) and although they were perfect the AD is recurring annually as long as the original parts remain... I ordered the steel torque tube (~1.5" x 36")to replace the aluminum tube and it was $400 (hey, it's for an airplane)... The torque arm however was a nine inch long, $1600 item for something that any competent machine shop would make from scratch for $40 in material and a $150 in labor and CNC machine time - Piper's price is big time rape! Steve, the mechanic, was really po'd at Piper over this part... He finally found a serviceable part from a wrecked plane that met the AD and was available for 50% of new, so we went that route... The other AD was the pressure test on the heater can... Of course it has a small crack, but worse it had been welded before (no entry on the logs) so it was DOA... Plus the Southwind heater would continue to be a recurring AD... The heater shops wanted $1800 to zero time the heater, plus $650 to replace the solenoid fuel valves... A search was started and we wound up with C&D which is just downstate from us... They have PMA for a brand new heater which wound up being $3200 by the time it was delivered... The big labor costs in this are the install and the new panel switch and wiring.. But, I have a no AD heater, which is new and shiny and has a warranty... Next on the hit list was that the port engine backfired when I started it up to fly over to the shop for the annual, ran rough for 10 seconds then smoothed out (picture me with raised eyebrow and cringing wallet) it has never done this before... When we got to the shop the first thing we do is a compression test while the engine is hot... #1 cylinder on port side has zero compression... Pull the rocker cover and sure enough the exhaust valve lacks about a sixteenth of an inch of closing... So, Steve drives the valve out, reams the guide (carbon buildup, no warpage) and reassembles... Borescopes the cylinder and pressure tests again, all OK now... So more bucks for labor... The other item on the hit list was that the starboard engine has been gradually running leaner over a period of months.. In cruise the starboard mixture knob is now an inch and a half ahead of the port mixture knob for the same egt... It has been looked at twice with no obvious leaks... With the engine totally uncowled we go after it with a vengence... The induction hoses and clamps are replaced with new, and all new intake gaskets... Pressure testing shows bubbles where the induction tube for the #1 cylinder is pressed into the oil pan... This is sealed up... The engine is test run, and the cowl is replaced... Annual is finished and I'm to test fly it... The flight delivers no joy with the starboard engine still considerably leaner than the port engine, even at full rich on both mixtures... Ah jeez! So, back in the shop, off with the cowlings (half an hour for two mechanics), and we start glaring at the carburetor... The throttle shaft has some slop in it, but the throttle shaft on the port engine, which runs fine, is looser still - and we don't think that is the problem... After considerable peering and poking and wiggling we (three of us by now) decide that the shaft on the mixture has too much play... So off comes the carburetor (more labor time as it is well buried... Up on the bench we disassemble the carb... The mixture shaft is worn and the brass washers show eccentric wear... A parts count and comparison to the manual shows an O-ring is totally missing... This could upset the air pressure above the fuel at the main metering valve down in the bowl... OK, so we stop for the night... The next day Steve calls Lycoming and talks to their carb expert... He opines that the air leak around the mixture shaft will cause the engine to run lean... He wants $450 for a rebuild kit... A call to avial shows that they want $1000 for a rebuilt carb... I say let me think about it and go home... A bit of skulking on the web brings up aircraft spruce as having a rebuilt carb in stock for $529... It is ordered, next day air for an extra 40 some bucks... The carb is put on, the engine test run, cowl put on, and the plane is ready for a test flight... So, I hurry through the office Saturday and manage to get in a days work and be out to the airport with daylight left... Everyone is all smiles, so in anticipation of delivering the plane back to the home field it is fully fueled, etc.. The wind is from the same side of the field as the shop, so we have to taxi 3/4 of a mile.. By the time I get to the runup pad the starboard engine is wallowing and slowly winds down and quits... Pat, the mechanic, who is in the right seat peers out and says, hmmm there's fuel dripping off the cowl... (&*%#$@ bad word said) We limp back to the shop on one engine (twins taxi terrible on one engine)... Testing at the shop shows fuel running through the carb... Off come the cowls and the carb... Monday morning (today) Kelly Aerospace is called and the problem discussed... They want the carb back for examination and will ship me a replacement carb same day as mine arrives there... So here we go with a round of $60+ next day shipping charges... I was going to wait until the annual was over to post this, but who knows when that will be... Anyway, the fun meter has passed $9,000 and is still running... Cheers... Denny of the Lean Wallet, and Fat Albert the Apache  |
Dang, sorry to hear about the carb problems... hopefully when you get them
	resolved it will make flying FA feel a little sweeter. Glad the torque tube issue didn't turn out that bad, I've heard some horror stories about not getting the replacement drilled correctly. Merry Christmas, Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.799 / Virus Database: 543 - Release Date: 11/21/2004  |
Yup Jim.... I told Steve that if he misdrilled that tube HE was paying
	for the replacement and the shipping and labor was on his nickle, not mine... When I got back to the shop a day later it was all installed... I asked him how the drilling went... He pulled his pipe out of his mouth, scowled at me, and said, "What a ^&%$*# miserable job... I spent 2 hours getting that thing jigged up and drilling four holes... But that's OK because I'm charging for the time!"... Then he smiled an evil smile and lit his pipe and walked away contentedly blowing clouds of evil smoke... I discussed his ancestry, just loud enough for him to hear... That made him really smile... Actually, if I didn't insult him, I suspect he would charge me more... Steve is an old time A&PI with decades of experience on Apaches and Aztecs... I had no reservations about his ability to do the job right the first time...  |
HA!  He sounds like a combination of Santa Claus and the Grinch!  Too funny!
	Glad he got it all installed for you. I wish we had more A&P's like him around here, most of them here don't have nearly that much experience, patience, or stick-with-it-ness but they sure know how to charge! You mentioned that C&D is just downstate from you... what part of MI are you in? I'm planning on flying over to Hastings (just south east of GRR) Christmas Eve and back to WI Christmas day. How much snow is there in that area? We got about 8 inches here last night. Jim "Denny" wrote in message oups.com... Yup Jim.... I told Steve that if he misdrilled that tube HE was paying for the replacement and the shipping and labor was on his nickle, not mine... When I got back to the shop a day later it was all installed... I asked him how the drilling went... He pulled his pipe out of his mouth, scowled at me, and said, "What a ^&%$*# miserable job... I spent 2 hours getting that thing jigged up and drilling four holes... But that's OK because I'm charging for the time!"... Then he smiled an evil smile and lit his pipe and walked away contentedly blowing clouds of evil smoke... I discussed his ancestry, just loud enough for him to hear... That made him really smile... Actually, if I didn't insult him, I suspect he would charge me more... Steve is an old time A&PI with decades of experience on Apaches and Aztecs... I had no reservations about his ability to do the job right the first time... --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.820 / Virus Database: 558 - Release Date: 12/20/2004  |
Repeat slowly and carefully after me:
	The owner or operator of an aircraft is allowed to manufacture parts for his/her own aircraft. Say it again. Understand that you do not have to have your hand on the drill press or CNC buttons. The FAA is satisfied that you take a drawing down to your local machine shop and oversee their manufacture of your part. Or you can make it yourself, your choice. Now, say it one more time... Jim "Denny" wrote in message oups.com... The torque arm however was a nine inch long, $1600 item for something that any competent machine shop would make from scratch for $40 in material and a $150 in labor and CNC machine time - Piper's price is big time rape! Steve, the mechanic, was really po'd at Piper over this part... He finally found a serviceable part from a wrecked plane that met the AD and was available for 50% of new, so we went that route...  |
			 "RST Engineering" wrote in message ... Repeat slowly and carefully after me: The owner or operator of an aircraft is allowed to manufacture parts for his/her own aircraft. Say it again. Understand that you do not have to have your hand on the drill press or CNC buttons. The FAA is satisfied that you take a drawing down to your local machine shop and oversee their manufacture of your part. Or you can make it yourself, your choice. Now, say it one more time... Jim You're an A&P with inspection authorization, aren't you? Please cite the FAR. I think I know which one you're talking about but it seems you'd be more authoritative by referring to the book. "Denny" wrote in message oups.com... The torque arm however was a nine inch long, $1600 item for something that any competent machine shop would make from scratch for $40 in material and a $150 in labor and CNC machine time - Piper's price is big time rape! Steve, the mechanic, was really po'd at Piper over this part... He finally found a serviceable part from a wrecked plane that met the AD and was available for 50% of new, so we went that route...  |
			 " jls" wrote in message ... "RST Engineering" wrote in message ... Repeat slowly and carefully after me: The owner or operator of an aircraft is allowed to manufacture parts for his/her own aircraft. Say it again. Understand that you do not have to have your hand on the drill press or CNC buttons. The FAA is satisfied that you take a drawing down to your local machine shop and oversee their manufacture of your part. Or you can make it yourself, your choice. Now, say it one more time... Jim You're an A&P with inspection authorization, aren't you? Please cite the FAR. I think I know which one you're talking about but it seems you'd be more authoritative by referring to the book. "Denny" wrote in message oups.com... The torque arm however was a nine inch long, $1600 item for something that any competent machine shop would make from scratch for $40 in material and a $150 in labor and CNC machine time - Piper's price is big time rape! Steve, the mechanic, was really po'd at Piper over this part... He finally found a serviceable part from a wrecked plane that met the AD and was available for 50% of new, so we went that route... http://www.avionicswest.com/myviewpo...owner.htm#2004 http://www.iflyamerica.org/ownerproducedparts.htm http://www.faa.gov/avr/afs/news/arch...2002/Parts.htm http://www.faa.gov/avr/afs/news/arch...gust/IvsWe.htm My only question? Why are some links blue, and some purple? Karl "Curator" N185KG  |
			 "kage" wrote in message ... " jls" wrote in message ... "RST Engineering" wrote in message ... Repeat slowly and carefully after me: The owner or operator of an aircraft is allowed to manufacture parts for his/her own aircraft. Say it again. Understand that you do not have to have your hand on the drill press or CNC buttons. The FAA is satisfied that you take a drawing down to your local machine shop and oversee their manufacture of your part. Or you can make it yourself, your choice. Now, say it one more time... Jim You're an A&P with inspection authorization, aren't you? Please cite the FAR. I think I know which one you're talking about but it seems you'd be more authoritative by referring to the book. "Denny" wrote in message oups.com... The torque arm however was a nine inch long, $1600 item for something that any competent machine shop would make from scratch for $40 in material and a $150 in labor and CNC machine time - Piper's price is big time rape! Steve, the mechanic, was really po'd at Piper over this part... He finally found a serviceable part from a wrecked plane that met the AD and was available for 50% of new, so we went that route... http://www.avionicswest.com/myviewpo...owner.htm#2004 http://www.iflyamerica.org/ownerproducedparts.htm http://www.faa.gov/avr/afs/news/arch...2002/Parts.htm http://www.faa.gov/avr/afs/news/arch...gust/IvsWe.htm My only question? Why are some links blue, and some purple? Karl "Curator" N185KG Well, now, if you ain't just a gentleman and a scholar. Thanks. I figured that authority was somewhere in Part 23.  |
			 kage wrote: My only question? Why are some links blue, and some purple? Usually this is because you have set your browser to display links you haven't visited recently as blue text and those you have visited recently as purple. These are the default colors for Netscape. I believe the default for "recently" is 10 days. Both the colors and the retention period are settable parameters. George Patterson The desire for safety stands against every great and noble enterprise.  |
			 jls wrote: You're an A&P with inspection authorization, aren't you? Please cite the FAR. I think I know which one you're talking about but it seems you'd be more authoritative by referring to the book. Karl has posted links. To do Jim justice, Jim has posted the applicable regs before. George Patterson The desire for safety stands against every great and noble enterprise.  |
| Giving thanks this Christmas, by Phill Coleman | Otis Willie | Naval Aviation | 0 | December 18th 04 06:52 AM |
| Annual Report Final. "Long" | NW_PILOT | Owning | 20 | October 28th 04 08:20 PM |
| Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 04:41 PM |
| Another Almost Annual Christmas Poem!!! | David Pincus | Home Built | 4 | December 28th 03 01:47 PM |
| MERRY CHRISTMAS | JSH5176 | Military Aviation | 0 | December 13th 03 06:12 AM |
