Hand Adjustable Reamer?
Old March 18th 04, 04:01 PM
Boelkowj
Default Hand Adjustable Reamer?
Can anyone recommend a good expandable type reamer (brand name) for aircraft
work? All I need to do is ream out an elongagted hole a few thousands of an
inch but since it is an aft wing attach fitting and the bolt needs to be a
tight fit. I have seen adjustable reamers range from $20 to $60 (5/16-3/8 in
range). What are the differences? This is a one time job but I want to do it
right. I have been told that a straight flutted reamer would probably be too
big by 2-3 thousands as this will be a in field in situ job and alignment is a
problem since need to go thru 3 holes (sandwich plate and tongue) in one
direction. Thank you.
Larry
Old March 18th 04, 04:19 PM
Rich S.
"Boelkowj" wrote in message
aircraft
an
in
it
too
is a
You might consider buying the next larger size straight fluted reamer and
have it resharpened to the exact size you require. Boeing Surplus has them
for $2.00/lb. last I looked.
Rich S.
Old March 19th 04, 03:06 AM
marge
Try ENCO they have some adjustable reamers cheap along with a lot of other
machine tool stuff from China
jim
Boelkowj wrote in message
aircraft
an
in
it
too
is a
Larry
Old March 19th 04, 10:01 PM
Bob Chilcoat
Here's a cheap set (mine were made in India) that covers a lot of ground.
Be careful, though; the blades seem to be too hard. I've shattered them in
one of mine. Naturally the most useful size.
http://www.harborfreight.com/cpi/cta...emnumber=38577
Bob (Chief Pilot, White Knuckle Airways)
"Roger Halstead" wrote in message
aircraft
an
a
in
do it
too
is a
Man... I used to use the things on a regular basis when working as an
instrument technician. I haven't touched one since 87 and can't for
the life of me remember the manufacturer.
I'd just get a good machine tool catalog and look up the brand names.
The ones we used were expensive.
They were adjustable by a small strew in the end. One turn was good
for just a few ten thousandths.
I'd like to have a set of them. I'd like to have a full set of reamers
... and a mill ... and a lathe... and....
www.rogerhalstead.com
Larry
