Gary Drescher wrote: That's pretty cool. Even more straightforwardly, if you have a spare headset and intercom station, you can just give the recorder its own headset, pressing the two ear pieces together with the recorder in between. Would the "pilot isolate" or "crew isolate" feature interfere with that? George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
"Glenn Westfall" wrote in message
Would this work? Plug in a headphone adapter that goes from the big size to the small walkman size in an unused intercom jack. Run an extension cable from the adapter to the mic in on a recorder or video camera. Not necessarily. You have to consider the impedance differences. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
"Glenn Westfall" wrote in message ... On Thu, 22 Jan 2004 13:17:58 GMT, "Chuck" snip Glenn, Not an answer to your question, but are you in Ft. Worth? No...I am in Okinawa at the moment. I am from Southern CA. OK... I worked with a Glenn Westfall until about 6 months ago... Just checking... |
I did exactly that with my Sony TRV18 Digital camera. It works like a chram.
If you mount the camera in the back seat, just make sure you have it high enough to almost hit the roof. Otherwise you will see nothing but the panel. It's good to see the runway. Marco "Glenn Westfall" wrote in message ... After I posted this message I started thinking about it. Would this work? Plug in a headphone adapter that goes from the big size to the small walkman size in an unused intercom jack. Run an extension cable from the adapter to the mic in on a recorder or video camera. That shoud do the trick correct? The headphone jack of aviation headsets are standard size and can be converted to the smaller size. On 22 Jan 2004 12:26:06 -0800, (Andrew Sarangan) wrote: "Ben Smith" wrote in message ... Assuming your aircraft has an intercom, you can make a direct-connect cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I've made one of these cables, and they work good. I don't mess with tapes, though. I bought an Olympus DM-1 digital recorder.. With the included 64MB Smart Media, it will record for 10 hours on best quality. Double that if you get a 128MB card. (Which is the max you can use). It also plays back MP3/WMA format music files too. Here's a small .wav clip from one of my recordings: http://tinyurl.com/2ycds I record all my flights with students using a tiny digital recorder. I have a very simple system that works wonderfully. You don't have to tap into the intercom system. It is so simple that I record every single flight, whether it is useful or not. I have written an article about the setup on my website. http://www.geocities.com/asarangan/aviation (and click on Cockpit Voice Recorders). Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Marco Leon wrote: "Glenn Westfall" wrote in message ... After I posted this message I started thinking about it. Would this work? Plug in a headphone adapter that goes from the big size to the small walkman size in an unused intercom jack. Run an extension cable from the adapter to the mic in on a recorder or video camera. That shoud do the trick correct? The headphone jack of aviation headsets are standard size and can be converted to the smaller size. It works great with Sony camcorders for sure, that's what I have. I have a length of elastic attached to the top of the glareshield. I put an unused sponge under that and set the camcorder on the sponge. The patch cord goes from the intercom jack to the audio in jack on the camera. The sponge serves two purposes. First it eliminates vibration and holds the camera in place. Second is it raises it up off the panel for a better view. I have found the ideal view is to have the top of the cowl just barely in the bottom of the frame for some perspective. Get a camera with the swing out viewfinder window, makes it very easy to make sure you are aiming at what you want. Make sure you adjust the camera so it will not focus on the windshield, all cameras have a distant focus setting. After that setup it works great. My next project is to try and find a weatherproof, wireless camera that can be attached to an inspection panel. Since I have no desire to try and get it approved I want to be able to remove it when I am not using it. If anybody has any ideas let me know. |
Cool. This is exactly what I want to do. I have a Sony camcorder and
have been video taping some flights, but wanted to have cockpit voices. I will give it a try and see if it works for me. Can you explain to me how you afix the camera to the panel? Or does it just sit atop the sponge? I am renting aircraft, so I can't do any permanent mounting. Thanks again, Glenn On Sat, 24 Jan 2004 00:00:13 GMT, Newps wrote: Marco Leon wrote: "Glenn Westfall" wrote in message ... After I posted this message I started thinking about it. Would this work? Plug in a headphone adapter that goes from the big size to the small walkman size in an unused intercom jack. Run an extension cable from the adapter to the mic in on a recorder or video camera. That shoud do the trick correct? The headphone jack of aviation headsets are standard size and can be converted to the smaller size. It works great with Sony camcorders for sure, that's what I have. I have a length of elastic attached to the top of the glareshield. I put an unused sponge under that and set the camcorder on the sponge. The patch cord goes from the intercom jack to the audio in jack on the camera. The sponge serves two purposes. First it eliminates vibration and holds the camera in place. Second is it raises it up off the panel for a better view. I have found the ideal view is to have the top of the cowl just barely in the bottom of the frame for some perspective. Get a camera with the swing out viewfinder window, makes it very easy to make sure you are aiming at what you want. Make sure you adjust the camera so it will not focus on the windshield, all cameras have a distant focus setting. After that setup it works great. My next project is to try and find a weatherproof, wireless camera that can be attached to an inspection panel. Since I have no desire to try and get it approved I want to be able to remove it when I am not using it. If anybody has any ideas let me know. |
Glenn Westfall wrote: Cool. This is exactly what I want to do. I have a Sony camcorder and have been video taping some flights, but wanted to have cockpit voices. I will give it a try and see if it works for me. Can you explain to me how you afix the camera to the panel? Or does it just sit atop the sponge? I am renting aircraft, so I can't do any permanent mounting. My plane has an avionics access panel on the top of the glareshield, about 8x6 inches, with screws all the way around to hold it down. I took a couple of ring terminals and put them under the screws. I tied knots in the end of the elastic and smashed the end around it. The camera sits on the sponge with the elastic band holding the camera down onto the sponge. Flip out the view finder, plug in the audio in and you are ready. Don't know what to tell you with a rental. |
Can you explain to me how you afix the camera to the panel? Or does it just sit atop the sponge? I am renting aircraft, so I can't do any permanent mounting. You could always use a tripod: http://www.tknowlogy.com/TknoFlyer/CockpitVideo.htm -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
Cool. This is exactly what I want to do. I made a patch cable to go from the intercom directly into my sony camcorder; it is a simple resistor divider level matcher. I mounted the camera on a tripod and bungeed the tripod down in the back of the 152 I trained in. I crank it up to the roof and it gives a great view, and the audio is excellent. It takes just a few seconds to install and remove too. |
| backup cockpit lighting | Josef Burger | Instrument Flight Rules | 35 | January 2nd 05 02:23 AM |
| Antonov vs Galaxy cockpit | Emilio | Military Aviation | 13 | July 2nd 04 07:15 AM |
| Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 06:32 PM |
| What are you guys using for cockpit lights these days? | Stealth Pilot | Home Built | 6 | December 9th 03 10:14 AM |
| FS DeHavilland Open Cockpit Chipmunk | [email protected] | Aviation Marketplace | 0 | October 14th 03 12:10 PM |
