Recording cockpit voices
Old January 22nd 04, 10:16 PM
G.R. Patterson III
Gary Drescher wrote:
That's pretty cool. Even more straightforwardly, if you have a spare
headset and intercom station, you can just give the recorder its own
headset, pressing the two ear pieces together with the recorder in between.
Would the "pilot isolate" or "crew isolate" feature interfere with that?
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 22nd 04, 11:02 PM
John T
"Glenn Westfall" wrote in message
Would this
work? Plug in a headphone adapter that goes from the big size to the
small walkman size in an unused intercom jack. Run an extension cable
from the adapter to the mic in on a recorder or video camera.
Not necessarily. You have to consider the impedance differences.
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old January 23rd 04, 03:18 AM
Andrew Sarangan
The impedance of the aircraft headsets are quite different than the
audio inputs of walkmans (I can't recall the numbers). You could use
an impedance matching network, but now things are starting to get
complicated.
Since I use the recorder for flight instruction, and since I fly a
dozen different aircrafts, I did not want to rely on tapping into the
intercom system. Every intercom is different, and what worked in one
airplane may not work in another. With my arrangement (condenser
microphone in the headset), it works in all airplanes equally.
If anyone wants to listen to the audio quality from my setup, I will
be happy to email you a clip.
(Glenn Westfall) wrote in message ...
After I posted this message I started thinking about it. Would this
from the adapter to the mic in on a recorder or video camera. That
shoud do the trick correct? The headphone jack of aviation headsets
are standard size and can be converted to the smaller size.
On 22 Jan 2004 12:26:06 -0800,
(Andrew
Sarangan) wrote:
"Ben Smith" wrote in message ...
Assuming your aircraft has an intercom, you can make a direct-connect
cable
using Gene Whitt's directions found he
http://tinyurl.com/36x3c
I've made one of these cables, and they work good. I don't mess with tapes,
though. I bought an Olympus DM-1 digital recorder.. With the included 64MB
Smart Media, it will record for 10 hours on best quality. Double that if
you get a 128MB card. (Which is the max you can use). It also plays back
MP3/WMA format music files too.
Here's a small .wav clip from one of my recordings:
http://tinyurl.com/2ycds
I record all my flights with students using a tiny digital recorder. I
have a very simple system that works wonderfully. You don't have to
tap into the intercom system. It is so simple that I record every
single flight, whether it is useful or not. I have written an article
about the setup on my website.
http://www.geocities.com/asarangan/aviation (and click on Cockpit
Voice Recorders).
Old January 23rd 04, 06:08 PM
Chuck
On Thu, 22 Jan 2004 13:17:58 GMT, "Chuck"
snip
Glenn,
Not an answer to your question, but are you in Ft. Worth?
No...I am in Okinawa at the moment. I am from Southern CA.
OK... I worked with a Glenn Westfall until about 6 months ago... Just
checking...
Old January 23rd 04, 10:16 PM
Marco Leon
I did exactly that with my Sony TRV18 Digital camera. It works like a chram.
If you mount the camera in the back seat, just make sure you have it high
enough to almost hit the roof. Otherwise you will see nothing but the panel.
It's good to see the runway.
Marco
On 22 Jan 2004 12:26:06 -0800, (Andrew
cable
tapes,
64MB
if
back
Voice Recorders).
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old January 24th 04, 12:00 AM
Newps
It works great with Sony camcorders for sure, that's what I have. I
have a length of elastic attached to the top of the glareshield. I put
an unused sponge under that and set the camcorder on the sponge. The
patch cord goes from the intercom jack to the audio in jack on the
camera. The sponge serves two purposes. First it eliminates vibration
and holds the camera in place. Second is it raises it up off the panel
for a better view. I have found the ideal view is to have the top of
the cowl just barely in the bottom of the frame for some perspective.
Get a camera with the swing out viewfinder window, makes it very easy to
make sure you are aiming at what you want. Make sure you adjust the
camera so it will not focus on the windshield, all cameras have a
distant focus setting. After that setup it works great. My next
project is to try and find a weatherproof, wireless camera that can be
attached to an inspection panel. Since I have no desire to try and get
it approved I want to be able to remove it when I am not using it. If
anybody has any ideas let me know.
Old January 24th 04, 02:06 AM
Glenn Westfall
Cool. This is exactly what I want to do. I have a Sony camcorder and
have been video taping some flights, but wanted to have cockpit
voices. I will give it a try and see if it works for me. Can you
explain to me how you afix the camera to the panel? Or does it just
sit atop the sponge? I am renting aircraft, so I can't do any
permanent mounting.
Thanks again,
Glenn
Old January 24th 04, 04:05 AM
Newps
permanent mounting.
My plane has an avionics access panel on the top of the glareshield,
about 8x6 inches, with screws all the way around to hold it down. I
took a couple of ring terminals and put them under the screws. I tied
knots in the end of the elastic and smashed the end around it. The
camera sits on the sponge with the elastic band holding the camera down
onto the sponge. Flip out the view finder, plug in the audio in and you
are ready. Don't know what to tell you with a rental.
Old January 24th 04, 02:01 PM
John T
Can you
permanent mounting.
You could always use a tripod:
http://www.tknowlogy.com/TknoFlyer/CockpitVideo.htm
John T
Old January 24th 04, 09:24 PM
John Harlow
I made a patch cable to go from the intercom directly into my sony
camcorder; it is a simple resistor divider level matcher. I mounted the
camera on a tripod and bungeed the tripod down in the back of the 152 I
trained in. I crank it up to the roof and it gives a great view, and the
audio is excellent. It takes just a few seconds to install and remove too.
backup cockpit lighting Josef Burger Instrument Flight Rules 35 January 2nd 05 01:23 AM
Antonov vs Galaxy cockpit Emilio Military Aviation 13 July 2nd 04 06:15 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
What are you guys using for cockpit lights these days? Stealth Pilot Home Built 6 December 9th 03 09:14 AM
FS DeHavilland Open Cockpit Chipmunk [email protected] Aviation Marketplace 0 October 14th 03 11:10 AM
