Block Allocation?
Old February 9th 04, 07:20 PM
AES/newspost
Default Block Allocation?
Listening to channel nine on UA 1225 Denver-Reno yesterday, I heard
something like:
"Denver Center, Jackpot 123, can we request a block allocation
for 39 to 41?"
and then
"Jackpot 123, Denver Center, block allocation 39 to 41 approved."
["Jackpot 123" is made-up name since I don't remember actual name; maybe
it was "block assignment" instead of "allocation"; and I don't recall if
the wording was "Flight levels 39 to 41" or just the numbers.]
Anyway, I'm assuming that "Jackpot 1243" wanted to move up and down
freely between 39,000 and 41,000 feet seeking smoothest ride and best
fuel economy without having to make repeated requests; and Denver Center
was willing to approve this since nobody else was up that high anyway.
Is that likely the case?
Old February 9th 04, 07:39 PM
Peter Duniho
"AES/newspost" wrote in message
Sounds like a "cruise clearance". Not sure why those words weren't used in
the request. There are any number of reasons to request a cruise clearance,
but a common one is if there's some sort of mountain wave action going on,
making it desirable to "go with the flow" as the wave alternately causes
ascents and descents.
2000' isn't a heck of wide range for that purpose, granted. But neither
would it be for the purpose of finding a smooth ride. Changing altitude
repeatedly isn't good for fuel economy, so I don't think that was the
purpose either.
Pete
Old February 9th 04, 08:08 PM
Newps
He asked for and received a block altitude. Controller phraseology
would be "Jackpot 123 maintain FL390 through FL410." Normally done at
this altitude for turbulence.
something like:
for 39 to 41?"
and then
Old February 9th 04, 08:34 PM
DALing
your analysis is essentially correct - they requested to be able to go FL
39-41 and in between without requesting additional clearance
something like:
for 39 to 41?"
and then
Old February 9th 04, 08:42 PM
Gary Drescher
in
the request.
According to the AIM P/CG, a cruise clearance permits flight from a single
specified altitude down to the minimum applicable IFR altitude; the
phraseology is e.g. "Cruise eight thousand". A block clearance, with an
explicit lower bound, is slightly different.
--Gary
Old February 9th 04, 08:57 PM
Ben Jackson
That is bizjet territory so you can probably get a pretty big block
without conflicting with traffic. I wonder what happens when a bus
requests 330-350...
Ben Jackson
http://www.ben.com/
Old February 9th 04, 10:09 PM
Andrew Sarangan
Cruise clearance allows you to operate freely between the specified
altitude and the minimum IFR altitude. If the lower limit is not the
MIA, then a block clearance is issued. At least that is my
understanding.
"Peter Duniho" wrote in message ...
purpose either.
Pete
Old February 9th 04, 11:23 PM
Frank Ch. Eigler
"Gary Drescher" writes:
in the request.
specified altitude down to the minimum applicable IFR altitude [...]
I believe a "cruise clearance" also implies an approach clearance, making it
even more different from an ordinary block altitude assignment.
- FChE
Old February 9th 04, 11:24 PM
Michael
Well, sort of but not quite. I think what he really requested was a
block altitude, which is the standard phraseology, and the goal was
not to intentionally change altitude but simply to avoid having to
correct the altitude all the time when turbulence changed it for him.
When a pilot requests a narrow block, it's usually because the ride is
unavoidably rough and he wants to be able to just hold a pitch
attitude rather than continually changing pitch and airspeed to
maintain altitude. It's easier on the airframe, easier on the
passengers, allows you to maintain a relatively constant airspeed so
it might be slightly more fuel efficient, and generally easier on the
pilot as well if he is hand-flying. I routinely ask for this when I
fly in convective weather, and so far I've always gotten it. Like
this pilot, I also generally ask for a 2000 ft block.
Michael
Old February 10th 04, 12:02 AM
G.R. Patterson III
It's more likely that they're encountering turbulence which makes it difficult
to maintain altitude.
George Patterson
Love, n.: A form of temporary insanity afflicting the young. It is curable
either by marriage or by removal of the afflicted from the circumstances
under which he incurred the condition. It is sometimes fatal, but more
often to the physician than to the patient.
New "Rhinos" on the block (& farewell to low-viz) [email protected] Naval Aviation 0 November 25th 04 08:24 AM
B-2 question Harley W Daugherty Military Aviation 37 August 27th 04 12:45 AM
Block out someone? (Little Hitler) Jeff Military Aviation 6 April 13th 04 07:03 PM
More Info on Block 52 F-16 robert arndt Military Aviation 0 November 18th 03 03:07 PM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 06:48 PM
