angry wrote:
	Yes, that's what I ment - the ATC put unnesesary pressure to the poor pilot. By playing the "authority" too much, he forced the pilot into taking his advice as one that is overriding, so the russian pilot flew into the other aircraft - this is why I call the ATC murderer. If the russian pilot had made a mistake, be it because of CRM issues or other, I could have said that he is a fool - but he is not. That's sad! There's no such thing as "playing authority" in the ICAO or JAA docs, the authority is either there or it's not. And the controller couldn't give an "overriding advice" - he didn't have anything to override, and there's no such thing as overriding an RA by ATC anyway. The controller acted based on the information available and the authority granted to him, and the BAL crew should've done the same. They hadn't, and killed their passengers, the other crew and themselves. It's sad allright. Dima  |
angry wrote:
	Absurd is to see people like you believe in the newspaper stories. And just where are you getting your information, considering that no official accident report has been released? I have enough knowledge to know that information from the media is suspect, particularly their opinions about what happened and who is at fault. The ATC did made a mistake by choosing wrong altitude to advice as so to avoid the collision. If the Russian plane had followed the ATC instruction, and the DHL plane had continued without descending, there would have been no collision. The ATC instruction was incorrect in hindsight, but given the conflicting information from the collision warning system, the Russian pilot should have ignored the ATC instruction. Had the pilot done so, there wouldn't have been a collision. You are saying that he was unaware of the other aicraft - that's absurd - he was the only one on duty and he had ALL the aicraft in his vicinity, their course, and their altitude displayed for him to make a decision. He was late in asking the Russian plane to change altitude. That was part of the problem. However, the collision warning systems are installed on aircraft for just that eventuality, and the Russian pilot did not use it correctly. As far as the altitude display available to the ATC, it is not necessarily that accurate, since it is only updated on the radar screen about once every 12 seconds, and relies on the altimeters in each of the aircraft for data, which can be out of calibration by a couple of hundred feet. That is why flight levels are at least 500 feet apart, and automatic TCAS warnings are made earlier at high altitudes. Beyond that, yes the aircraft were flying at essentially the same altitude, since they had entered Swiss airspace at the designated altitudes, which were the same. The controller eventually made the choice to ask one to descend to avoid the collision. There was nothing wrong with that instruction by itself, other than it was a bit late. He made the wrong one. The ATC likely made the right one, based on the information he had at hand. However, neither of us can be sure of that, since the official report has yet to be released. He further in a tone not allowing any questioning instructed the russian pilot to obey him and ignore the onboard TCAS instructions. Nonsense. Pilots are routinely told to ignore ATC instructions if following them would endanger their aircraft. In fact, the European traffic control rules specifically state that pilots are to obey TCAS advisories over any conflicting ATC instructions. The pilot did not follow that rule. Pilots have absolutely no obligation to follow ATC instructions if safety is involved. The poor pilot did (contrary to what he should have done) and a lot of people died as a result. So you are now saying the pilot was primarily at fault? That's because of the ATC's mistake and attitude. No. In the first place, the ATC's mistake was in not asking the aircraft to change altitude sooner. He did not make a mistake in asking the Russian aircraft to descend, based on the information available to him, nor was the urgency of his instruction an error, since he was trying to avoid an imminent collision. In saying the ATC instruction was a mistake is a gross oversimplification of a complex set of interactions. The ATC was certainly involved in the events that led up to the collision, but there were many other events, such as inadequate support from the ATC's employer, equipment that was out of service, and questionable training of pilots on the part of the Russian airline. The ATC was likely not even primarily to blame. This is where the official accident report will sort out many of the conflicting events. Did you get it this time? I seem to have a much better understanding of the situation than you do. And further to your earlier suggestion that the ATC instructed the Russian plane to descend even though he knew that it was contrary to the advisory from the aircraft's own collision avoidance system, here is a link to the transcript of the flight data and voice recorders prepared by the German investigators: http://www.bfu-web.de/olderinfo/aktuinfo-e28.htm As you can see, the controller would only have known about the DHL aircraft descending after the pilot announced it over the radio. This was 30 seconds after asking the Russian aircraft to descend, and less than 13 seconds prior to the collision.  |
angry wrote:
	Yes, that's what I ment - the ATC put unnesesary pressure to the poor pilot. The ATC instruction was perfectly normal, and did not in itself put unnecessary pressure on the pilot. The ATC wanted to avoid an imminent collision. The apparently pilot did not react for something like 20 seconds after the ATC's instruction, instead continuing at the same altitude, which is why the ATC had to repeat it with greater urgency. By playing the "authority" too much, he forced the pilot into taking his advice as one that is overriding, so the russian pilot flew into the other aircraft - The ATC did not force the pilot into taking his advice. If the pilot had proper training, he would be able to sort out conflicting instructions. That is not the ATC responsibility. this is why I call the ATC murderer. As I said before, murder is premeditated. The ATC did not plan on killing anybody. You are therefore wrong not only on your interpretation of the events leading up to the accident, but wrong in the use of that word. If the russian pilot had made a mistake, be it because of CRM issues or other, I could have said that he is a fool - but he is not. That's sad! How can you come to that conclusion? The events as reported so far are somewhat sketchy, and there certainly hasn't been any official report issued that reviews the individual actions of the ATC or pilots, nor can we be sure that the TCAS functioned properly when both planes started to descend. (The latest TCAS systems are supposed to change RA if one of the aircraft doesn't respond as it should.) Therefore, you cannot come to any conclusions whatsoever about who was right or who was wrong, except for misinformed ones.  |
I see that both you and I are bieased - I know that I am seeing things in
	this light because I hate ATC's "policeman" attitude, irrespective of the cisrcumstances... I have been a victim of similar attitude, fortunatelty I am here, angry, but allive and kicking... So let's get the facts straight - The ATC instructed the russians to descend as part of the approachg for landing procedure. At that time, he claims that he did not noticed the conflict situation because the radar warning system was not operational - this is bull, as that system is there as an aural warning, and an alert ATC should have noticed that situation developping himself, not waiting for the radar to ring a bell to him about it... The desent instruction coinsided with the TCAS warning and the subsequent RA. Although the ATC mentiones that there is a potential conflict in his descent instruction, he fails to advise that the conflict is and will remain on same FL, he never issues instruction to the DHL traffic although all are on the same FRQ - that misfortunately makes the russion pilot stay put as he has to figure out what to do - to to follow the RA (climb) or to follow the ATC (descent) The ATC has a 5 sec update (not 12) and the Mode C data error is +/- 100 ft, sufficiently accurate. At the time the ATC issues his second "expedite" instruction, the ATC fails to notice that the DHL traffic already has desended halfway trough - still, no radio contact with the DHL traffic, no instructions to maintain assigned FL, no query "hey, where are you going..." - although that information is available cleraly on his radar for almost 45 sec and the picture is there to show that the DHL is descending from FL360 into his "other" trafic that he just instructed to descend to FL350! Under the pressure, the russion pilot finally decides to follow the ATC instruction and descend. 30 sec after that decision they collide - now, I want to know what the stupid ATC was doing for that time - 30 seconds - was not he seeing on his radar screen ( 6 x 5 sec updates) that the he just forced one aicraft to descent into another one that was descending on it's own. Surely he could have just open his mouth and call the DHL traffic and stop him. Or he could have just open his mouth and changed the clearence to the russian guy. Or just open his mouth and say something, anything that would give a clue to the both pilots that they are heading on a collision course. You see, the ATC was the only one that had a whole clear picture in front of him and his job was to keep the things separated and not colliding with each other... He failed... He should not have... That's the way I see it. "James Robinson" wrote in message ... angry wrote: Absurd is to see people like you believe in the newspaper stories. And just where are you getting your information, considering that no official accident report has been released? I have enough knowledge to know that information from the media is suspect, particularly their opinions about what happened and who is at fault. The ATC did made a mistake by choosing wrong altitude to advice as so to avoid the collision. If the Russian plane had followed the ATC instruction, and the DHL plane had continued without descending, there would have been no collision. The ATC instruction was incorrect in hindsight, but given the conflicting information from the collision warning system, the Russian pilot should have ignored the ATC instruction. Had the pilot done so, there wouldn't have been a collision. You are saying that he was unaware of the other aicraft - that's absurd - he was the only one on duty and he had ALL the aicraft in his vicinity, their course, and their altitude displayed for him to make a decision. He was late in asking the Russian plane to change altitude. That was part of the problem. However, the collision warning systems are installed on aircraft for just that eventuality, and the Russian pilot did not use it correctly. As far as the altitude display available to the ATC, it is not necessarily that accurate, since it is only updated on the radar screen about once every 12 seconds, and relies on the altimeters in each of the aircraft for data, which can be out of calibration by a couple of hundred feet. That is why flight levels are at least 500 feet apart, and automatic TCAS warnings are made earlier at high altitudes. Beyond that, yes the aircraft were flying at essentially the same altitude, since they had entered Swiss airspace at the designated altitudes, which were the same. The controller eventually made the choice to ask one to descend to avoid the collision. There was nothing wrong with that instruction by itself, other than it was a bit late. He made the wrong one. The ATC likely made the right one, based on the information he had at hand. However, neither of us can be sure of that, since the official report has yet to be released. He further in a tone not allowing any questioning instructed the russian pilot to obey him and ignore the onboard TCAS instructions. Nonsense. Pilots are routinely told to ignore ATC instructions if following them would endanger their aircraft. In fact, the European traffic control rules specifically state that pilots are to obey TCAS advisories over any conflicting ATC instructions. The pilot did not follow that rule. Pilots have absolutely no obligation to follow ATC instructions if safety is involved. The poor pilot did (contrary to what he should have done) and a lot of people died as a result. So you are now saying the pilot was primarily at fault? That's because of the ATC's mistake and attitude. No. In the first place, the ATC's mistake was in not asking the aircraft to change altitude sooner. He did not make a mistake in asking the Russian aircraft to descend, based on the information available to him, nor was the urgency of his instruction an error, since he was trying to avoid an imminent collision. In saying the ATC instruction was a mistake is a gross oversimplification of a complex set of interactions. The ATC was certainly involved in the events that led up to the collision, but there were many other events, such as inadequate support from the ATC's employer, equipment that was out of service, and questionable training of pilots on the part of the Russian airline. The ATC was likely not even primarily to blame. This is where the official accident report will sort out many of the conflicting events. Did you get it this time? I seem to have a much better understanding of the situation than you do. And further to your earlier suggestion that the ATC instructed the Russian plane to descend even though he knew that it was contrary to the advisory from the aircraft's own collision avoidance system, here is a link to the transcript of the flight data and voice recorders prepared by the German investigators: http://www.bfu-web.de/olderinfo/aktuinfo-e28.htm As you can see, the controller would only have known about the DHL aircraft descending after the pilot announced it over the radio. This was 30 seconds after asking the Russian aircraft to descend, and less than 13 seconds prior to the collision.  |
angry wrote:
	I see that both you and I are bieased - Perhaps, if you consider my desire to wait for the full story from the official accident report before blaming anyone to be a bias. I know that I am seeing things in this light because I hate ATC's "policeman" attitude, irrespective of the cisrcumstances... I have been a victim of similar attitude, fortunatelty I am here, angry, but allive and kicking... So they are simply guilty before all the facts have been collected and sorted out. So let's get the facts straight - Unfortunately, your "facts" are not correct again. Hence the need to wait for the accident report. The ATC instructed the russians to descend as part of the approachg for landing procedure. At that time, he claims that he did not noticed the conflict situation because the radar warning system was not operational - this is bull, as that system is there as an aural warning, and an alert ATC should have noticed that situation developping himself, not waiting for the radar to ring a bell to him about it... The transcript of the CVR and FDRs on both aircraft indicate that the first instruction the ATC gave was to the Russian plane to descend to avoid the traffic. They still had a long way to go to Barcelona, so it would be too early for starting a descent. It is also clear that the controller was distracted, since he was talking on a telephone. Yes, an alert ATC should have noticed the conflict. However, backup alarms are provided as a safety precaution. Alert pilots should never execute a CFIT, land with gear retracted, or try to take off in a DC-9 without flaps, either. Alarms are often provided to reduce the risk of those things happening. The issue is that there were a number of reported problems at Skyguide, which might have "set up" the ATC, such that an accident was inevitable. First, the conflict warning system was inoperable; then, there was only one controller handling the aircraft at the time, even though there are supposed to be two when the conflict warning system was inoperable; finally, there was only one phone line available, so German controllers who saw the impending conflict could not contact their Skyguide counterpart to warn him. Given those problems, how much responsibility does the ATC's employer share in the tragedy? The desent instruction coinsided with the TCAS warning and the subsequent RA. Although the ATC mentiones that there is a potential conflict in his descent instruction, he fails to advise that the conflict is and will remain on same FL, he never issues instruction to the DHL traffic although all are on the same FRQ - that misfortunately makes the russion pilot stay put as he has to figure out what to do - to to follow the RA (climb) or to follow the ATC (descent) Yes, but the Russian pilot should not have needed to hesitate. He should have followed the TCAS RA without any need to think about it. That is an additional question about the accident - why did the Russian pilot take the action he did? You can't blame the ATC for what the pilot chose to do. The ATC has a 5 sec update (not 12) The updates are indeed 12 seconds on the Skyguide radar, based on the sweep of their secondary radar antenna. There are a number of sources for that, including a report released only one week prior to the collision by the Swiss accident investigation branch. Skyguide was planning to upgrade their radar systems to at least meet European recommendations of a minimum of 8 second updates, but had not yet done so. This would allow the implementation of reduced vertical separation standards. and the Mode C data error is +/- 100 ft, sufficiently accurate. At the time the ATC issues his second "expedite" instruction, the ATC fails to notice that the DHL traffic already has desended halfway trough - still, no radio contact with the DHL traffic, no instructions to maintain assigned FL, no query "hey, where are you going..." - although that information is available cleraly on his radar for almost 45 sec and the picture is there to show that the DHL is descending from FL360 into his "other" trafic that he just instructed to descend to FL350! You are being optimistic about what the controller can see. Given the 12 second update interval, and the 100 foot resolution of display, he wouldn't be confident of any change for two or three sweeps of the radar. I understand that ATC are often told not to be confident about any information until that information has been updated twice, since they sometimes get data with errors, which is corrected at the next pass. Under the pressure, the russion pilot finally decides to follow the ATC instruction and descend. Yet you have no criticism of the Russian pilot, even though an automatic system has given him a clear warning? I ask that, recognizing that there is some controversy about what pilots will do when ATC and TCAS instructions conflict, though the JAA policies are quite clear on the subject - the pilot should have followed the TCAS RA, and not the ATC instruction. 30 sec after that decision they collide - now, I want to know what the stupid ATC was doing for that time - 30 seconds - was not he seeing on his radar screen ( 6 x 5 sec updates) Again, the Skyguard radar sweeps are 12 seconds apart. He would only have seen one or two updates before the collision was inevitable. It also appears that the DHL pilot only announced that he had a TCAS RA, and was descending, at about 13 seconds prior to the collision. This was the first the ATC would have known about the RA, and it was too late for the controller to take any further action. that the he just forced one aicraft to descent into another one that was descending on it's own. Surely he could have just open his mouth and call the DHL traffic and stop him. Based on the CVR information, he didn't force the Russian captain to do anything. The captain made the decision to descend, and instructed the first officer to do so, even though the first officer questioned the decision. Hence the delay in beginning the descent, while they discussed what to do. That opens up the questions of CRM and training. As far as the ATC calling the DHL aircraft to stop its descent, if I was the pilot on that aircraft, I would have completely ignored the ATC instruction, and increased my rate of descent in accordance with the RA I was getting from TCAS. That clearly is the training. That brings up the question of what the TCAS system was doing. Both aircraft were supposedly equipped with the latest version - TCAS II, version 7 - which is supposed to alter the RA if one of the aircraft does not do what it is instructed. In this case, why didn't that system provide an RA to the DHL aircraft to stop descending and climb when the Russian aircraft descended contrary to its RA? Or he could have just open his mouth and changed the clearence to the russian guy. Or just open his mouth and say something, anything that would give a clue to the both pilots that they are heading on a collision course. He did give an instruction to avoid the collision. If the Russian aircraft had descended, and the DHL remained at its assigned altitude, there wouldn't have been a collision. With the 12 second sweep of the radar, by the time he would have been sure the DHL aircraft was also descending, it was too late to do anything. You see, the ATC was the only one that had a whole clear picture in front of him and his job was to keep the things separated and not colliding with each other... He failed... He should not have... The ATC did not have a full picture, since he did not have any information about what the TCAS systems were telling the pilots. That's the way I see it. You are still prejudging the results of the accident investigation based on erroneous information and assumptions. There is a whole list of events that shouldn't have happened they way they did, and certainly the ATC's late instruction was one of them, but so were the policies of Skyguide, the way the TCAS system reacted, the training of the crew on the Russian airliner, and the political divisions that require fragmented ATC over Europe. Again, that is what the accident report will sort out. Wait for it before assigning blame. I certainly don't know who is at fault. I have many questions, but won't make any judgment until the report is released.  |
angry wrote:
	So let's get the facts straight - The ATC instructed the russians to descend as part of the approach for landing procedure. The russians were going to Barcelona, which is 600 nautical miles from the collision point. This would be a fairly long landing prcedure. So much to your unbiased, straight facts. I think I'll skip the rest. Stefan  |
| American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 11:46 PM |
| Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 10:45 PM |
| Skyguide traffic controller killed | HECTOP | Piloting | 39 | March 3rd 04 02:46 AM |
| Coalition casualties for October | Michael Petukhov | Military Aviation | 16 | November 5th 03 12:14 AM |
| Why the Royal Australian Air Force went for Israeli Python-4 AAM's over US AIM-9L's | Urban Fredriksson | Military Aviation | 79 | July 19th 03 04:33 AM |
