homebuilt safety
Old May 20th 04, 10:05 PM
Jim-Ed Browne
Not necessarily true, but also virtually never necessary. A good sailplane
gives you amazing glideslope control. With the spoilers fully deployed, I am
literally standing on the rudder pedals in some sailplanes approaching the
runway like a nicely controllable anvil; yet you can close them at any time to
instantly regain your full glide ratio, or modulate them anywhere in between.
It works! Just don't get low, slow, and downwind.
After years as a glider-guider (or a "dope on a rope" if you prefer) I have
finally taken up powered flight, and I am not at all sure that I have truly
internalized the concept that go-arounds are now an option.
Wolfgang pointed out in the 1940s that most lightplanes suffered not
from too poor a glide ratio but one that was too good-making power off
approaches challenging when it has to be done for real.
Most any airplane can be deadsticked-it was done with the F-104
several times, the most famous being the RCAF pilot who executed a
perfect rollout in the middle of a huge frozen lake, rolled to a stop,
got out-then panicked at being on the ice alone,climbed back in the
cockpit and shot himself dead. (The airplane was fixed and flown out.)
The X-1, X-15, and other rocket planes landed deadstick every time and
so does the Space Shuttle.
(Exception-the T-38 and a couple other jet twins with irreversible
hydraulic flight controls and no RAT or standby electric or hydrazine
pump. The USAF justifies this by saying if both engines quit we want
the pilots to punch out,it's safer.)
Today, light planes-particularly the ones that crash with six people
and get the manufacturer sued-are always flown with power-on
approaches so the obsolete museum piece forward of the firewall
doesn't get shock cooled. Then said museum piece quits.... This is an
example of "organized stupidity". An effective speedbrake/spoiler
system would have prevented, in my opinion and in that of many more
well qualified people than myself, the majority of fatal Bonanza
crashes in the last 40 years.
Has experimental aviation learned from this? Well, not yet, but
there's still hope.
  #63
Old May 21st 04, 12:15 AM
Ernest Christley
Pete Schaefer wrote:
"Ernest Christley" wrote in message
. com...
See my website for PICTURES of proof. Crumple zones are not only
feasible, reliable, and light, but they've been flying for over 40years.
There's a lot of stuff on your site. I didn't see anything about crumple
zones. Please provide pointers to what you're talking about. I kept flipping
through your pages, doing searches for "crumple"....no hits.
Does it have to be labeled "Crumple Zone" to work?
No, seriously, after looking at the pictures from the perspective of
someone who doesn't look at the plane everyday, the crumple zones are
not quite so obvious. It's best seen in this pictu
http://ernest.isa-geek.org/Delta/Pic...DykeDelta5.jpg
It's especially easy to see in Tom Bauer's red and white Delta on the
bottom. There is about 18" of steel and fiberglass that has to crumple
before outside objects can reach the the internal cage that forms the
cockpit. The cockpit frame has to bend up another foot or so before
reaching the pilot.
A zone of material that has to crumple before outside objects get to
you, ie, a crumple zone.
test than any other homebuilt design. Why would you need to do
destructive testing? Do I have to break my wings to prove they will
hold me up in flight?
As far as I know, crumple zones are not reusable. Isn't that the point of
them? How can you test the design if you don't do it destructively? Am I
missing something here? Or are you saying that analysis is sufficient? Or
are you confusing crumple zones with something else? I don't get your
analogy, either. You test a wing structure by putting it under load and
showing it holds; you test an energy dissipation feature like a crumple zone
by subjecting it to an impact and showing that it crumples by the amount
predicted.
Do you have to know the exact amount of energy the object will absorb
before deciding that you're safer with than without? I'm not saying
that this Delta can take on cliffs, I'm saying that in an off airport
landing, with all other things being equal (they never are though) the
Delta would be safER with it's crumple zone than the typical
conventional GA aircraft, and it cost nothing in additional weight,
labor or money. You don't have to spend millions as you claim to prove
the obvious.
the landing to an acute angle crumple zones WILL help.
I didn't see the crumple zone features of the Delta that you are refering
to.
Crashworthiness should be part of the primary structure. Not a heavy,
expensive afterthought.
ALL of the crashworthiness considerations I've ever seen have been the usual
"this is the max expected design load, so make it strong enough to withstand
XX times that". Often, there is additional strength in components that
protect the pilot. But that's different than crumple zones.
Maybe we should define what we're talking about. In my simplistic view,
a crumple zone is "stuff that breaks, so you don't have to". The front
leading edge is NOT designed to stop the Delta from flying through a
tree. It's designed to hold the nose in the air; HOWEVER, it is
completely willing to sacrifice itself to HELP the pilot survive that
close encounter with the wooden kind. A good design serves its purpose.
A great design will serve many purposes.
When I sit in my incomplete project, I can look around at all the steel
Fine. If that gives you a warm fuzzy, then good for you. Me? I'll place my
emphasis on accident prevention - both by design, training, and proper
preparation.
Building this plane is taking me about 3yrs minimum. I don't see why
there's not time for all of it.
I take the viewpoint that **** is going to happen, no matter how much we
try to prevent it. If I assume that at some point I'll have to put down
when I really don't want to, I have the chance to prepare for it. Try
to prevent the bad stuff, but be ready in case it does finally happen.
There are not any electronics or flight systems that will ever make me
feel safer than
several feet of protection between me and the hard stuff.
Not even an angle-of-attack sensor? Dang. Given that they are available, I
wouldn't consider building a new plane without one. But your Deltas don't
have enough elevon authority to reach CLmax, so that's probably not an issue
for you.
One of the other builders response to my question about AOA indicator
was that the best one for the Delta was the altimeter. If it's
unwinding too fast you need to let the nose down some 8*)
But to answer your question, if you're having to put it down in a small
field cause you blew a jug, how will the AOA indicator help with that
tree that's getting awfully close? When all your altitude and energy
has been spent and your low, slow and close to hard stuff, I'll take a
few pound of steel tube and fiberglass buffer over a ton of fancy
electronics any day.
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
  #64
Old May 21st 04, 03:24 AM
Pete Schaefer
om...
A crumple zone is a pretty specific type of structure. It's a technical
term.
That's unlikey to be a crumple zone. If you guys are just going to randomly
refer to anything outside the cockpit as a crumple zone, then there's no
basis for communication here.
Please don't make up definitions on your own for technical stuff. It just
confuses everyone.
It's about quantifying a benefit. How much benefit -vs- how much weight,
etc. Do the math and make the design decision.
the obvious.
Obvious? I call that speculation without a shred of evidence to support it.
There is a ton of good technical info on crumple zones as used in automotive
design. Instead of pulling stuff out of your butt, go look it up.
An AOA indicator will help you to precisely select a best-glide speed,
giving you more time and more options.
  #65
Old May 21st 04, 03:32 AM
George A. Graham
On Fri, 14 May 2004, anonymous coward wrote:
a discussion of all
the factors that affect safety in homebuilt aircraft.
My homebuilt airplane design has saved my bacon at least twice. It is
a canard pusher.
First, I landed very hard in high winds. I broke the nose gear linkage
and stopped quickly on the runway. A fellow canard builder flew in with
epoxy and cloth to patch the road rash, and another fellow mailed me some
brake calipers. A few weeks later, two men perished when they landed
hard in a tractor engine airplane. Their nose gear failed, the prop hit and
started a fire which they did not survive.
Second:
After one 1,000 mile long, very high flight (I have oxygen now), I turned
base to final too tightly, and the canard stalled. I leveled her off and builtup
speed, and did an extra trip around the pattern before landing.
I often read about stall/spin crashes, and am very glad to fly this bird.
It does prefer clean paved runways, it seems much more safe to me.
I learned to fly after I turned 50 years old, and do make newbie mistakes.
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
  #66
Old May 21st 04, 04:15 AM
Ernest Christley
om...
term.
Technical terms have definitions, and believe it or not, I can read.
You can step off the high horse, 'cause we're all human here. If you've
got a definition that will change the definition from what I've stated,
then put it out there. You're liable to teach a whole lot of people a
thing or two, including myself. I've offered a simple, workable
definition below.
Well, hell. I didn't mean for you to get your technical panties is a
wad. Anything outside the cockpit IS a crumple zone if
1) it gets between you and the hardstuff, and
2) it's not so strong that you break before it does
By this definition, if something extreme happens and you somehow come
down backwards, landing on your tail with the nose straight up, then the
whole aft fuselage becomes a crumple zone.
confuses everyone.
Whew!! The snots flying now!
Uh. Excuse me. This IS r.a.h. you know. Making up our own definitions
is what we do best.
Uh. Excuse me again. There is NO weight added. You've just put part
of the structure that has to be there anyway between yourself and
obstacles. It's stuff that crumples, and it's in a zone (around here,
we call it "The Stuff to the Front and Side of Daddy Zone", careful I
have that phrase copyrighted, possibly trademark, and I'm gonna talk to
a lawyer about a patent), therefore it's a crumple zone.
the obvious.
Nope no evidence whatsoever, and I'm not about to go out and bend up a
bunch of perfectly good, expensive and increasingly scarce 1" 4130 steel
tube to prove that it absorbs a lot of energy as it's bending.
Look at all the technical info you want. A zone that crumples. It's
self defining. I don't need a self styled expert to tell me that I'm
safer if I have something other than me to absorb the impact energy.
OK, you've had a perfect glide into the only field in the valley as you
tried to cross the mountain. You're just below the treetops, and the
end of the field is coming quick. How many options will the indicator
give you?
Besides, that's what the airspeed indicator is for.
Veeduber
  #67
Old May 21st 04, 08:42 AM
Pete Schaefer
om...
Well, then look it up. Rather than get offended, go look it up on Google.
You'll get tons of hits, but there will be some gems there that explain the
concept. It wasn't me that started applying the term "crumple zone" to
every part of the airplane.
Your definition is way too general and does not match up with common usage
in the engineering circles where the term comes from.A crumple zone is a
structural piece that is designed to compress in a specific way under a load
in a certain direction. Instead of just tearing to pieces, it folds up like
an accordion, thus reducing the peak stresses transmitted to the rest of the
structure. A crumple zone is designed to collapse upon reaching a certain
threshold, usually determined by some maximum impact velocity and the weight
of the rest of the structure. Think about an empty soda can. If you
carefully stand on it, it might support your weight. If you hop up onto it,
the sides will fold up like an accordion. Put a can on it's side, and it
fails in quite a different manner.
is what we do best.
Yup. It's one of my chief annoyances of newsgroups: very low signal to noise
ratio.
If I had an idea for, say, a new engine mount system that could dramatically
increase my chance of survival without increasing weight that much, I
wouldn't hesitate for a second to build a prototype and at least put it
through some static load tests. You wouldn't necessarily have to wreck an
entire airframe, as long as you could demonstrate the behavior with an
appropriate design load.
If you don't want to go through that, then do what everyone else does and
pick a max design load and apply an overdesign factor.
Fine, stick to your own definitions if you want. It's not my goal in life to
educate you. And I never claimed to be a structures expert, but I do
interface with guys every day who are. I understand the issues and how they
affect what I do. But I don't go around changing definitions.
give you?
If you've taken advantage of the best your airframe can do, then maybe
you've arrived above the valley with enough altitude so that you have a
choice as to what direction you're going to land in.
And how do you chose the best airspeed? Just pick one out of a book? Well,
the best airspeed changes based on your current loadout. The optimum angle
of attack for glide does not change. Without looking at alpha, you're just
going on a rough guess that will likely be off significantly.
Anyway, I've done all the typing on this topic that I'm going to do. If you
want to deviate from the normal state some more, there's plenty of books,
articles, etc., out there for you to read. You don't have to take my word
for anything. Given that you've chosen a low aspect-ratio design, not having
any choices where you set your airplane down may be much more of a reality
for you.
  #68
Old May 21st 04, 01:16 PM
On Fri, 21 May 2004 03:15:13 GMT, Ernest Christley
Is this what you meant when you said that the P-51 was built with
crumple zones? If that's what you meant, then this is a revisionist
interpretation of how the P-51 was designed and why.
That the P-51 had a monocoque type fuselage and the engine assembly
bolted to it, was just the way fighters were built. It was a
production thing, a compromise between what the engineers really
wanted and what was possible to get the airplanes out the door as
inexpensively as possible and still be lightweight and strong. That
the fuselage was stong was a necessity for combat, withstanding high G
maneuvers and near supersonic speeds, it had nothing to do with crash
safety.
The P-47 Thunderbolt was also designed exactly the same way: monocoque
fuselage and the engine bolted to the firewall. Except that Republic
decided to make the airplane REALLY strong. One example, according to
one of it's more famous pilots, rolled itself up into a ball in Long
Island sound after pulling out of a dive. The pilot was sitting on
the shore somewhat dazed but alive after crawling out of the wreckage
when they found him. Did Republic set out to specifically design the
P-47 to protect the pilot in crashes? No, but it was so strong that
it was more crashworthy than virtually any other fighter in WWII. It
paid for this crashworthiness by being the heaviest single engine
fighter of the war. The phenominal weight made it's climb, for a long
time, it's least impressive feature.
Corky Scott
  #69
Old May 21st 04, 01:53 PM
jls
"George A. Graham" wrote in message
a discussion of all
a canard pusher.
and
Second:
builtup
George Graham
I saw a Long-Eze land gear-up at Oshkosh. All the emergency vehicles sped
to the downed aircraft. Adrenaline pumped. Not to worry, though. The
nose had a little bumper underneath which was barely even scuffed.
  #70
Old May 21st 04, 02:35 PM
Jim Harper
(Jim-Ed Browne) wrote in message . com...
approaches _so the obsolete museum piece forward of the firewall
doesn't get shock cooled_. Then said museum piece quits.... This is an
Mr. Jimed...I suspect that you are merely a troll, and to those on rah
who have been ignoring you, I apologize. On the other hand, this post
represents an abysmal lack of knowledge and requires comment.
Specifically, I would like to point out that your claim that power-on
approaches are "so (the tried and true aircraft engine) forward of the
firewall doesn't get shock cooled..." is patently absurd. Power-on
landings are used to control the descent rate of the airplane...or to
remove the far too effective drag device of the windmilling propeller
(as in my RV-8A)...or for other reasons, but certainly not to prevent
shock-cooling. The minimal application of the throttle needed would
not be accomplish that goal, firstly, and secondly, the time for that
is long past on landing approach.
I have little doubt that this represents a precis' of your entire
knowledge base regarding things aeronautical, and with that, am done
with you.
RV-8A N888FP
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
