#21
It is on the IFR charts because -- at least in theory -- the information
helps VFR pilots determine where they can legally scud run and at what airports they can legally fly a standard 1000-foot pattern on a marginal VFR day. Whether that is safe or whether VFR pilots actually are aware of or follow these rules is another matter. The distinction between a 700-foot transition zone or a 1200-foot transition zone basically helps VFR pilots to determine if they can fly a standard 800-foot or 1000-foot pattern on a day when there is a 1000-foot ceiling. The answer is yes for airports with 1200-foot transition zones and no for airports with 700-foot transition zones. A related issue has to do with Class E Surface Areas -- generally commuter or regional airlines are permitted only to fly at airports which have Class E Surface Areas and thus -- at least in theory -- where it should not be possible for an IFR airplane to break out of a cloud and find a VFR airplane 1 foot below. This means that on marginal VFR days it is at least theoretically safer for an IFR pilot to land at an airport with a Class E Surface Area than with Class G airspace on the surface. -- Richard Kaplan, CFII www.flyimc.com |
The difference between class E and G airspace is that ATC
cannot control traffic in class G (thus... it's uncontrolled)... By lowering the floor of the class E (in which ATC can control aircraft) over small airports, IFR flights can remain under ATC control to a lower altitude, thus facilitating the IFR approach process... The fact that VFR minimums in class G are 1 mile and clear of clouds is not to encourage VFR pilots to go fly in that, but to make it legal for instrument pilots to complete approaches where the visibility minimums are 1 mile in the class G airspace... Ever wondered why SVFR minimums are 1 mile and clear of clouds... Same reason... John Price CFII/AGI/IGI http://home.att.net/~jm.price "Ace Pilot" wrote in message om... A friend recently asked me to explain the magenta circles seen around numerous airports on sectionals. It got me to thinking about how useful they are. Personally, if the weather isn't good enough to fly VFR in Class E airspace, I'm not going to fly VFR, even if it is legal in Class G airspace. So, for me, it is pointless knowing where the boundary is between Class E and Class G airspace. But I was curious to know if there are pilots that take full advantage of this distinction. Does anyone actually make use of the Class E/G boundaries depicted on sectionals? If so, how? I suspect the most common use is doing T&Gs in the pattern below 700 feet AGL when the weather is marginal. Other uses? |
![]() "john price" wrote in message ... The fact that VFR minimums in class G are 1 mile and clear of clouds is not to encourage VFR pilots to go fly in that, but to make it legal for instrument pilots to complete approaches where the visibility minimums are 1 mile in the class G airspace... VFR minimums have nothing to do with IFR approaches. |
#24
![]() "john price" wrote in message ... The fact that VFR minimums in class G are 1 mile and clear of clouds is not to encourage VFR pilots to go fly in that, but to make it legal for instrument pilots to complete approaches where the visibility minimums are 1 mile in the class G airspace... With visibility of 1 mile I would never cancel IFR until I am on the ground. Thus how would the VFR weather rules affect my flight other than by settting cloud distance requirements for VFR airplanes in Class E airspace? -- Richard Kaplan, CFII www.flyimc.com |
#25
![]() "Steven P. McNicoll" wrote in message ink.net... "Ron Natalie" wrote in message m... Those circles aren't to keep VFR pilots safe when the weather is marginal. They are to lower the floor of controlled airspace for the benefit of IFR pilots. This accomplishes two things: 1. Allows ATC to provide control to lower altitudes, primarily separation from other IFR aircraft. 2. Makes sure any there is sufficient visibility / cloud clearance for visual separation techniques to be used between any VFR aircraft that might be present. Changing weather has no effect on the floor of controlled airspace. I never said it did. |
#26
![]() "Steven P. McNicoll" wrote in message nk.net... "BTIZ" wrote in message news:vJqbc.69606$1I5.24219@fed1read01... But I did not think he said anything about changing the floor of the airspace for weather, he stated that the lower floor provides transistions for IFR pilots to get close to the airport, and CLEAR OF VFR traffic in marginal weather, that should be remaining in Class G and not Class E where the approach may dump them off. He said; "Those circles aren't to keep VFR pilots safe when the weather is marginal. They are to lower the floor of controlled airspace for the benefit of IFR pilots." Correct. The transition area lowers the floor of controlled airspace. I never said it had anything to do with changing weather conditions. The first sentence was to refute the hypothesis of the original poster. |
#27
![]() "Ron Natalie" wrote in message m... I never said it did. Well, if you didn't, then somebody else is posting here under the name "Ron Natalie". |
#28
![]() "Ron Natalie" wrote in message m... Correct. The transition area lowers the floor of controlled airspace. The floor of controlled airspace is fixed. |
#29
![]() "Steven P. McNicoll" wrote in message ink.net... "Ron Natalie" wrote in message m... Correct. The transition area lowers the floor of controlled airspace. The floor of controlled airspace is fixed. The transition area floor is LOWER than it would be if there were no transition area. It's a local dropping of the controlled airspace floor from 1200 (typically) to 700. Everybody else seems to understand what I'm saying except for you. Stop and try to think about the real issue rather than trying to generate as much confusion as possible. |
#30
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
