This additional slant from the Aero-News email newsletter this morning: ************************************************** ****************** "Minutes after departure, I started experiencing instrument failures, one after another. No warning. No smoke. No clues. Just gauges going out one after another." As the first gauge failed, Jeff told Center he wanted to turn back. Center immediately gave him vectors for the return, but thereafter the perceived succession of failures made the turn-around seem fairly iffy. Ippoliti was stunned. Not only were gauges failing, but they were failing in systems that didn't appear to be related. In a matter of seconds, just hundreds of feet from the ground and untold obstacles obscured by IMC, he really didn't know what to trust. This couldn't be good. With an unknown number of hazards looming, he informed ATC that he was clearly in trouble. And after some initial hope of heading back, the SR22 pilot realized that turning back to the airport was something he wasn't sure he could do with his gauges continuing to fail in "rapid succession." "I told center I couldn't turn back... that I was going to pull the chute." Jeff then told ANN that one of the few responses he remembered from that moment on was center responding, "you're going to pull what?" From there, Ippoliti's activities were quick and assured. "I'd thought about this... but I never expected to have to do it." Jeff pulled the power back, killed the engine and reached up for the BRS CAPS handle... and pulled. Despite all his trepidation, Jeff noted that the pull went well, "No problem with that, it pulled easily." BANG! The chute OPENED. Ippoliti then described feeling a little 'G' as the plane slowed, swung around a bit, and then things calmed down remarkably fast. "From there it was almost a non-event. The ELT went off right away and prevented me from understanding Center because it was so loud, and the pilot door came off as the chute fired... but the ride down lasted only seconds as I came down on some trees and just... stopped." Ippoliti was alive and had landed in a local park. The aircraft was not only intact, but surprisingly suffered limited damage... "a lot less than what might have been," he noted. He doesn't have much to say about the landing impact, as the trees apparently absorbed most of the energy, and turned history's third emergency CAPS landing into a "relative non-event." all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
(When I posted the above, I did not realize that this was *yet another* deployment! I apologize for any confusion I may have caused when replying to earlier threads where fuel exhaustion, not instrument failure, was the supposed issue.) all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
"Cub Driver" wrote in message ... This additional slant from the Aero-News email newsletter this morning: ************************************************** ****************** "Minutes after departure, I started experiencing instrument failures, one after another. No warning. No smoke. No clues. Just gauges going out one after another." Interesting, but again I would not trust ANN too much. They have the news reporting standards of a supermarket tabloid combined with the business practices of the Sopranos. However, supposing the instruments failed "one by one" in unrelated systems, then I am going to risk a guess that the pilot was badly disoriented. Probably none of his instruments failed. |
"Cub Driver" wrote: "I told center I couldn't turn back... that I was going to pull the chute." Taking this with a grain of salt because of the source, I wonder if the pilot might have been over hasty. Why not ask ATC where the nearest VFR weather was and go there? If he didn't have the fuel to get there, then ok, pull the 'chute. -- Dan C172RG at BFM |
| NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 11:33 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 08:17 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 08:29 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
