"avfan" wrote in message news:j1c2b0h37tm0cvslp7o92q0k47rrsjdf8t@news... http://www.airliners.net/open.file/541868/M/ Ah those were the days... I wonder if those commercial aircraft used water injection. Imagine that aircraft with 8 engines, spewing double the smoke, and another one just like it 12 seconds behind....and at least one more 12 seconds behind number 2. Now you've got a B-52G MITO takeoff. JB |
Some 707s DID use water injection.
"Jim Baker" wrote in message ... "avfan" wrote in message news:j1c2b0h37tm0cvslp7o92q0k47rrsjdf8t@news... http://www.airliners.net/open.file/541868/M/ Ah those were the days... I wonder if those commercial aircraft used water injection. Imagine that aircraft with 8 engines, spewing double the smoke, and another one just like it 12 seconds behind....and at least one more 12 seconds behind number 2. Now you've got a B-52G MITO takeoff. JB |
"tom418" wrote
Some 707s DID use water injection. Yes, more specifically, the early -100 series with the P&W JT3C-6 engine producing 13,500# of thrust with water injection. With the availability of the P&W JT4A-3 engines @ 15,800 # of thrust without water injection, the airframe was enlarged to the early -300 series while P&W was busy adding a front fan stage to the JT3-C to produce the JT3-D series of engines producing over 18,000# of thrust which would power the improved -300 series and the later 720 model aircraft. Bob Moore 17 years in 707s |
"Scott M. Kozel" wrote in message ... "Ralph Nesbitt" wrote: "matt weber" wrote Early jet engines often had multiple small combustion chambers, the volume to surface ratio prevented the temperatures from getting high enough in parts of the chamber to burn the fuel effectively and some even had an exhaut pipe for each chamber. As the materials improved, a switch to a single combustion chamber, with a much more favorable surface to volume ratio and higher combustion chamber temperatures produced more complete combustion, and the black exhaust plume started to disappear. By the early 1970's such plumes had become rare on commercial jets in the USA. As a boy growing up in the mid 50's we lived near a SAC Base. An "Alert Scramble/Launch" was a sight to see. The above Pic is from a single 707. Consider the smoke put off by a dozen B-52's followed by a dozen KC-135's using "Powder Charges" to start the engines. It would take ~ 30 minuets for all the B-52's & KC-135's to get airborne. If there was little/no wind the smoke would hang over the base for hours. What has been done to make the B-52s less smoky? There was talk about 15 years ago of re-engining them with 4 large turbofans to replace the 8 original Jet engines, but that was not done. All the turbojet models are retired, the last one being the G model. The H model has fanjets and thus doesn't use water for added thrust on takeoff. JB |
Matt
I'll use your post to stick my 2 cents in. Long before my retirement from the USAF, I was told that the smoke trail out of the US engines was caused by the engine design where an internal bearing was oiled by a spray and that that oil migrated back and was burned and made the smoke trail. Used to see and take my Fighter off behind B-52's and their heavy smoke all the time at SAC bases. Also the smoke trail worked against the F-86. It was much easier to spot the F-86 with their smoke trail then the Russian MIG which didn't have a smoke trail. Amy one out there want to take this up and add to this technical issue? Seem to remember that the B-52(s) that flew non stop around the world (used air to air refueling) had extra oil tanks installed so there would be enough oil for the trip???? Long time ago in a land far away................ Big John ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~` On Tue, 25 May 2004 22:03:12 -0700, matt weber wrote: On Tue, 25 May 2004 00:11:32 -0400, "Scott M. Kozel" wrote: "Ralph Nesbitt" wrote: "matt weber" wrote Early jet engines often had multiple small combustion chambers, the volume to surface ratio prevented the temperatures from getting high enough in parts of the chamber to burn the fuel effectively and some even had an exhaut pipe for each chamber. As the materials improved, a switch to a single combustion chamber, with a much more favorable surface to volume ratio and higher combustion chamber temperatures produced more complete combustion, and the black exhaust plume started to disappear. By the early 1970's such plumes had become rare on commercial jets in the USA. As a boy growing up in the mid 50's we lived near a SAC Base. An "Alert Scramble/Launch" was a sight to see. The above Pic is from a single 707. Consider the smoke put off by a dozen B-52's followed by a dozen KC-135's using "Powder Charges" to start the engines. It would take ~ 30 minuets for all the B-52's & KC-135's to get airborne. If there was little/no wind the smoke would hang over the base for hours. What has been done to make the B-52s less smoky? There was talk about 15 years ago of re-engining them with 4 large turbofans to replace the 8 original Jet engines, but that was not done. The current inventory I believe is all H models, and H's have ended up with TF33PW-103's engines, which is the miltary version of a late model JT4, in otherwords a turbofan without water injection.All prior model B52's used the J57, which is a turbojet, not a turbofan, and no doubt water injected... In short, replace the cans with larger burner, get rid of the water injection, add a turbofan and a better designed combustion chamber, and most of the smoke disappears... The civilian vesion of the J57 is a JT3 (turobjet), used on early 707's, the civilian version of the TF33 is the JT4, used on later 707's. J57 is a 12,000-13000 pound thrust engines, most of the TF33's are 17,000-18,000 pounds. |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | Aviation Marketplace | 1 | January 13th 04 09:26 PM |
| Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | General Aviation | 1 | January 13th 04 09:26 PM |
| MSNBC Reporting on GA Security Threat | Scott Schluer | Piloting | 44 | November 23rd 03 03:50 AM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
