I was searching via Google for informational schematics, or even just
a written description, on Lycoming's fuel injection system because it's different from Continental's. I came across Lycoming's website in which a number of technical and informational articles reside. One of them http://www.lycoming.textron.com/main.jsp?bodyPage=support/publications/keyReprints/operation/leaningEngines.html discusses various mixture settings for their fuel injected engines. Here is item no. 5 from that article, it's a description of how to achieve "best power" and "best economy" when an EGT guage is available: 5. The exhaust gas temperature (EGT) offers little improvement in leaning the float-type carburetor over the procedures outlined above because of imperfect mixture distribution. However, if the EGT probe is installed, lean the mixture to 100oF on the rich side of peak EGT for best power operation. For best economy cruise, operate at peak EGT. If roughness is encountered, enrich the mixture slightly for smooth engine operation. ***editorial note*** If you do this (richen slightly from peak), the only place for the cylinderhead temperatures to go is up. Slightly to the rich side of peak on the graph described below is where the cylinderhead temps peak. So it would pay to be careful how much you richen from the peak setting, if the engine is running rough at that point. The Cessna 172 I rent has the EGT guage, but no CHT guage. So you can richen from peak and drone happily along not knowing that you are cooking the cylinderheads. This particular section of the website includes a nice graph, which, if you are familiar with John Deakin's "Mixture Magic" article, will look very familiar. It should because all fixed spark engines will show the exact same performance curves for things like EGT, CHT, percent power and BSFC. What was interesting to me is if you look at where peak EGT is occuring and then go down to the BSFC curve is, you will see that you have not yet reached the lowest BSFC. That doesn't occur until you've leaned a bit further. But then you would be **LOP**. Notice it does not take much additional leaning to get the lowest BSFC the engine is capable of producing. Here's the interesting part: At peak EGT, the cylinderhead temps are already starting down from their peak, and the downward curve is pretty steep once you get to peak EGT. Just a tiny bit more leaning and the cylinderhead temps dive down another full ten degrees, while the EGT has hardly gone down at all. While this is going on, the percentage of power is dropping off too, which is why economy cruise is slower than best power, of course. Lycoming finishes the graph with the following statement: "Textron Lycoming does not recommend operating on the lean side of peak EGT." Yet as their own graph shows, best economy is ONLY achieved lean of peak. What extremely interesting to me is that the difference between peak and lean of peak where best economy occurs is only a matter of a very few degrees EGT. Remember, when you are cruising at 60% power, you cannot hurt the engine no matter where you set the mixture control. You can't burn valves or cook the cylinderheads or cause detonation, it just isn't producing enough power to do that. Lycoming themselves recommends that for maximum engine life, cruise power should be limited to 65% and CHT's kept below 400 F. But since the instrument panel doesn't include a CHT guage, the only way to avoid high temps is to be way rich, or at peak EGT or below. Why Lycoming recommends against LOP operation is a mystery. MUCH cooler CHT's and less fuel being burned... what am I missing here? Does the engine run roughly at this setting? Only those who try LOP will know. Corky Scott |
... Why Lycoming recommends against LOP operation is a mystery. MUCH cooler CHT's and less fuel being burned... what am I missing here? Does the engine run roughly at this setting? Only those who try LOP will know. http://www.lycoming.textron.com/supp...ps/SSP700A.pdf sets out their case, at least for larger turbos. (I'm not suggesting I endorse it.) Another thing to bear in mind is that mixture distribution is imperfect in most factory engines. If you operate at a steep part of the power vs mixture curve, small differences in mixture mean large imbalances of power between the cylinders. That can't be good for the engine. The point of Braly's Gamijectors is to even out the mixture distribution so that the imbalance disappears. Julian Scarfe |
"Julian Scarfe" wrote in message ... The point of Braly's Gamijectors is to even out the mixture distribution so that the imbalance disappears. They don't even out a power imbalance, they just make all the cylinders reach peak EGT at the same mixture setting. |
"Stan Prevost" wrote in message ... "Julian Scarfe" wrote in message ... The point of Braly's Gamijectors is to even out the mixture distribution so that the imbalance disappears. They don't even out a power imbalance, they just make all the cylinders reach peak EGT at the same mixture setting. Which likely produces a balancing of power, no? Also, IIRC, it leads to the piston achieving ignition at the optimal point in the stroke (at LOP??). |
wrote in message ... Lycoming finishes the graph with the following statement: "Textron Lycoming does not recommend operating on the lean side of peak EGT." Yet as their own graph shows, best economy is ONLY achieved lean of peak. What extremely interesting to me is that the difference between peak and lean of peak where best economy occurs is only a matter of a very few degrees EGT. Corky, Isn't it also true that LOP optimizes the point in the stroke that the cylinder achieves the peak ignition point? Considering the wear on the engines moving parts that provides, maybe George Patterson is right, that they'd like us to buy new engines? :~) I also wonder how they are trying to cover their legal asses if they were spreading wrong (negligent) information for all these years, or merely just PP QC on their engines?? Tom -- "Flying an airplane is just like riding a bike -- it's just a lot harder to put baseball cards in the spokes" -- Capt. Rex Cramer |
Mike Rhodes wrote: As for Lycoming recommending against LOP, there was an article in Flying magazine (p. 74-75, 7/02, inset article, J.Mac) , where there was some sort of lead crystalline deposit (lead oxybromide) forming in _turbo_ engines only in LOP operations. I've snipped the rest since it is full of old wives tales. The theory of lead oxybromide came from a poorly investigated accident in Austrailia. John Deakin analyzes the accident, and Flying's coverage of it. Accident: http://www.avweb.com/news/columns/182152-1.html Flying's coverage: http://www.avweb.com/news/columns/182153-1.html Deakin also covers LOP in alot of his articles, specifically the ones titled 'Where should I run my engine?' He goes into the science of how an engine actually works, and examines how the 'your engine will burn up if you do that' OWTs relate to reality. All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html John -- John Clear - http://www.panix.com/~jac |
... The point of Braly's Gamijectors is to even out the mixture distribution so that the imbalance disappears. They don't even out a power imbalance, they just make all the cylinders reach peak EGT at the same mixture setting. Which they do by ensuring the same actual fuel/air mixture at a given mixture setting. Further, since the difference in fuel/air mixture at a given mixture setting plays a big part in the power differences between each cylinder, why wouldn't the Gamijectors help improve the power imbalance? Pete |
"John Clear" wrote in message
... I've snipped the rest since it is full of old wives tales. The theory of lead oxybromide came from a poorly investigated accident in Austrailia. John Deakin analyzes the accident, and Flying's coverage of it. Accident: http://www.avweb.com/news/columns/182152-1.html Flying's coverage: http://www.avweb.com/news/columns/182153-1.html You missed the best bit, where the coroner slates the ATSB investigation. :-) http://www.airsafety.com.au/whyalla/default.htm has the chronology. Julian Scarfe |
In article , Mike Rhodes wrote:
things to tend to) invites catastrophic trouble in any engine. And for the pilot to get in that habit in normally-aspirated engines can, after the pilot upgrades, apparently inflict harm on turbo engines. snip I've never bought the argument of "don't get in the habit of this, because if you move to X type of different aircraft, it's bad". Operating one engine sub-optimally because it's not done in another type seems a bit silly to me - surely pilots should fly each different type appropriately, instead of by habit? If someone tells me "don't operate your C140/Auster/Champ [...] like this because if you move to a turbo Bonanza, doing that will be harmful", I tend to ignore them and continue to operate each aircraft appropriately. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 01:50 AM |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Military Aviation | 3 | August 21st 04 01:40 AM |
| Power settings for 182RG | Andrew Gideon | Piloting | 19 | March 3rd 04 08:41 PM |
| Cessna 404 Cruise settings | Katia | General Aviation | 0 | December 19th 03 06:04 PM |
| Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 05:00 PM |
