For those of you who have aerobatic airplanes, I'd be interested in
data about the recommended entry speed for a snap roll vs. what Va is in your airplane. Thanks for any info. |
In a 7GCAA, Va at max gross is 120 mph and the recommended snap roll entry
speed is 85 mph. "Greg Esres" wrote in message ... For those of you who have aerobatic airplanes, I'd be interested in data about the recommended entry speed for a snap roll vs. what Va is in your airplane. Thanks for any info. |
entry speed is 85 mph. Thank you. Can a snap roll be done at max gross ? |
Yes.
"Greg Esres" wrote in message ... In a 7GCAA, Va at max gross is 120 mph and the recommended snap roll entry speed is 85 mph. Thank you. Can a snap roll be done at max gross ? |
Yes.
Thank you. |
Most things in aviation are related to the wings-level, 1-g stall
speed, Vso. The maneuvering speed, Va, is actually the stall speed of the airplane at the design limit, and it is related to Vso by the square root of the g-load. (Of course, all of these are CAS, so you may have to do some massaging through the airseed calibration data to convert back and forth between IAS and CAS to find the numbers you must read on the airspeed indicator.) For example, in aerobatic airplanes like the Citabria which were certificated at +5.0 g's (at max. gross), Va = 2.24 x Vso. In aerobatic airplanes certificated at +6.0 g's (at max. gross), Va = 2.45 x Vso. In terms of the snap roll entry speed (and snap rolls are really accelerated stall/spins), the speed will naturally fall somewhere between Vso and either 2.24 or 2.45 x Vso. In Eric Muller's book, Flight Unlimited, he recommends intially practicing snap rolls at 1.5 x Vso, so there's a starting point. In my experience, I'd recommend around 1.6 x Vso as a good "recommended" snap roll speed, which translates into a 2.5-g pull to stall/spin the airplane at that speed. The MAXIMUM snap roll speed should probably be no greater than about 1.7 to 1.8 x Vso... Hope this helps (and HI Ken!), Rich http://www.richstowell.com "Ken Ibold" wrote in message . com... In a 7GCAA, Va at max gross is 120 mph and the recommended snap roll entry speed is 85 mph. "Greg Esres" wrote in message ... For those of you who have aerobatic airplanes, I'd be interested in data about the recommended entry speed for a snap roll vs. what Va is in your airplane. Thanks for any info. |
that speed. The MAXIMUM snap roll speed should probably be no greater than about 1.7 to 1.8 x Vso... Rich: Thanks for your reply. The genesis for my question is that there are a number of aerodynamic sources which discuss the concept of a "dynamic stall", where when the a/c is rapidly rotated to a high AOA, it can generate a much higher lift coefficient than in steady state conditions. My thought is that a snap roll should duplicate those conditions. However, the g-forces you're reporting don't seem to match that theory. Bill Kershner said that he does snap rolls at 80 knots, and has never seen more than 3 g's in his Aerobat. |
Hi Greg,
You're right, dynamic stall occurs when a wing or other lifting surface is subjected to time-dependent pitching (or other type of time-dependent) motion, resulting in a greater effective angle of attack than the normal, static stall angle. But the "dynamic stall" phenomenon does not really apply to light airplanes. It is is an unsteady stall phenomenon which can be experienced by the retreating blade of a helicopter in forward flight and by highly maneuverable fighter aircraft. "Dynamic stall" means something to skydivers as well, I think when a skydiver pendulums under the canopy too close to the ground... Rich http://www.richstowell.com Greg Esres wrote in message . .. which translates into a 2.5-g pull to stall/spin the airplane at that speed. The MAXIMUM snap roll speed should probably be no greater than about 1.7 to 1.8 x Vso... Rich: Thanks for your reply. The genesis for my question is that there are a number of aerodynamic sources which discuss the concept of a "dynamic stall", where when the a/c is rapidly rotated to a high AOA, it can generate a much higher lift coefficient than in steady state conditions. My thought is that a snap roll should duplicate those conditions. However, the g-forces you're reporting don't seem to match that theory. Bill Kershner said that he does snap rolls at 80 knots, and has never seen more than 3 g's in his Aerobat. |
"Rich Stowell" wrote in message
om... Most things in aviation are related to the wings-level, 1-g stall speed, Vso. The maneuvering speed, Va, is actually the stall speed of the airplane at the design limit, and it is related to Vso by the square root of the g-load. (Of course, all of these are CAS, so you may have to do some massaging through the airseed calibration data to convert back and forth between IAS and CAS to find the numbers you must read on the airspeed indicator.) For example, in aerobatic airplanes like the Citabria which were certificated at +5.0 g's (at max. gross), Va = 2.24 x Vso. In aerobatic airplanes certificated at +6.0 g's (at max. gross), Va = 2.45 x Vso. In terms of the snap roll entry speed (and snap rolls are really accelerated stall/spins), the speed will naturally fall somewhere between Vso and either 2.24 or 2.45 x Vso. In Eric Muller's book, Flight Unlimited, he recommends intially practicing snap rolls at 1.5 x Vso, so there's a starting point. In my experience, I'd recommend around 1.6 x Vso as a good "recommended" snap roll speed, which translates into a 2.5-g pull to stall/spin the airplane at that speed. The MAXIMUM snap roll speed should probably be no greater than about 1.7 to 1.8 x Vso... Hope this helps (and HI Ken!), Rich http://www.richstowell.com Don't forget that the structural g limit is for a symmetrical stall and is reduced to 2/3 for an asymmetric stall - therefore the absolute max snap roll speed at MAUW for a 6g airframe is 2xVso. Also, this speed should decrease at lighter weights by the ratio of the square roots of the weights. Vso at weight w = Vso x sqrt(w)/sqrt(MAUW), this can make a 10% difference to Vso so could easily affect the max snap speed by 10kts or more. Dave Sawdon |
A couple points to add to this discussion... 1) How does the use of rudder affect the g-loading on the wings? A typical snap roll, in competition, anyway, is initiated by the rudder after the pilot has loaded up the wings. This loading is less than that required to produce a stall. 2) Snap rolls cause twisting loads and gyroscopic effects that do not register on a g-meter. Are those loads significant? How would one determine what those twisting limits are? 3) Reducing the aircraft's weight will reduce the load on the wings, but it does not affect the load on non-lift-bearing parts of the aircraft, like the propeller, engine mounts, and pilot seat. Bottom line for me is to read the aircraft flight manual and reduce the published limits by a percentage equal to the square root of the age of the airplane + the cube root of the age of the pilot. If there are no published limits, do a good preflight on your parachute and be sure you will have an easy egress. -- Dennis Yugo http://www.worldpassage.net/~dyugo |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 08:27 AM |
| Barrel roll And g's Quest. | Robert11 | Aerobatics | 6 | July 16th 03 03:51 PM |
