Starting to bead blast my landing gear and assorted fittings getting
	ready to pain and inspect closely. Purchased a pressurized blaster from harbor freight. The 40lb kind. dumped a box of #8 beads in and expected to blast off. Nope. Nada. Seems glass bead is hygroscopic or hydrophylic take yer pick. Compressed air in North Carolina is quite wet. Glass bead wet air = no blasting. Solution. Take one bog standard portable air tank. Drill a hole in the side of the thing or top does'nt matter. Weld a steel male to male bung onto the side of it and then attach a ball valve or quick connect. Remove air fitting that came with the tank. I was left with a 1/2" threaded bung. Using a 1/2 steel pipe nipple and 90Deg fitting from Lowes aerospace supply company I hung a Johnson Controls Filter regulator on it. (also from lowes) How the setup works. 1. Locate the compressor in a different location than where you are blasting. 2. connect an airline fromt he compressor to the header tank/reg/filter. This is important. The length of the line will help cool the air down. This allows water to condensate out and get trapped in the header tank. The longer the line the better the results (in theory) Im getting good results with a 25 foot line. 3. feed the blaster from the header tank thru the filter/regulator. 4. Blast away. Works well for me. Sean Trost  |
On Fri, 25 Jun 2004 18:09:32 GMT, Sean Trost
	wrote: Solution. Take one bog standard portable air tank. Drill a hole in the side of the thing or top does'nt matter. Weld a steel male to male bung onto the side of it and then attach a ball valve or quick connect. Remove air fitting that came with the tank. I was left with a 1/2" threaded bung. Using a 1/2 steel pipe nipple and 90Deg fitting from Lowes aerospace supply company I hung a Johnson Controls Filter regulator on it. (also from lowes) How the setup works. 1. Locate the compressor in a different location than where you are blasting. 2. connect an airline fromt he compressor to the header tank/reg/filter. This is important. The length of the line will help cool the air down. This allows water to condensate out and get trapped in the header tank. The longer the line the better the results (in theory) Im getting good results with a 25 foot line. 3. feed the blaster from the header tank thru the filter/regulator. 4. Blast away. Works well for me. Sean Trost now that's an interesting approach. I've battled with a regulator with creamic water trap for some time and it just doesnt work well enough to trap out all the water. thanks mate Stealth Pilot Australia  |
My brother has a VW compressor which runs on two of the four cylinders and
	has compressor heads on the other two. Although it produces plenty of air, it is oily, hot, and certainly can have a high water content in a Brisbane (Australia) summer. As the compressor cylinders are lubricated by the dirty engine oil, the oil content in the air tank is yuck. (Technical term!) As a condensation unit he uses 20 feet of 3/4 inch copper water pipe coiled up inside a 44 gallon (55 US gallon) drum full of water. The air enters at the top of the coil and travells down the coil to the bottom of the drum and then the copper pipe is bent back up out of the water. This cooled air is then fed to a commercial water and oil trap which catches almost every last drop of oil from the now cooled air. He uses the air for sand blasting timber for artistic furniture and creative artwork and the air is cleaner than anything else he has tried. If there is any oil or water in the air it stains the timber and he gets pretty finicky with his quality control...... If he uses it for continued operation, he changes the water in the drum after about an hour or leaves a hose running to overflow the drum so the hot water is continually changed with fresh cold water and the garden gets a drink. The copper pipe is readily available at your local hardware store, and a copper olive from a standard plumbing fitting soldered on each end of the pipe makes a great bevel for the hose clamp to hold against so the flexible hose can't blow off. You might use a flair to do the same thing. This part is cheap, the drum also is an old second hand plastic one (no rusty water) with one end cut out, but a garbage can or and old oil drum would be just as good as it only has to hold water and no pressure. The lot is mounted on the back of an old unregistered farm truck so he can keep it in the shed and drive down the back paddock when he wants to blast the timber and that way he leaves all the mess down the paddock. Hope this helps, Peter  |
Peter,
	Jeebus! Did a fellow named Rube Goldberg have anything to do with the construction? BillC85 "Bushy" wrote in message ... My brother has a VW compressor which runs on two of the four cylinders and has compressor heads on the other two. Although it produces plenty of air, it is oily, hot, and certainly can have a high water content in a Brisbane (Australia) summer. As the compressor cylinders are lubricated by the dirty engine oil, the oil content in the air tank is yuck. (Technical term!) As a condensation unit he uses 20 feet of 3/4 inch copper water pipe coiled up inside a 44 gallon (55 US gallon) drum full of water. The air enters at the top of the coil and travells down the coil to the bottom of the drum and then the copper pipe is bent back up out of the water. This cooled air is then fed to a commercial water and oil trap which catches almost every last drop of oil from the now cooled air. He uses the air for sand blasting timber for artistic furniture and creative artwork and the air is cleaner than anything else he has tried. If there is any oil or water in the air it stains the timber and he gets pretty finicky with his quality control...... If he uses it for continued operation, he changes the water in the drum after about an hour or leaves a hose running to overflow the drum so the hot water is continually changed with fresh cold water and the garden gets a drink. The copper pipe is readily available at your local hardware store, and a copper olive from a standard plumbing fitting soldered on each end of the pipe makes a great bevel for the hose clamp to hold against so the flexible hose can't blow off. You might use a flair to do the same thing. This part is cheap, the drum also is an old second hand plastic one (no rusty water) with one end cut out, but a garbage can or and old oil drum would be just as good as it only has to hold water and no pressure. The lot is mounted on the back of an old unregistered farm truck so he can keep it in the shed and drive down the back paddock when he wants to blast the timber and that way he leaves all the mess down the paddock. Hope this helps, Peter  |
It probably more of a monument to the memory of "Steptoe and Son", (British
	TV series about a garbage and scrap recycler from many years ago) but it works a treat. Just the sort of tools you expect to see us poor homebuilders working with! Hope this helps, Peter "BillC85" wrote in message ... Peter, Jeebus! Did a fellow named Rube Goldberg have anything to do with the construction? BillC85 "Bushy" wrote in message ... My brother has a VW compressor which runs on two of the four cylinders and has compressor heads on the other two. Although it produces plenty of air, it is oily, hot, and certainly can have a high water content in a Brisbane (Australia) summer. As the compressor cylinders are lubricated by the dirty engine oil, the oil content in the air tank is yuck. (Technical term!) As a condensation unit he uses 20 feet of 3/4 inch copper water pipe coiled up inside a 44 gallon (55 US gallon) drum full of water. The air enters at the top of the coil and travells down the coil to the bottom of the drum and then the copper pipe is bent back up out of the water. This cooled air is then fed to a commercial water and oil trap which catches almost every last drop of oil from the now cooled air. He uses the air for sand blasting timber for artistic furniture and creative artwork and the air is cleaner than anything else he has tried. If there is any oil or water in the air it stains the timber and he gets pretty finicky with his quality control...... If he uses it for continued operation, he changes the water in the drum after about an hour or leaves a hose running to overflow the drum so the hot water is continually changed with fresh cold water and the garden gets a drink. The copper pipe is readily available at your local hardware store, and a copper olive from a standard plumbing fitting soldered on each end of the pipe makes a great bevel for the hose clamp to hold against so the flexible hose can't blow off. You might use a flair to do the same thing. This part is cheap, the drum also is an old second hand plastic one (no rusty water) with one end cut out, but a garbage can or and old oil drum would be just as good as it only has to hold water and no pressure. The lot is mounted on the back of an old unregistered farm truck so he can keep it in the shed and drive down the back paddock when he wants to blast the timber and that way he leaves all the mess down the paddock. Hope this helps, Peter  |
The better solution (the one that will actually work) is to find a pneumatic or
	industrial parts supplier and get a coalescing filter unit of the appropriate size. The standard filtration rate in the Wilkerson units that I used to sell was .1 microns, although you can get cartridges that will filter down to .003 microns. The standard filtration rate for Home Depot/Lowe's/HF units is 60-40 microns. The setup that I'd use would be to go from the compressor tank, through a standard industrial-quality piggyback filter/reg., into a receiver tank (made of a 7-gal inflator tank modified with a few push-to-connect fittings. Then out of the receiver tank, through the coalescer, through another reg. if you need it, and then into the tool. That's the setup that is used on most of the industrial machines that I now work in, and should eliminate most of the problems you are having. I'd also definately locate that compressor inside in a clean area. Outside compressors suck in a lot of junk and moisture. Be sure that your air line includes a drop-leg or a tank drain somewhere, and that all of your air take-offs are located on the top side of your fixed air line. Harry "former pneumatic systems specialist" Frey  |
