![]() A Lieberman wrote: Approach said to me, 43L, you are suppose to call before you leave the ground on 123.90. Squawk 0104. To which you reply..."I don't think so, squawk 0104." When they're clearly wrong I don't hesitate to give them the needle. |
91.123 Compliance with ATC clearances and instructions. (b) Except in
an emergency, no person may operate an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised. Presumably, the approaching aircraft was in Class E airspace, which is defined as controlled airspace. Doesn't that obligate the pilot to follow ATC instructions given to him? Even if it were Class G airpspace, it's a de facto "area in which air traffic control is exercised," by the fact that the tower controller is providing service, and the regulation applies. It's a given that you have to establish 2-way communication (or make prior arrangements) before you can enter Class D airspace, and it follows that if you're not going in to the airspace, you don't need to contact the controller. .... but once a pilot contacts a controller, isnt' he obligated to comply whether he's in that controller's jurisdiction or not? I can't recall any regulation that indicates otherwise. |
![]() Brien K. Meehan wrote: 91.123 Compliance with ATC clearances and instructions. (b) Except in an emergency, no person may operate an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised. Presumably, the approaching aircraft was in Class E airspace, which is defined as controlled airspace. Doesn't that obligate the pilot to follow ATC instructions given to him? No, the class D tower has no more authority in class E as he does in class G. Even if it were Class G airpspace, it's a de facto "area in which air traffic control is exercised," by the fact that the tower controller is providing service, and the regulation applies. Nope. ... but once a pilot contacts a controller, isnt' he obligated to comply whether he's in that controller's jurisdiction or not? No and the class D controller shouldn't be trying to control you outside his airspace. |
I would have answered... "you told me to follow the Cherokee, and that is
what I'm trying to do".. maintain visual separation means just that.. the controller gave the pilot permission to do what is needed to follow the Cherokee.. Once the tower identified that the Cessna had the wrong Cherokee.. the tower controller over reacted by berating the pilot about it. The pilot did have permission to maneuver (see above). The tower should have just re-issued a new direction (clearance) and let it go. Granted.. the controllers un professional actions on the radio do not warrant the CFI's response. Calls to supervisors on the ground are the order, and if the supervisor presses the issue. Ask him to pull the tapes, and that you are filing a HATR. BT "Bob Gardner" wrote in message ... Once in radio contact with ATC, whether inside of that controller's airspace or not, the pilot should get permission before doing anything like a 360. He (in this case) has no idea of the controller's traffic management plan. I agree that the best thing to do is comply with instructions and hash it out on the ground. Ask the controller for a phone number and his initials. Bob Gardner wrote in message ups.com... Howdy, I was interested in some other pilots' 'takes' on the following. I was up with a student a few days ago, when another CFI I know (flying out of the same airport I do) also with a student had an issue with an air traffic controller. We were both flying out of airport A, which is a non-towered airport near a fairly large city. Airport B is a class D (non federal towered) municipal airport about 10 miles South of airport A. The controllers at airport B have a reputation as kind of prickly. The following is the jist of the conversation: Cessna "Airport B tower, this is Cessna 123, 2000 off of airport A, 10 miles North, inbound landing with kilo" Tower "Roger, Cessna, you will be number 2 for runway 21R, follow Cherokee traffic at your 11 O'Clock, you also have Cherokee traffic transitioning at your 2 O'Clock, and Skyhawk traffic inbound on the ILS for the parallel. Maintain visual separation." Cessna "Roger, have the Cherokee traffic, will follow him in, visual separation" A couple minutes later Tower "Cessna, what are you doing out there?" Cessna "Tower, that Cherokee isn't making much progress, we're making a couple 360s for spacing" Tower (in a nasty tone) "Negative Cessna! You're following the wrong Cherokee. You need my permission before making any maneuvers like that. If you are inbound, you need to be a direct heading *to* my airport. You can't be doing that kind of stuff without telling me." [pause] Cessna "Tower, I was following the Cherokee that was at my 11. Sorry if I got the wrong one. But sir, I am VFR, *outside* of your airspace...if I feel the need to do a 360 to maintain safe spacing, that's exactly what I will do...I'm outside of your airspace. I don't need your permission to do *anything* until I enter it. Turning 210 for landing now" The controller didn't say anything else, expect a gruff 'Cleared for landing 21R'. I haven't talked to the other CFI about this yet. The reason I am asking is that my student (already scared to talk to ATC) is even *more* scared now, and asked me about it. I told him that the pilot was technically right...if you are in uncontrolled airspace, and are responsible for maintaining visual seperation from other aircraft, then you can certainly make 'normal' maneuvers to do that. And I told him that a Class D tower controller doesn't have any say about what you do outside of his airspace. I also told him that it usually wasn't a good idea to have an altercation like that on the radio. That if the pilot wanted to talk to the controller about that, he should have waited until he was on the ground, and called the tower and asked to speak with a supervisor. I also told him that the other CFI 'probably' should have told the controller what he was doing as a matter of 'courtesy', and that if he wasn't absolutely sure which Cherokee to follow, he should have told the controller that he'd remain outside of his airspace until the tower told him the traffic was clear, and then turn in. Plus, it isnt a good idea to alienate the ATC guys in your own area....they can make life 'interesting' sometimes. But the tower controller didn't tell him to copy a number (altho maybe he got that on the ground. But I asked a few of the other CFIs I work with about this..most agreed with me, but a couple thought the pilot was wrong for various reasons. So...what is your take on this? Cheers, Cap |
can you get a word in edgewise on the frequency? many times I have not been
able to and had to circle outside his airspace just to get into the flow on the radios and get permission to proceed. (Initial call up) BT "Bill Denton" wrote in message ... Just a somewhat uneducated guess... You were inbound to an airport and talking to tower. Would it have been too much trouble to simply key the mic and tell the controller that you were having spacing problems on the Cherokee, and ask for permission to do your 360's? Regardless of regulations, regardless of responsibility, isn't tower providing sequencing at that point? Common sense would tell you that under those circumstances, if everyone of the aircraft simply started flying whatever path they wanted to would be an extremely dangerous situation. You noted: "The controllers at airport B have a reputation as kind of prickly". If this is an example of the types of situations they are dealing with, don't you think their attitude might be justified? wrote in message ups.com... Howdy, I was interested in some other pilots' 'takes' on the following. I was up with a student a few days ago, when another CFI I know (flying out of the same airport I do) also with a student had an issue with an air traffic controller. We were both flying out of airport A, which is a non-towered airport near a fairly large city. Airport B is a class D (non federal towered) municipal airport about 10 miles South of airport A. The controllers at airport B have a reputation as kind of prickly. The following is the jist of the conversation: Cessna "Airport B tower, this is Cessna 123, 2000 off of airport A, 10 miles North, inbound landing with kilo" Tower "Roger, Cessna, you will be number 2 for runway 21R, follow Cherokee traffic at your 11 O'Clock, you also have Cherokee traffic transitioning at your 2 O'Clock, and Skyhawk traffic inbound on the ILS for the parallel. Maintain visual separation." Cessna "Roger, have the Cherokee traffic, will follow him in, visual separation" A couple minutes later Tower "Cessna, what are you doing out there?" Cessna "Tower, that Cherokee isn't making much progress, we're making a couple 360s for spacing" Tower (in a nasty tone) "Negative Cessna! You're following the wrong Cherokee. You need my permission before making any maneuvers like that. If you are inbound, you need to be a direct heading *to* my airport. You can't be doing that kind of stuff without telling me." [pause] Cessna "Tower, I was following the Cherokee that was at my 11. Sorry if I got the wrong one. But sir, I am VFR, *outside* of your airspace...if I feel the need to do a 360 to maintain safe spacing, that's exactly what I will do...I'm outside of your airspace. I don't need your permission to do *anything* until I enter it. Turning 210 for landing now" The controller didn't say anything else, expect a gruff 'Cleared for landing 21R'. I haven't talked to the other CFI about this yet. The reason I am asking is that my student (already scared to talk to ATC) is even *more* scared now, and asked me about it. I told him that the pilot was technically right...if you are in uncontrolled airspace, and are responsible for maintaining visual seperation from other aircraft, then you can certainly make 'normal' maneuvers to do that. And I told him that a Class D tower controller doesn't have any say about what you do outside of his airspace. I also told him that it usually wasn't a good idea to have an altercation like that on the radio. That if the pilot wanted to talk to the controller about that, he should have waited until he was on the ground, and called the tower and asked to speak with a supervisor. I also told him that the other CFI 'probably' should have told the controller what he was doing as a matter of 'courtesy', and that if he wasn't absolutely sure which Cherokee to follow, he should have told the controller that he'd remain outside of his airspace until the tower told him the traffic was clear, and then turn in. Plus, it isnt a good idea to alienate the ATC guys in your own area....they can make life 'interesting' sometimes. But the tower controller didn't tell him to copy a number (altho maybe he got that on the ground. But I asked a few of the other CFIs I work with about this..most agreed with me, but a couple thought the pilot was wrong for various reasons. So...what is your take on this? Cheers, Cap |
Class E airspace in general is UNCONTROLLED.. it is only "controlled" for
IFR traffic.. I can fly in Class E all I want and talk to no one.. as long as I maintain required visual weather minimums.. BT "Brien K. Meehan" wrote in message oups.com... 91.123 Compliance with ATC clearances and instructions. (b) Except in an emergency, no person may operate an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised. Presumably, the approaching aircraft was in Class E airspace, which is defined as controlled airspace. Doesn't that obligate the pilot to follow ATC instructions given to him? Even if it were Class G airpspace, it's a de facto "area in which air traffic control is exercised," by the fact that the tower controller is providing service, and the regulation applies. It's a given that you have to establish 2-way communication (or make prior arrangements) before you can enter Class D airspace, and it follows that if you're not going in to the airspace, you don't need to contact the controller. ... but once a pilot contacts a controller, isnt' he obligated to comply whether he's in that controller's jurisdiction or not? I can't recall any regulation that indicates otherwise. |
Newps wrote:
No, the class D tower has no more authority in class E as he does in class G. Who says he has no authority in class E or G airspace? |
BTIZ wrote:
I can fly in Class E all I want and talk to no one.. as long as I maintain required visual weather minimums.. Everyone knows that. .... but if you call a controller and ask for service, you ARE talking to someone. Aren't you obligated to follow instructions given to you at that point? What regulation indicates otherwise? |
(sorta OT) Free Ham Radio Course | RST Engineering | Home Built | 51 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Radio waves vs light waves | Jay Honeck | Piloting | 63 | February 22nd 04 05:14 PM |
Radio silence, Market Garden and death at Arnhem | ArtKramr | Military Aviation | 4 | February 12th 04 12:05 AM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
