Hi all...
Was doing a little web reading on part 103 Ultralights (both gyro's and more conventional winged thingys)..... And it quickly becomes obvious that staying under that 250 pound or so limit aint easy... So, so the gas tanks (like everything else on an ultralight) doesn' t really inspire confidence from a strength point of view.....and those extra pounds to make the tank to hold the gas are just that many more pounds you have to give up somewhere else. And I've notice that some gyro's and other ultralights have relatively large hollow metal tubes that form a "backbone" to which all the other important parts are attached.... So, my question is......could you actually USE these tubes as your gas tank to hold your precious 5 gallons of fuel (part 103 limit)? Anybody anywhere tried that that you know of? Could you prevent internal corrosion in aluminum (or even steel) tubing? With perhaps some sacrificial internal metal ( like the zinc blocks they put on boats). And maybe make sure there is NO place for water to seperate out and settle, or if there is, its at a place of minimal stress on the structure, or perhaps is even a little seperate offshoot "tube" that is not load bearing in any fashion. Flame away ![]() take care Blll |
BllFs6 wrote:
snip So, my question is......could you actually USE these tubes as your gas tank to hold your precious 5 gallons of fuel (part 103 limit)? Years ago in Oz you could get steel backpack frames which held (usually) kerosene (or shellite/white gasoline) for stoves. IIRC corrosion wasn't an issue for a few years and they were probably subjected to more impact loads then airframes normally are. -- regards jc LEGAL - I don't believe what I wrote and neither should you. Sobriety and/or sanity of the author is not guaranteed EMAIL - and are not valid email addresses. news2x at perentie is valid for a while. |
The Grumman AA-1 stores fuel in a tubular wing spar.
BllFs6 wrote: Hi all... Was doing a little web reading on part 103 Ultralights (both gyro's and more conventional winged thingys)..... And it quickly becomes obvious that staying under that 250 pound or so limit aint easy... So, so the gas tanks (like everything else on an ultralight) doesn' t really inspire confidence from a strength point of view.....and those extra pounds to make the tank to hold the gas are just that many more pounds you have to give up somewhere else. And I've notice that some gyro's and other ultralights have relatively large hollow metal tubes that form a "backbone" to which all the other important parts are attached.... So, my question is......could you actually USE these tubes as your gas tank to hold your precious 5 gallons of fuel (part 103 limit)? Anybody anywhere tried that that you know of? Could you prevent internal corrosion in aluminum (or even steel) tubing? With perhaps some sacrificial internal metal ( like the zinc blocks they put on boats). And maybe make sure there is NO place for water to seperate out and settle, or if there is, its at a place of minimal stress on the structure, or perhaps is even a little seperate offshoot "tube" that is not load bearing in any fashion. Flame away ![]() take care Blll -- John Kimmel "Cuius testiculos habes, habeas cardia et cerebellum." - When you have their full attention in your grip, their hearts and minds will follow. |
There are motorcycles that use the structural tubing as pipes to get the
coolant from engine to radiator. Older GSX-R 750s come to mind. "BllFs6" wrote in message ... Hi all... Was doing a little web reading on part 103 Ultralights (both gyro's and more conventional winged thingys)..... And it quickly becomes obvious that staying under that 250 pound or so limit aint easy... So, so the gas tanks (like everything else on an ultralight) doesn' t really inspire confidence from a strength point of view.....and those extra pounds to make the tank to hold the gas are just that many more pounds you have to give up somewhere else. And I've notice that some gyro's and other ultralights have relatively large hollow metal tubes that form a "backbone" to which all the other important parts are attached.... So, my question is......could you actually USE these tubes as your gas tank to hold your precious 5 gallons of fuel (part 103 limit)? Anybody anywhere tried that that you know of? Could you prevent internal corrosion in aluminum (or even steel) tubing? With perhaps some sacrificial internal metal ( like the zinc blocks they put on boats). And maybe make sure there is NO place for water to seperate out and settle, or if there is, its at a place of minimal stress on the structure, or perhaps is even a little seperate offshoot "tube" that is not load bearing in any fashion. Flame away ![]() take care Blll |
A lot of airliners store fuel in the horizontal tail...
"Jay" wrote in message om... You usually put fuel near the center of lift so that as the fuel burns off the balance of the aircraft doesn't change. This is part of the reason they taught ww2 fighter pilot to aim for the intersection of the fuselage and the wings, thats "bingo" fuel. Hollow wing spars might be a good funky place as others have mentioned. The additional benefit of storing in the wings is that the fuel weight doesn't count against your bending loads at the wing roots like your butt sitting in a seat does. (BllFs6) wrote in message ... Hi all... Was doing a little web reading on part 103 Ultralights (both gyro's and more conventional winged thingys)..... And it quickly becomes obvious that staying under that 250 pound or so limit aint easy... So, so the gas tanks (like everything else on an ultralight) doesn' t really inspire confidence from a strength point of view.....and those extra pounds to make the tank to hold the gas are just that many more pounds you have to give up somewhere else. And I've notice that some gyro's and other ultralights have relatively large hollow metal tubes that form a "backbone" to which all the other important parts are attached.... So, my question is......could you actually USE these tubes as your gas tank to hold your precious 5 gallons of fuel (part 103 limit)? Anybody anywhere tried that that you know of? Could you prevent internal corrosion in aluminum (or even steel) tubing? With perhaps some sacrificial internal metal ( like the zinc blocks they put on boats). And maybe make sure there is NO place for water to seperate out and settle, or if there is, its at a place of minimal stress on the structure, or perhaps is even a little seperate offshoot "tube" that is not load bearing in any fashion. Flame away ![]() take care Blll |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 08:48 AM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
| Fuel pressure Problems | smf | Home Built | 3 | September 7th 03 09:25 PM |
