Red Hot Pilot
Old January 31st 05, 03:01 PM
Larry Dighera
"Big John" wrote in message
http://www.fan-tasticmodels.com/muller.wmv
On Sun, 30 Jan 2005 21:17:17 -0800, "aluckyguess" wrote in ::
I have a friend that can do that stuff. I was alright but nothing like those
guys.You can check some of his videos.
http://marktrent1.com/
Many thanks for the link to your friend's videos. His Giant Scale
aircraft is remarkable, however this one is a little more like the one
in the link provided by the OP:
http://www.nesail.com/detail.php?productID=1573
Old January 31st 05, 03:03 PM
Larry Dighera
On Thu, 27 Jan 2005 20:44:21 -0600, Big John
wrote in ::
Here's another: http://www.nesail.com/videos/quasar.mpg
Why does it take an electric motor to provide this sort of
performance?
Could this portend a future trend in manned aircraft?
Old January 31st 05, 10:12 PM
Big John
Larry
There are some UAV's, now in test, that run on batteries.
Big John
On Mon, 31 Jan 2005 14:03:26 GMT, Larry Dighera
wrote in ::
performance?
Old February 1st 05, 12:17 AM
Larry Dighera
On Mon, 31 Jan 2005 15:12:17 -0600, Big John
wrote in ::
I know Aerovironment made one for the government powered by solar
cells. Are you referring to something else?
Old February 1st 05, 12:57 AM
Dave
Basically, unlike only a short time ago, you can now pack more
horsepower and duration into a model with an electric power system
than glow power.....
My most powerfull models are electric.....
One reason for this is that the model can be built very light because
the structure does not have to secure and withstand the pounding of a
recriprocating engine....
My indoor model hovers at 30-40 % throttle..., and my Cloud Dancer
(with the old ni-cads) has unlimited vertical.
With a comparable li-po battery, it would be ballistic, and I would
have to land it when before I get tired...
We have come a long way...
Dave
performance?
Old February 1st 05, 04:17 PM
Larry Dighera
performance?
On Mon, 31 Jan 2005 19:57:39 -0400, Dave
wrote in
Basically, unlike only a short time ago, you can now pack more horsepower and duration into a model with an electric power system than glow power.....
Are you sure about that? Are you aware of any 16 horsepower electric
motors on the model airplane market? Here's one that claims to output
16.5 hp: http://www.desertaircraft.com/engine...hp?Page=DA-150
So it's easier to increase the horsepower to weight ratio with
electric powered aircraft, because they don't have to be built so
stoutly?
Isn't the increased control over throttled power output of electric
motors part of the reason they are beginning supplant IC engines in
some arenas? I would guess that the absence of exhaust emissions,
flammable fuel, noise, and starter are also part of the attractiveness
of electric power.
and my Cloud Dancer (with the old ni-cads) has unlimited vertical.
Right. From the videos I've seen, it looks as if the electric powered
aircraft hanging on their propellers are actually performing in "helo"
mode rather than using the wings' lift for flying.
The advancements in battery technology and electric motor development
are remarkable. I'm just wondering if it is scaleable to manned
aircraft.
Old February 2nd 05, 06:28 AM
Dave
OOPS!...I should explain further....
AIRCRAFT, not necessarily the ENGINE...
I have several models with more powerful engines.... but none with
the power/weight ratio of the electrics....
stoutly?
Yes....they have to be constructed only to support flight
loads/stresses... LOTS of wood blocks, hardwood and plywood goes
away......foam plastic and light plastic components appear in the
construction that would in no way survive the pounding of a recip
engine...
of electric power.
....all correct.....I can idle an electric motor at speed you can count
the blades as they pass....and I had never had a motor completely fail
in flight.
The new "outrunners" do not require a gearbox in most applications..
only mechanical points of failure are the bearings...
aircraft.
Old February 2nd 05, 06:43 AM
Dave
Rats... that post went too soon.. I hate laptop KB's....
To continue....
of electric power.
Yes.. the lack of noise, exhaust, (can fly indoors), no oily gunk to
be cleaned off the model and less ground support equipment are a
given..
Yes, we call it "3D" flying..and some models (and pilots) fly as if
there is no consideration given to the presence of gravity....
aircraft.
Dono Larry.....
Statistically, the next "breakthrough" in battery technology is only
two years away... and I am told by those who "should" know, that we
will soon see fuel cells in high end laptops...
I am amazed that we are "here"...already
Scaleable to "full size" ?
It seems possible, and even probable...
I expect it will happen..
Cheers!
Dave
Old February 4th 05, 07:41 PM
Larry Dighera
On Wed, 02 Feb 2005 01:43:56 -0400, Dave
wrote in
aircraft.
Dono Larry.....
two years away...
What sort of "breakthrough" might that be?
I find that hard to believe.
It's getting a lot closer:
http://www.google.co.uk/groups?q=fue... ax.com&rnum=1
Old February 5th 05, 04:09 AM
Dave
two years away...
No idea Larry,- this based on the historically shortening time
periods between "Breakthroughs" in battery technology...
So do I, BUT the Laboratory size fuel cells that have been successfull
are small, light, and will operate a modern laptop...
Who knows what is next!
Dave
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
Renting an airplane? Need Expert FARS Advice?? NW_PILOT Piloting 50 September 27th 04 04:17 PM
Sport Pilot inconsistency frustrated flier Piloting 19 September 10th 04 05:53 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Piloting 114 July 22nd 04 06:40 PM
