Would a gyro with a swashplate ( just for pitch control) fly any different
(better,worse) than using a tilt type rotor head? Just more complex? Also, I've seen some photos of early kit helicopters that appear to have just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death wish? Does a helicopter need to have collective pitch for anything other than auto-rotaion? Silly questions, but it's a late night. ![]() |
"Rhodesst" wrote in message ... Power adjustments. Wally Power adjustments? I don't see the difference a swashplate over a tilt head for cyclic control would make to a gyros rotor system. Care to explain further? OTOH, I think that sport gyros today use the tilt rotor hub because it's a very simple design, and it works very well. No swashplate and associated linkages, not to mention the fact that there's no need for individual feathering hinges on the rotor blades themselves. Much less to go wrong and/or maintain. JMO, Fly Safe, Steve R. The K.I.S.S. formula at it's best. So why not on a helicopter? (Like those old kits I mentioned). I'm assuming because you'd lose auto-rotation? |
On Mon, 21 Jul 2003 01:21:13 -0700, "Phillip" wrote:
Would a gyro with a swashplate ( just for pitch control) fly any different (better,worse) than using a tilt type rotor head? Just more complex? Just more complex. The net effect would be the same. Increase the angle of attack 90 degrees before desired disc upward movement, decrease AoA 90 degrees before. Gyroscopic precession then makes the desire movement happen. Also, I've seen some photos of early kit helicopters that appear to have just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death wish? Does a helicopter need to have collective pitch for anything other than auto-rotaion? Helicopter collective increase/decreases pitch angle of all blades collectively and thereby increases/decreases lift. Pull collective up, go up. lower collective, go down. It's a bit more complex than that, but I'll leave that to the experts here. Silly questions, but it's a late night. ![]() Phil -- Definitions of a pilot - No. 1 The average pilot, despite the sometimes swaggering exterior, is very much capable of such feelings as love, affection, intimacy and caring. These feelings just don't involve anybody else. US Navy Times |
"Phillip" wrote in
: Also, I've seen some photos of early kit helicopters that appear to have just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death wish? Does a helicopter need to have collective pitch for anything other than auto-rotaion? Helicopters depend on collective pitch for control of power - they have no other way to fly. Without collective pitch, you can't get off the ground, or change power, or get back on the ground in one piece. -- Regards, Stan |
Stan Gosnell wrote:
"Phillip" wrote in : Also, I've seen some photos of early kit helicopters that appear to have just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death wish? Does a helicopter need to have collective pitch for anything other than auto-rotaion? Helicopters depend on collective pitch for control of power - they have no other way to fly. Without collective pitch, you can't get off the ground, or change power, or get back on the ground in one piece. IIRC, at least the first Piasecki helo and maybe the first Hiller lacked collective pitch. Lift was controlled by the throttle (which controlled the engine and thus rotor rpm), and they seemed to have flown just fine. There are clearly advantages to the collective system as later models all included it, but it's not as if a helo has to have one to fly. Guy |
"Guy Alcala" wrote in message . .. Stan Gosnell wrote: "Phillip" wrote in : Also, I've seen some photos of early kit helicopters that appear to have just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death wish? Does a helicopter need to have collective pitch for anything other than auto-rotaion? Helicopters depend on collective pitch for control of power - they have no other way to fly. Without collective pitch, you can't get off the ground, or change power, or get back on the ground in one piece. IIRC, at least the first Piasecki helo and maybe the first Hiller lacked collective pitch. Lift was controlled by the throttle (which controlled the engine and thus rotor rpm), and they seemed to have flown just fine. There are clearly advantages to the collective system as later models all included it, but it's not as if a helo has to have one to fly. Guy I guess what I wondered was , other than a need to auto-rotate, a tilt system would work on a helicopter the same as a gyro? Yes I know auto-rotation is needed...I'm just wounding if the concept is the same. ![]() That's what these kits mentioned (it's been a long time), you added power to go up, remove power to come down...seems simple enough. Don't think I'd like the idea of no collective control for auto-rotation. |
On Tue, 22 Jul 2003 10:43:27 +1000, Phil Miller
wrote: On Mon, 21 Jul 2003 01:21:13 -0700, "Phillip" wrote: Would a gyro with a swashplate ( just for pitch control) fly any different (better,worse) than using a tilt type rotor head? Just more complex? Just more complex. The net effect would be the same. Increase the angle of attack 90 degrees before desired disc upward movement, decrease AoA 90 degrees before. Gyroscopic precession then makes the desire movement ^^^^^^ happen. Woops. After. Also, I've seen some photos of early kit helicopters that appear to have just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death wish? Does a helicopter need to have collective pitch for anything other than auto-rotaion? Helicopter collective increase/decreases pitch angle of all blades collectively and thereby increases/decreases lift. Pull collective up, go up. lower collective, go down. It's a bit more complex than that, but I'll leave that to the experts here. Silly questions, but it's a late night. ![]() Phil Phil -- "Me fail english? That's unpossible!" Ralph Wiggum |
"Phillip" wrote: "Rhodesst" wrote in message ... Power adjustments. Wally Power adjustments? I don't see the difference a swashplate over a tilt head for cyclic control would make to a gyros rotor system. Care to explain further? OTOH, I think that sport gyros today use the tilt rotor hub because it's a very simple design, and it works very well. No swashplate and associated linkages, not to mention the fact that there's no need for individual feathering hinges on the rotor blades themselves. Much less to go wrong and/or maintain. JMO, Fly Safe, Steve R. The K.I.S.S. formula at it's best. So why not on a helicopter? (Like those old kits I mentioned). I'm assuming because you'd lose auto-rotation? The basic principle of autogyro flight is auto-rotation. What you'd lose is a simple, practical way of controlling powered flight. -- Paul Baechler |
"Bart" wrote in message ... Phillip wrote: I guess what I wondered was , other than a need to auto-rotate, a tilt system would work on a helicopter the same as a gyro? Yes I know auto-rotation is needed...I'm just wounding if the concept is the same. ![]() That's what these kits mentioned (it's been a long time), you added power to go up, remove power to come down...seems simple enough. Don't think I'd like the idea of no collective control for auto-rotation. No, a helicopter can not operate without a swashplate. Without the swashplate you'd just be able to go up and down. I'll probably draw some heat here for this, but autogyros have more in common with airplanes than they do helicopters. The aerodynamics are really different. In horizontal flight, a helicopter is constantly changing the pitch of each main rotor blade independently as it travels around in the circuit. The advancing blade has negative relative pitch, and the retreating blade has hugely positive relative pitch. Horizontal thrust is not derived by tilting the mast. The swashplate is controlled by the cyclic and collective together. The two flight controls are "mixed together" to move the swashplate. The collective moves the pitch of all blades equally, the cyclic tilts the swashplate to cause the pitch changes to be become "cyclical". Bart I see those brothers (Nolan ?? ) built a coaxial with no swash plate....but also no auto-rotation. twin engine though. How do they get away with it? I guess the twin rotors would cancel all those bad things out. This is one of the kits I saw. http://www.airscooter.com No swashplates, no collective, NO AUTOROTATION (scary) two engines I think. |
On Fri, 25 Jul 2003 11:57:53 GMT, Terry Spragg
wrote: For the simplest possible reason: An auto gyro is always flown in autorotation, with fixed plade pitch set for 'gliding'. If you apply torque to an auto rotor, you do not get lift, you get propelled groundward. G'day Terry, Are you saying that autogyro's have negative pitch on their rotor blades? If so, you are wrong. If that's not what your saying, I apologise. I have misunderstood your meaning. Could you please explain this statement? Cheers, Phil -- Pfft...english! Who needs that? I'm never going to England. Homer J. Simpson |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Bothersome Phillips Head Screws | Larry Smith | Home Built | 48 | January 10th 04 05:26 AM |
| Aviano thanks base guardians as Puerto Rican guardsmen head home | Otis Willie | Military Aviation | 0 | September 1st 03 03:24 AM |
| Child head set | Dennis O'Connor | Piloting | 7 | July 15th 03 02:55 PM |
| Citabria with gyros | Bob Esser | Piloting | 6 | July 9th 03 01:03 AM |
