Is there an online source of downloadable CAD files for common AN
	hardware? I don't see any reason to redraw what I'm sure has been done many times. ========================= Leon McAtee  |
There are some commercial libraries but you have to buy them.
	For many other types of hardware you can download the files from the hardware manufacturers web sites (usually for free) but not for any AN hardware that I am aware of. Dan is right though ... it is no big deal to draw them (I have done this for some hardware). They don't have to be perfect so long as the overal dimensions are correct. If you are going to do this you first need to get the AN / MS data sheets which have all the required dimensions. You can get these from the STINET site. http://stinet.dtic.mil/str/index.html "B2431" wrote in message ... From: (Leon McAtee) Date: 9/7/2004 10:17 PM Central Daylight Time Message-id: Is there an online source of downloadable CAD files for common AN hardware? I don't see any reason to redraw what I'm sure has been done many times. ========================= Leon McAtee I use MicroStation. Several years ago I made cels of each AN bolt, washer an nut. With the nut and washers you only have to draw one of each type the scale as needed. With the bolts draw one of each length of a given size and scale as needed to the desired size. It's easy to set up a cel file for each type of item and in each size. It will take an hour or two depending on your skill, but it really is worth it. Dan, U.S. Air Force, retired  |
Thanks for the link, (i was happy there for a while, as I've been looking
	for this type of data for quite some time) although there seems to be a problem. - Very hard to find the information - Once the report required has been found I get a: "You have attempted to access a page without proper authorization" Hmmm, too bad, it would really have been great to have access to the actual mil-specs... "smjmitchell" wrote in message u... There are some commercial libraries but you have to buy them. For many other types of hardware you can download the files from the hardware manufacturers web sites (usually for free) but not for any AN hardware that I am aware of. Dan is right though ... it is no big deal to draw them (I have done this for some hardware). They don't have to be perfect so long as the overal dimensions are correct. If you are going to do this you first need to get the AN / MS data sheets which have all the required dimensions. You can get these from the STINET site. http://stinet.dtic.mil/str/index.html "B2431" wrote in message ... From: (Leon McAtee) Date: 9/7/2004 10:17 PM Central Daylight Time Message-id: Is there an online source of downloadable CAD files for common AN hardware? I don't see any reason to redraw what I'm sure has been done many times. ========================= Leon McAtee I use MicroStation. Several years ago I made cels of each AN bolt, washer an nut. With the nut and washers you only have to draw one of each type the scale as needed. With the bolts draw one of each length of a given size and scale as needed to the desired size. It's easy to set up a cel file for each type of item and in each size. It will take an hour or two depending on your skill, but it really is worth it. Dan, U.S. Air Force, retired  |
IIRC, Mr. Wanttaja has a story about drawing AN bolts and some peculiar head
	markings. How 'bout an encore, Ron? Rich  |
"Pierre"  wrote in message   m...
	Thanks for the link, (i was happy there for a while, as I've been looking for this type of data for quite some time) although there seems to be a problem. - Very hard to find the information - Once the report required has been found I get a: "You have attempted to access a page without proper authorization" Hmmm, too bad, it would really have been great to have access to the actual mil-specs... Which ones do you need? I've got a fairly good number of them in my hard files here at the house. Craig C.  |
"smjmitchell"  wrote in message .  au...
	There are some commercial libraries but you have to buy them. For many other types of hardware you can download the files from the hardware manufacturers web sites (usually for free) but not for any AN hardware that I am aware of. Dan is right though ... it is no big deal to draw them (I have done this for some hardware). I've begun the task of drawing the basics - as I need them. There must be a "gazillion" different nuts out there, or it seems that way. Once I get a good batch of files I'll post them on my web site for download. No reason not to share. CAD is something that I'm glad I taught myself. Slow at first, but now, it really saves time and material. The reason for needing hardware drawings was to make sure I had room to actually get a socket on my aileron hinge mounts. Nice to know that there will be room before mixing up the resin. There was! :-) Also being able to print accurate full size templates takes a lot of the work out of making things. Not a big deal if you follow the plans, but if you venture as far out in the Experimental part of our hobby as I have............ If you've never used CAD - Learn. Do a Google for DeltaCad for a good first CAD program (free download). So simple I bet that even someone that flunked geometry can make useable drawings in less than a 1/2 hour. ==================== Leon McAtee Still looking for Aeronca C-3 factory drawings.  |
Have you tried John Houser?
	"Leon McAtee" wrote in message om... "smjmitchell" wrote in message . au... There are some commercial libraries but you have to buy them. For many other types of hardware you can download the files from the hardware manufacturers web sites (usually for free) but not for any AN hardware that I am aware of. Dan is right though ... it is no big deal to draw them (I have done this for some hardware). I've begun the task of drawing the basics - as I need them. There must be a "gazillion" different nuts out there, or it seems that way. Once I get a good batch of files I'll post them on my web site for download. No reason not to share. CAD is something that I'm glad I taught myself. Slow at first, but now, it really saves time and material. The reason for needing hardware drawings was to make sure I had room to actually get a socket on my aileron hinge mounts. Nice to know that there will be room before mixing up the resin. There was! :-) Also being able to print accurate full size templates takes a lot of the work out of making things. Not a big deal if you follow the plans, but if you venture as far out in the Experimental part of our hobby as I have............ If you've never used CAD - Learn. Do a Google for DeltaCad for a good first CAD program (free download). So simple I bet that even someone that flunked geometry can make useable drawings in less than a 1/2 hour. ==================== Leon McAtee Still looking for Aeronca C-3 factory drawings.  |
	hardware manufacturers web sites (usually for free) but not for any AN hardware that I am aware of. Go get an Aircraft Spruce catalog. Quent  |
It`s be nice to have the most commen type of hardware complete spec sitting
	in a binder on a shelf just for when I need it. The first thing that comes to mind is the thickness of bolt heads and nuts (bolt length and grip length is in all catalogs but thickness of heads is another story) i.e. MS21042, AN354 and AN365, etc. Anchor nuts would be nice as well. The idea is that when I`m making a drawing, I don`t need the intricate details of the nut shape, but it`d be nice to know how thick it is (short of buying one of each and measuring one myself!) Also, strength values is not typically in catalogs. That would be nice to have Thanks for any help "Craig" wrote in message om... "Pierre" wrote in message m... Thanks for the link, (i was happy there for a while, as I've been looking for this type of data for quite some time) although there seems to be a problem. - Very hard to find the information - Once the report required has been found I get a: "You have attempted to access a page without proper authorization" Hmmm, too bad, it would really have been great to have access to the actual mil-specs... Which ones do you need? I've got a fairly good number of them in my hard files here at the house. Craig C.  |
| Extra 200 image files | Peter Orlov | Aerobatics | 0 | May 21st 04 12:19 AM |
| Go over the Binaries Files to see a real Hero | Badwater Bill | Home Built | 0 | March 20th 04 04:35 AM |
| Hardware | Lou Parker | Home Built | 10 | January 31st 04 01:21 PM |
| hardware to mount avionics trays | Matthew M. Jurotich | Home Built | 1 | November 17th 03 11:56 PM |
| Need help with hardware | Paul Mennen | Home Built | 8 | August 29th 03 04:54 AM |
