How do I get default fs2004 airports to show in the airport list when I open
afcad221 for the first time. The list I see is very extensive for Europe and the USA but doesn't have the airport for Brisbane International, Australia YBBN or any other Oceania [Australia or NZ region of world] airports. YBBN is a very large airport capable of allowing fully loaded B747s to take off. I have Australian scenery installed in fs2004 and disk 4 in the CD drive. Cheers Peter Cokley |
On Thu, 15 Jan 2004 17:20:35 +1000, "Peter and Susan"
wrote: How do I get default fs2004 airports to show in the airport list when I open afcad221 for the first time. File-Open Airport. Insert YBBN in the Airport ID window then Search, OK. -- Alan White Twenty-eight miles NW of Glasgow. Overlooking Loch Goil and Loch Long in Argyll, Scotland. http://tinyurl.com/55v3 |
Ignore my previous request as I found what I need at
http://afcad.projectai.com/ Cheers Peter Cokley Peter and Susan wrote in message ... How do I get default fs2004 airports to show in the airport list when I open afcad221 for the first time. The list I see is very extensive for Europe and the USA but doesn't have the airport for Brisbane International, Australia YBBN or any other Oceania [Australia or NZ region of world] airports. YBBN is a very large airport capable of allowing fully loaded B747s to take off. I have Australian scenery installed in fs2004 and disk 4 in the CD drive. Cheers Peter Cokley |
Hi Alan, your suggestion did not work for YBBN but I have since found
someone has done YBBN at http://afcad.projectai.com/ so I will experiemnt with this. Thanks Alan anyway, it was worth a try. Peter Cokley Alan White wrote in message ... On Thu, 15 Jan 2004 17:20:35 +1000, "Peter and Susan" wrote: How do I get default fs2004 airports to show in the airport list when I open afcad221 for the first time. File-Open Airport. Insert YBBN in the Airport ID window then Search, OK. -- Alan White Twenty-eight miles NW of Glasgow. Overlooking Loch Goil and Loch Long in Argyll, Scotland. http://tinyurl.com/55v3 |
![]() How do I get default fs2004 airports to show in the airport list when I open afcad221 for the first time. File-Open Airport. Insert YBBN in the Airport ID window then Search, OK. Alan White Hi Alan, Now I understand what you mean! It works!! What I did was to download the YBBN file from http://afcad.projectai.com/ and open it as you said and it works. What I incorrectly thought at the beginning was AFCAD would collect data from fs2004 but instead you have to make your own data or download from http://afcad.projectai.com/ if someone else has saved you the trouble and already done it and loaded it to that website. Great for adding an ILS to an airport!!!! Cheers and thanks Peter Cokley www.petan.net |
On Fri, 16 Jan 2004 10:29:10 +1000, "Peter and Susan"
wrote: What I incorrectly thought at the beginning was AFCAD would collect data from fs2004... It does. Have you done a full install with all the scenery? YBBN is in file ....\Flight Simulator 9\Scenery\Aust\scenery\AP988410.BGL. Have you got that file? -- Alan White Twenty-eight miles NW of Glasgow. Overlooking Loch Goil and Loch Long in Argyll, Scotland. http://tinyurl.com/55v3 |
![]() Alan White wrote in message ... On Fri, 16 Jan 2004 10:29:10 +1000, "Peter and Susan" wrote: What I incorrectly thought at the beginning was AFCAD would collect data from fs2004... It does. Have you done a full install with all the scenery? YBBN is in file ...\Flight Simulator 9\Scenery\Aust\scenery\AP988410.BGL. Have you got that file? -- Alan White No, I don't have the file although I thought I did have Australia installed on the hard drive, which means I had better redo my fs9 installation. Thanks Alan! Cheers Peter Cokley |
... On Fri, 16 Jan 2004 10:29:10 +1000, "Peter and Susan" wrote: What I incorrectly thought at the beginning was AFCAD would collect data from fs2004... It does. Have you done a full install with all the scenery? YBBN is in file ...\Flight Simulator 9\Scenery\Aust\scenery\AP988410.BGL. Have you got that file? -- Alan White AFCAD now working perfectly as you said after a reinstall!! Many thanks!!!!! Cheers Peter Cokley |
On Sat, 17 Jan 2004 10:26:34 +1000, "Peter and Susan"
wrote: Many thanks!!!!! :-) -- Alan White Twenty-eight miles NW of Glasgow. Overlooking Loch Goil and Loch Long in Argyll, Scotland. http://tinyurl.com/55v3 |
